New Horizontally opposed Ecomotor 100mpg
matara - March 2nd, 2010 at 05:57 AM
Just stumbled across this on the net, but you can see the developers work on the beetle engine in this design. Over 100mpg and twice the power of a conventional engine from a two stroke engine! Even has an electric version of a turbo/supercharger.
[img]http://image.automobilemag.com/f/31686174+w750+st0/0912_01_z+ecoMotors_OPOC+eM100_testing.jpg[/img]
[img]http://image.automobilemag.com/f/31686171+w750+st0/0912_02_z+ecoMotors_OPOC+eM100_testing.jpg[/img]
http://www.ecomotors.com/files/eturbo2_0.jpg
Here is the link
pete wood - March 3rd, 2010 at 09:25 AM
those secondary connecting rods would be doing it tough. what's the rev range on that?
bajachris88 - March 3rd, 2010 at 01:04 PM
Pretty innovative and ingenious. and they are right on teh money with the fuel efficiency and power.
But they claim it to be a green engine, however don't highlight how the design overcomes the environmental concerns that are typical of a 2 stroke (oil/pollution/emissions)
Unless the whole green label is ignorant towards that and refers to the fuel consumption. I'm sure they would have looked into that though (emissions).
Does anyone have any more info about that?
gerrelt - March 6th, 2010 at 05:22 AM
Cool engine!
Allthough It will be pretty wide, I think.
It's roughly the same idea as this opposed piston two stroke diesel engine:
http://www.amt.nl/upload/179560_657_1263481903590-achates-motor-2.jpg
http://www.amt.nl/upload/179562_657_1263481969894-achates-motor-3.jpg
http://www.amt.nl/upload/179568_657_1263482055674-achates-motor-4.jpg
More here: Achates
jamiec - March 10th, 2010 at 02:52 PM
bajachris88 most two stroke engines other then small ones like lawnmowers wiper snippers etc have a wet sump just like 4 stroke engines so they don't inject oil with the air fuel mix so no oil burning. i guess this engine would be the same.
Snap Crackle Bang - March 10th, 2010 at 09:58 PM
This looks like a variation on the "Commer Knocker" arrangement. The Commer was a British made truck with a 2 stroke diesel engine that had 6 pistons, but 3 cylinders. (Might be able to get cheaper rego because there are only 3 cylinders!) The advantage is that the inlet is at the opposite end to the exhaust, so very little fresh charge escapes through the exhaust ports.The Commer engine had connecting rods that connected to levers that connected to the crankshaft. Not built for revs! There was a German truck engine which had a similar arrangement but with twin cranks connected by gears. Elegant but expensive.
waveman1500 - May 21st, 2010 at 01:01 PM
Amazingly, from what I have read about it I believe that the reduction in RAC horsepower rating and hence road tax was in fact the main reason for developing the engine!
rocknrob - May 21st, 2010 at 04:42 PM
My Dad used to haul coal in central QLD in the late 50's and the "commer double knockers" were famous because when they blew shrapnel went everywhere...of course these trucks were massively overloaded and overworked
pete wood - May 29th, 2010 at 10:21 AM
a whole lot of parts for not a whole lot more power really. the sarich [orbital] 2 stroke is a much more efficient design parts wise. Remember, less moving parts is the key. That's why rotaries work so well. The SIDI holden motors are an offshoot of that stuff too. Direct injection petrol motors. The difference with the orbital design was that it used a supercharger to create inlet pressure. Zoom magazine did a write up on a bmw 3 series powered by one of the testbench orbital 6s and it was apparently very impressive. It wouldn't be hard to turn a VW 4 into a dry 2stroke. I've thought about it often enough. Half the parts are available from motorbikes. Then just make up some generic heads and throw on a supercharger. Once the SIDI technology takes off in other cars, fuel pumps and the like will be easy to come by and you could build a really hot flat four that's smaller and a lot revier.
1303Steve - May 30th, 2010 at 10:10 AM
I went to demonstration of new sort of motor in Sydneys west a few years ago, it was based on a Subaru flat 4, I think it was called Revertec or something similar. The people made all sorts of claims about power and effeiceincy, it looked similar to one Matara posted.
The motor used Haltec injection, coincidently Haltec now occupy the same building that Revertec were in .
pete wood - June 8th, 2010 at 10:04 AM
I think the revertec had a scotch yoke setup with the pistons joined together.
General_Failure - June 16th, 2010 at 01:26 PM
The revertec was a Bourke Cycle engine?
pete wood - June 18th, 2010 at 08:01 AM
if by that you mean that the opposing pistons move in the same direction at the same time then the answer is yes. Because the scotch yoke joins them together, as one goes out the other side must come in and vice versa. VW/Subaru boxers have a crank config that means the opposing pistons go opposite directions at the same time. Both out, then both in.
General_Failure - June 19th, 2010 at 08:38 AM
Partially yes. Unless I misread was it being said that the revertec motor used a Scotch Yoke and 2 stroke, non oil butning technology?
Anyway, for those of you who couldn't be bothered:
http://en.wikipedia.org/wiki/Bourke_engine
I should mention in spite of what that wiki says, there are Bourke motors out in the wild. Some are still functioning too. i think they were used on generators, big saw, that kind of thing. I have always wanted to put one of those wonderful, strange motors in my bay. However with the machining technology I possess I can't even drill a hole straight let alone fabricate a motor.
HappyDaze - June 19th, 2010 at 09:47 AM
The Commer 'Knocker' earned its nickname from the dreadful knocking noise that the engine produced, especially when worn. You could hear them 'knocking' long before the exhaust was heard.
