custom header made of stock parts
subaruboxer - March 7th, 2005 at 09:59 PM
I build my own header with parts of the stock header and catalytic converter of the Subaru EJ 22.
To gain ground clearance I cut the flanges like shown here.
[ Edited on 9-11-2005 by subaruboxer ]
subaruboxer - March 7th, 2005 at 10:02 PM
And got them welded like shown left here.
subaruboxer - March 7th, 2005 at 10:11 PM
the other parts I used : 1 x 30° bend
2 x 45° bends
3 x 90° bends
1 x tube 1 meter
all in 50 mm diameter and stainless
steel
subaruboxer - March 7th, 2005 at 10:16 PM
The header already wraped in thermo tec exhaust insulating wrap.
subaruboxer - March 7th, 2005 at 10:18 PM
Please note the cat is up side down.
subaruboxer - March 7th, 2005 at 10:23 PM
the header painted black, because it was shining under the car. I want a sleeper look.
subaruboxer - March 7th, 2005 at 10:32 PM
The mounted header before it was all finished. I am testing with 2 different mufflers, thats why there are two seen here.
I am keen to see how much power output I am going to have with it. I will get it on a dyno, but not before the end of april. It is winter here in Germany with lots of snow this year
and 3 days ago we had minus 17 degrees celsius. I have bought the stock header of an Impreza WRX STI, that will be testet too on the dyno, but without a cat. I keep you posted.
subaruboxer - March 7th, 2005 at 10:51 PM
It was to big again. I spotwelded it and went to a professional welder to get it done. I went to the welder and my car six times to get it bit by bit and a perfect fit.
[Edited on 7-3-2005 by subaruboxer]
Jeza - March 10th, 2005 at 06:07 AM
Subaruboxer
These updates and pics of yours are great.
Keep it up :)
Jeremy
lugnuts - March 10th, 2005 at 03:29 PM
This is depressing,i feel like a junkie waiting for my next photo fix from subaruboxer,but anyway keep them coming very s l o w l y or ile OD,hey subaruboxer are u gunna put some fake exhaust tips out of the cutouts and make a SUPER SLEEPER.;)
subaruboxer - March 11th, 2005 at 02:57 AM
Hi lugnuts, you are right the exhaust tips are put into the cutouts to have it look stock. I made a little brace for the tips, but I have no picture of it. Got to take one.
subaruboxer - March 11th, 2005 at 06:48 AM
Found this picture of the early days. No pan, no engine but fake exhaust tips. You see, I always wanted to do it. If you can' t make it, fake it.
subaruboxer - May 7th, 2005 at 08:59 PM
mounted header
subaruboxer - July 29th, 2005 at 04:56 AM
This is what it is looking like now.
The muffler is a Peugeot 206 Gti.
boof2332 - July 29th, 2005 at 07:13 AM
Tidy..very tidy indeed.
How is the power and torque....has that cat actually got internals? Highly illegal here(removeing internals), although they block up and just restrict you motor after a while.
Matt
subaruboxer - July 30th, 2005 at 05:28 AM
Hi Matt,
wasn't able to get on the dyno again with the new clutch.
The cat is the stock Subaru unit. I'd like to see pics of your exhaust.
Jörg
1303Steve - September 19th, 2005 at 04:33 PM
Congratulations, that looks so nice, it looks like the factory did it, not sure which one though, the on in Germany or the one in Japan.
subaruboxer - September 20th, 2005 at 04:35 AM
Hi Steve,
thanks I hope it will work as good as it looks. Will hit the dyno again in two weeks and the Autobahn for topspeed testing, too.
Jörg
lugnuts - October 16th, 2005 at 08:15 PM
Hey subaruboxer dont forget the sleeper-look !!!!!!!!
subaruboxer - October 17th, 2005 at 02:32 AM
Hi lugnuts,
I won't forget it. Now that I had a chance to ride, I know what I want to change over the winter. One thing is the exhaust, I will probably build a complete new one without the catalytic converter and the fake exhaust tips. I tried the smaller muffler, but it was to loud. Have another muffler that I want to try with this header, with that one I could install the fake exhaust tips.
[ Edited on 16-10-2005 by subaruboxer ]
VWSyncroguy - November 8th, 2005 at 08:38 PM
How is your muffler supported at the back....is it mounted tothe engine somehow ...or to the frame of the car??
Warren C.
kombibob - November 8th, 2005 at 09:15 PM
sorry i just had 2
subaruboxer - November 9th, 2005 at 05:47 AM
Warren C.
Hi Warren,
the muffler is hanging in those rubber things, I dont know how you call them ( in English). You can see one at the exhaust tip of the larger muffler above. And mounted to the car.
Jörg
[ Edited on 8-11-2005 by subaruboxer ]
kombibob - November 2nd, 2009 at 08:05 PM
Just stumbled across this while doing some subi research and had a laugh
forgot about it.. lol
so bump
mactaylor - November 4th, 2009 at 05:33 AM
that is funny!!!!
Joel - November 4th, 2009 at 02:34 PM
i was gonna make one similar but those stock cats are pretty restirictive
colonel mustard - November 4th, 2009 at 02:44 PM
How much does that heat wrap help? could you use it on extractors?? with decent effect/result?>
trickysimon - November 4th, 2009 at 02:52 PM
It rusts out your exhausts alot quicker as it traps moisture. Also turns stainless brittle like glass.
