[ Total Views: 1972 | Total Replies: 2 | Thread Id: 106005 ]
Author: Subject:  Switch removal?
Membertan36
Threads: 17
posted on May 10th, 2014 at 06:33 PM
Switch removal?
Hi everyone, finished removing most of the wiring under the bonnet today, but can not work out how to remove the switches inside the car. Eg hazard lights, wipers etc. they are the pull out push in ones 1970 beetle. Thanks :)
Super Administratorbarls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 295
posted on May 10th, 2014 at 07:18 PM
depending on the switch the knob screws off then there is a nut that requires it to be unscrewed using ether the proper tool or a pair of needle nose pliers and then they just pop out.
the different ones are the fresh air box ones they just pull off.
the chaos project - click me
Membertan36
Threads: 17
posted on May 10th, 2014 at 07:21 PM
Thanks, mine where stuck up really really tight so where not screwing the top part off so that had me at a loss, but got that bit off will have a go at other part with the needle nose tomorrow.
[ Queries: 40 ] [ PHP: 22.5% - SQL: 77.5% ]
