[ Total Views: 2383 | Total Replies: 5 | Thread Id: 106816 ] |
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on August 8th, 2014 at 04:49 PM |
Beading Tool
This is some thing I have been working on for a while. I find with conversions you need to be able to get a bead on the end of pipe work to help keep
hoses on.
Made this from a standard scissor jack(VS Commodore) which had been damaged. The shafts are from alternators, as are the bearings and the spacers
between them. The forming roller is just another spacer which was let spin on the shaft as I ground it to profile(watch you fingers it get hot while
you profile it). The ring which holds the former on is from a beetle generator, it has an interference fit on the shaft.
This is Mark 2, is has internal bracing to stop the forming roller from trying to pivot away from the work piece. The small tubing is 32mm stainless
tube 1.6mm wall thickness, I previously had to anneal the tubing and it was still a difficult job. Now it breezes through it.
Quote of the week
matberry
posted on August 8th, 2014 at 08:01 PM |
Nice work
vduboy
Threads: 41
Mood: Dying to get more buggy building time..
posted on August 8th, 2014 at 08:21 PM |
Very nice! I love hand made tools, I have a whole drawer full at work for bike stuff.. pity I can't remember what they all are for!
It will all be OK in the end, if it's not OK it's not the end!
vlad01
Mood: Side ways
posted on August 11th, 2014 at 07:43 PM |
That is so awesome. Been looking for a tool to do exactly that. Seen another person make one for 5/16 and 3/8 tube which uses a ball bearing from the
inside of tube to make the beading.
71 notchback,
nils
Threads: 65
posted on August 12th, 2014 at 05:50 AM |
Sweet, I was going to us the work one. But it seems its just a easy to build your own. Thanks for posting.
And cheers for those parts
Quit calling rust patina
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on May 1st, 2016 at 06:00 PM |
Fixed up my original prototype today with the internal brace, so decided to put some addition photo up that are a bit clearer.
Quote of the week
