I have 4 sale a freshly built performance engine for a Kombi, this engine will bolt into any pre '76 Kombi that takes a Type 4 engine, it has a 215mm
flywheel.
Engine specs
69mm crank and new 96mm Lionel Jones Slip in lightweight piston and barrel kit, displacement is 1998cc
Cam is a new Watson 25/65 with with new matching Watson lifters.
Heads are reconditioned 1800 heads with all new valves.
Engine has all new bearings, gaskets and seals.
Compression is set at 8.3 to 1
This engine will run at its best with a pair of 40mm Webers or Dells and a free flowing exhaust, although will still perform well with good stock
carbs.
Price is $3800.00 outright, no exchange required.
Engine is in Nowra NSW phone Dave on 0402 003965.
What crankshaft are you using? Just curious. Dave
Quote: |
Nice. What con rods does it use. Again just curious! Dave
Wow Lionel Jones, thats a name from the past
Lionel Jones bored the barrels to 80mm for my 40hp engine.......in 1961.
Quote: |
Quote: |
It would be interesting to see what rods are in this, I remember Lionel Jones and Bob @ WER offset grinding 66mm cranks to 69mm and using Porsche
rods.
The 25/65 from memory is a mid range cam 280* 0.420" which would make for a flat torque monster and should rev to 6500 with the 41x34 1800 heads. I
only base this on my personal experience with the same cam similar combo set up and could stand corrected.
Engine uses Ford Pinto rods.
Like Fish26 says, This cam is good mid range cam, with a set of Webers it will pull to 6000 rpm no problems and still have good bottom end power.
Tried sending a pm last night but not sure it went through. Will try again.
Sold
Good combo sold for a good price, what's it going in?
Hey fish26,
I grabbed the engine to go in my 74 rat panelvan. Fingers crossed I will be able to get it next weekend. Looking forward to getting it in the
kombi.
Dan
Cool, always nice to have a bit more poke, especially in a bus.
