Please remember all sales are as per your local state or territory's Fair trading act.
Linking to an external auction or prize is fine in this sub-forum. However, we can't handle auctions or prizes using this software as we don't
have that functionality
Please don't spam the forums.
Please describe the goods accurately and fairly, preferably with pictures.
[ Total Views: 1197 | Total Replies: 2 | Thread Id: 107892 ]
Threads: 3
posted on December 14th, 2014 at 11:26 AM
You would have to spend quite a bit of money on that system to make it operational again.The hoses would all need replacing,the compressor would need
an oil change,plus a new shaft seal (assuming they are still available),and the reason for all this,is the fact that the refrigerant this system was
running on (R12) was phased out years ago,and its replacement,(R134A) requires a different oil for lubrication (Polyol Ester Oil),as the old mineral
is not compatible with R134A because it will not mix with it.The downside of Polyol Ester oil,is that it acts like a solvent in old systems,removing
old built up grime and residues causing blockages in the system,but the major problem is it turns rubber into a black mush,hence the need for new
neoprene based hoses and shaft seals.I noticed in Joels link that they have changed the compressor from the old reciprocating compressor to a
rotary,which is a good move,as those old York,and Techumseh compressors were also used on Ford Fairlanes and LTD's,and were quite capable of running
a small walk in cold room,so very much overkill for a VW.
So nutshell whoever purchases it will be up for another $500-$1000 to get it to do its thing,Joel's option is much more viable,if you want Air
Conditioning.
