Hi all Philbert has had little work done to it since adam helped me get it started, but when it starts it runs for about 6 secs than stops. also it
seems like it is giving me a code for the throttle position sensor (3 slow and 1 quick) but the TPS seems to be giving of the right readings.
Been given the time line of 3 weeks to have it running properly for a photo shot so any help would be great
Andy
Had a similar problem with the 2.5 after engine install. Turns out to be fuel pump earthing problem.
Just enough fuel to start when key first turned and pump pressures up.
So did you just try and get a better earth? WHat sort of power should you be getting to the fuel pump when the engine is running for the whole 6 secs?
Its doing my head in
Andy
Hmmm, thinking again it may not be your prob?
Has this been happening since the conversion? Or has it been running Ok up until now?
I had 2 pumps and it was the lift pump to the surge pot that
was not earthed correctly.
The primary pump which feeds the engine was operating but trying to feed from an empty surge pot.
Does it run roughly?
A squirt of engine starter into the intake when you start it, if the engine continues to rev then its fuel. This is how Tony from Rigoli Performance
found my problem, all in about 30 seconds!
I also has plug fouling at one stage which dropped cylinders out when trying to idle.
Tried an ECU reset?
sounds like the fuel pump or AFM.
Pull your return line off you tank and run it into a bottle and watch it when it starts up. If your pump is working well then it should keep filling
the bottle when it runs.
If is is running for a few seconds and your fuel pump is not the issue then I would be checking your AFM, the fault code for them on the EJ22 is
pathetic and more often than not does not thow one. A faulty AFM will give the issues you mention as the ECU will think it is not running when it does
its check after starting, no AFM signal tells ECU no air so it needs no fuel and stops.
I'm re mounting the fuel pump at the moment so i will check the fuel pump tommorrow and if thats not the problem then i will check the AFM i did get
it for $1 because the one that i got with the wiring loom was different to what the loom has on it, bit weird becuase it is all supposed to be from
the same engine.
I think that i read some where that the only difference between the 4 and 3 pin AFM is that it gives out a zero reading? c what happens tommorrow
Andy
There's an AFM her you can try if you want....
That would be great!!! I'll pm you
Quote: |
yeah my mistake got the AFM and the TPS mixed up. the air flow meter has 5pins and the TPS is 4
The other AFM that i have is 3 pin.
Quote: |
Yeah the engine that i got came with a 3 pin AFM, which the same as you i was a bit confused, but i now have a 5 pin.
The TPS is 4 pin and the o2 sensor is well just an o2 sensor. I really should read through my posts a bit better before i post them (and not do it
while I'm watching hackett swim his 1500m )
Checked the fuel pump today after remounting it and it is pumping out fuel via the fuel overflow, so it would seem that the pump is good and getting a
good signal.
MickH said that he had an AFM that i could try so i might take him up on his kind offer tommorrow.
ANdrew
I'll be home...gimmee a ring!!
well after MickH was good enough to let me borrow half an engine!! to check to make sure that it wasnt my components, I thought that i better plumb in
the Idle air control valve (IACV) and blank up one line into the manifold and guess what the bloody thing runs properly!! even with my stuff hooked
in.
So now i have to figure out how the COR throttle cable thing fits!!
thanks for all the help
andrew
No worries...happy to help! Now get it on the road......
hehe so you had air lines down wind of your AFM open to atmosphere ??
No wonder the poor thing didn't want to run, happy to see hear you got it working .
Hey Andrew if you need a hand this weekend coming give me a call, Ill PM my mobile number as we have the other house on the market for sale. Currently without internet and landline access at new place. Good to hear its running again.
Hey Andrew,
Great News on the engine running.
I need to do that to my engine too could you post a picture of your plumbing on the IACV?
Cheers,
Richard
Hey Richard, you dont want to see what i've done for the moment but i
here is a picture of hellbus's one that i am going to try and copy. I'll probably have mine stainless cause i can get hold of it pretty easy and I
cant weld plastic. Not sure if you can buy these but if you can i think that i would get one.
Andrew
Quote: |
i think that with there price revisions i wont be able to afford one from there,but it would be interesting to see how much they are
Quote: |
Thought that i would wait to update till i got the raditor, well got the rad with thermo, its rated to 1900cfm so it should pull enough air through
it.
Header tank is finished and it sure holds a fair bit of water.
Made up the throttle body spacer, just big enough to do the job.
I'll finish painting the rad frame tommorow and mount everthing and hopeflly be able to drive the car onto the car trailer!!! getting a little bit
sick of pushing it everywhere
so now to get the engine mount finished (mach 2) and the exhaust
Hey Andy...that looks very much like the one i made heheh...you're nearly there
[img][/img]
Hi i was wondering if anyone had a problem with their gearbox locking up, i went into reverse and tried to go into 1st and nothing just a jammed gear
lever. Any way to get it unjammed easy. or should i just cut away the 1600 box andtry and get a 1800/2L box?
Any peoples experience would help??
Andy
Andy what time do you finish work? I could come and have a look this arvo or tomorrow. If you like give me a call on my mobile.
Quote: |
Yeah there is oil in it, not dumb at all been a little bit absent minded lately and i even double checked. At the mo it seems like the consensus is the shift forks could be the problem so out with the box and engine again and see what happens.
sorry mate, that sux
Quick update, did have pictures but the camera packed it in. Have a new box,5 rib and managed to get it in yesterday, I can actually get gears
now!!
Engine crossmember is finished and the guys at worked even did some nice art work on it i will get some pictures and show you all.
My question to you all is that if the engine is idling a little high what could it be? I think that i have all the line hooked up but I think that i
might have missed something is there anything else that i could try?
thanks
Andrew
