WTB..Original bog stock standard rocker covers.
Gazza265 - February 27th, 2010 at 06:40 PM
Hi guys and gals, It has been reccomended to me that I buy a set of original stock rocker covers to help solve the leak problem. So if anyone can steer me to where I can find a good used set..or even reasonably priced new ones...I'd be happy to receive your suggestions.
The motor is a 74 1300 block with 1600 barrels and twin port heads.
pod - February 27th, 2010 at 09:58 PM
i will have a look out the back ,should have a couple you can have ,just pay the post:tu:
Gazza265 - February 28th, 2010 at 01:04 PM
Thanks for that Paul. mucho appreciato....
pod - February 28th, 2010 at 07:16 PM
yep,got 2 for you will need a sand and paint as have surface rust on outside ,they came off my 1600 in my bus which had been sitting 6 yrs
Gazza265 - February 28th, 2010 at 07:28 PM
Thanks for that mate...I have PM'd you I think...
68AutoBug - February 28th, 2010 at 09:59 PM
check Your spring bails that hold the tappet covers on..
they should be very difficult to push up or down...
they can be replaced or bent back into shape...
mine are very difficult to push on or off... lol
You can also buy chromed ones...
how good they are I don't know..
but chromed tappet covers hold the heat..
VW used them back in the 50-60s in Scandanavia etc..
to help keep the oil hot...
