Subarugears Pinion Depth Tool for DIYers
Subarugears - October 27th, 2012 at 06:00 PM
For those customers wishing to set up their own reversed Subaru transmissions, a Pinion Depth tool is needed in order to set up the initial location of the pinion gear in the case.
The pinion depth tool locates into the transmission case half and the wedge is slid between the pinion gear head and the depth tool. Appropriate shims are added behind the pinion retaining bolts until the wedge reads zero.
The Subarugears Pinion Depth Tool is CNC laser cut and etched from high quality acrylic to assure perfect location and measurements every time. Subarugears has tested this tool extensively with its own transmission builds.
Previously, customers would have to order an expensive OEM tool for around $300 shipped, with 2 weeks wait time. Subarugears now provides this tool FREE OF CHARGE with every reversed ring and pinion / rear drive conversion kit. Pricing without gear purchase is $80 including worldwide shipping.
http://i1169.photobucket.com/albums/r520/subarugears/Pinion%20Depth%20Tool/PinionDepthToolleftLowRes.jpg
