Ko204
shep1969 - June 1st, 2013 at 09:15 PM
Hello i'm a new member to the forum
I have just acquire ko204 it has no motor and is in need of a fair amount of body / rust repair 2x floors to start with.
I have been searching older posts and have a couple of questions
where could I find info /pics of a rear seat setup as somewhere it is mentioned that a rearseat was an option
could I register the buggy in qld as a 4 seater without major dramas
Thanks for your time Paul
newghia - June 2nd, 2013 at 07:11 AM
Country buggy Bill is the person who can assist you.
Look for him under the country buggy section, was also involved in Berry Blast, so you may find posts from him there.
He will probably chime in here when he see's your post,
Nath
58camper - June 2nd, 2013 at 09:05 AM
Paul,
Welcome to the world of the Country Buggy. Its an odd place to be and many of the CB owners are just a little "out there".
Good to see that KO 204 has surfaced again from its temporary resting place in Pittsworth Qld.
I have attached a photo of a rear seat which might help you. I am no expert on QLD vehicle registration rules but do know there are a number of CBs already registered up there so getting another one should not be a major issue. In NSW we would need to satisfy the Inspection authorities to get a "blue" slight which means an unregistered vehicle has to go over the pits for inspection. You would need to know the QLD requirements as this vehicle has been out of registration for many years as I recall.
If you need anything send me an email to countrybuggybill@hotmail.com as I usually know where bits and pieces can be sourced.
countrybuggybill
shep1969 - February 16th, 2014 at 08:13 PM
Finally had a chance to remove the body
looks like i have a lot of work ahead
just a few picks of what i found
Cheers Paul
BrisDubba - February 16th, 2014 at 10:20 PM
Whereabouts are you located ? Mine is registered as a four seater if you need ideas - though it appears you have a bit of work ahead of you.
Peter
KO200
shep1969 - February 16th, 2014 at 10:35 PM
Hi Peter,
I live at Laidley out in the Lockyer valley
I'm trying to workout the best way to go with the buggy
At least with the body off I have more idea of what's needed
