WPVW turbo oval progress - 443bhp (10.13@139.70mph)
hypo-vw - March 19th, 2005 at 06:00 PM
with the compak attak drag meeting postponed until the 9th April , this gives us around 3 weeks to have the oval ready . the pics posted are about a week ago , so there has been further progress .
It may be a big ask , but we a hoping to run high 10's and 130mph with this fully engineered and street regeristed bug .
will keep you informed when up and running !!:jesus
[ Edited on 14-1-07 by hypo-vw ]
[ Edited on 21-2-07 by hypo-vw ]
hypo-vw - March 19th, 2005 at 06:01 PM
oval with rear firewall section cut out to accomodate the turbo engine
hypo-vw - March 19th, 2005 at 06:03 PM
the 2.9 litre type-4 turbo injected engine
pod - March 19th, 2005 at 06:03 PM
cool as , looks like youve got a job and a half on your hands
hypo-vw - March 19th, 2005 at 06:04 PM
the alloy front suspension beam
hypo-vw - March 19th, 2005 at 06:05 PM
the wastegate , blow-off valve and the T-60 turbo with split exhaust housing
hypo-vw - March 19th, 2005 at 06:07 PM
the 4" inlet on the T-60 turbo and the 48mm wastegate
hypo-vw - March 19th, 2005 at 06:08 PM
the WPVW modified watercooled intercooler with 3" inlet / outlet
[ Edited on 27-8-06 by hypo-vw ]
Chewy - March 19th, 2005 at 06:10 PM
Hey Hypo Vw is your name Mark Gottwalt by any chance??
hypo-vw - March 19th, 2005 at 06:12 PM
no sorry , Wayne Penrose of WPVW
boersch - March 19th, 2005 at 06:25 PM
that's gonna be insane :D keep us posted!
11CAB - March 19th, 2005 at 08:34 PM
Nice setup, any more pics?
VWFOOL - March 19th, 2005 at 08:38 PM
very exciting!
Adolph - March 19th, 2005 at 08:43 PM
Hi Wayne.
Would you mind sharing the specs of the type 4 engine with us?
How much boost, power,G-box,size of slicks,etc?
Looks great!!!
Hermann
Flintstones - March 19th, 2005 at 08:52 PM
so what happen with the air to air intercooler that you were originally going to use?? what changed...
keep up the great work and keep us posted on the progress!!
hypo-vw - March 19th, 2005 at 10:45 PM
I decided to modify the air to air intercooler to a water to air type for several reasons . First was the issue of how to get enough air through the intercooler without having the engine lid open up to 300mm ( I want the oval to look pretty stock ) Second was when drag racing , you are stationary at the lights with no air flow through the intercooler ( I had planned to fit a thermo fan but dont know how efficient it would have been , and with the amount of plumbing involved didn't want to have to do it the second time over ) when you launch from the lights the intercooler wouldn't be very efficient until speed is reached . Third , I am able to mount the intercooler inside the cabin away from the heat of the engine and turbo . Fourth , I am able to add ice to the coolant to make it even more efficient from a standing start without any fluid spillage onto the track surface . The only down side to all of this is the additional weight I will be carrying with the coolant / reservoir / electric water-pump , but I am sure the added horsepower will offset this .
hypo-vw - March 19th, 2005 at 10:48 PM
the electric water pump kit to pump the coolant through the intercooler
LOWBUG - March 20th, 2005 at 04:43 PM
Is this going to be a street driven car?
hypo-vw - March 21st, 2005 at 06:10 AM
100% street driven on premium ULP . I am currently working on the compression ratio of the 2.9 engine trying to get it down to 6.95:1 . I have also purchaced a Turbosmart 2-stage boost controller , so with the flick of a switch on the dash can change from 8psi boost to 22psi instantly . So when used on the street it will run on 8 psi .:jesus
Dasdubber - March 21st, 2005 at 08:25 AM
Great stuff Wayne, I look forward to seeing further progress and anticipate some great things for the type IV lump! A high 10sec street beetle would be insane to put it lightly!!
HotRodMatt - March 21st, 2005 at 08:53 AM
What have you done with the heads Wayne? Type 4 heads flow like meatloaf through a sieve. Gonna need tremendous flow for a 10 second car.
Turbo54 - March 21st, 2005 at 12:48 PM
Hi Wayne,
I have spoke to you before about the turbo 2165 I am building.
I am Adam and Peter's friend. Is the water pump your running a Davis Craig?
What model is it? I have a similar setup in my car. I have a cool tank mounted behind the back seat and that runs through the plenum / intercooler in the engine bay and then down to the front beam where I am mounting a small radiator w/ thermos and then back to the cool tank. Do you think this will work, it is similar to Adam Deb's car but he was running a fuel pump to pump this? (I want to cut the least amount of holes into my car body as possible)
Have you thought of a shot of CO2 through the manifold while it is on boost. I was thinking of building something like this out of a paintball gun and some gas fittings, but i'm not sure what the men in blue would say about the gas venting into the atmosphere.
Heath
Turbo54
hypo-vw - March 22nd, 2005 at 06:52 AM
can't post any pics of the heads as they are already on the engine , but following are a couple of pics of the heads on the tow car ( my 2.5litre 77' dualcab kombi ) As you see these heads will flow a little better than you described . Keep in mind the heads pictured have been modified with 44mm inlet valves and 37mm exhaust valves ( this is why our dualcab can cope with towing that humungus enclosed trailer with 'mango' inside it , approx total weight 3800kgs ) The heads on the 2.9 engine have been modified with 48mm inlet valves and 38mm exhaust valves , and the ports are much larger !!:jesus
hypo-vw - March 22nd, 2005 at 06:53 AM
exhaust port
vw54 - March 22nd, 2005 at 07:10 AM
Wayne
You had better apply for an ANDRA licence if you intend going that quick.... and also a full ANDRA teck inspection.
vw54 - March 22nd, 2005 at 07:11 AM
thats a nice bit of work on the Intercooler..... did you do it yourself or is it a bought one.... looks great how big a radiator will you need to cool the water ???
hypo-vw - March 22nd, 2005 at 10:15 PM
Originally posted by vw54
Wayne
I anticipated that I would have to do this Dave , but I will get the oval to the track first and make sure it goes straight and fast . If it runs under 11.00 the officials will advise us not to return until a ANDRA full tech inspection and licence is obtained , and then I shall do as they ask . Thanks for the advise though .:jesus
hypo-vw - March 22nd, 2005 at 10:22 PM
the electric water pump is a Davis Craig unit that costs around $185 . I am not familiar with the type of cooler that you are running in you inlet manifold , but if it is the same type as Adams then it must work as it appears to be working for him .
hypo-vw - April 7th, 2005 at 12:05 AM
over the past couple of weeks we have slowed up on the oval as it was quite evident that I was not going to make it to the compak attak which is on this weekend ( april 9th )
the body work is nearly completed with all of the panels fitted . it requires a final rub prior to paint .
hypo-vw - April 7th, 2005 at 12:06 AM
