[ Total Views: 3029 | Total Replies: 13 | Thread Id: 110594 ] |
psimitar
Threads: 148
posted on February 20th, 2016 at 10:25 PM |
Spray booth time for base and clearcoat - Brissy Northside
I was just wondering if anyone knows an automotive painter on Brissy Northside that is willing to shoot the base and clear coats of a fully block
sanded Bug?
Also at a reasonable cost not over $1k, more like $500-600 for the booth time it takes, if I'm supplying all materials and help with the masking.
Pm me if you know anyone.
Cheers,
Mike
helbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on February 21st, 2016 at 05:29 PM |
Booth hire is normally $500, so the painter who is "shooting" the paint will want something to make it worthwhile. You will have to think in the $1K
range minimum.
psimitar
Threads: 148
posted on February 21st, 2016 at 09:40 PM |
Quote: | Originally
posted by helbus
range minimum.
I used to do this when I were a lot younger and for the time it takes to spray and bake the base and then clear makes it no more than a $1K all up,
especially if I'm helping.
Also, $1K is the most I can afford as been out of work with chronic back pain for over a year and the government are no help what so ever in helping
you get better to return to work.
adlbeetle66
A.k.a.: Denver
Under the car.........again!
Threads: 98
Mood: ICH BIN VW NUSS
posted on February 22nd, 2016 at 06:53 AM |
I had a mate at the Sunshine Coast who had it Dat 1200 ute painted for $400. Great job. He supplied all materials and masking, the painter just
painted !
bushed
Threads: 66
posted on August 29th, 2016 at 10:47 AM |
Dattos 1200 are mini cars, so mini cost
hows the back Mike?
psimitar
Threads: 148
posted on August 29th, 2016 at 10:53 AM |
Quote: | Originally
posted by bushed
hows the back Mike?
The backs OK mate. Getting better. Now the Oval's finished I'll have more time to work on my health and fitness
bushed
Threads: 66
posted on August 29th, 2016 at 12:01 PM |
If you ever go to Gympie let me know
the chiroman there
a science teacher is a miracle worker ...mostly one treatment...I used to drive 100kms to get healed.
teaches some prevention and self help too.
psimitar
Threads: 148
posted on August 29th, 2016 at 12:28 PM |
Quote: | Originally
posted by bushed
the chiroman there
I'm moving down to Melbourne in a few weeks Bernie but thanks for the info.
Chiro isn't quite so good for me due to the damage I have but exercise is the main thing to help with my injuries.
tonytyga
Threads: 9
posted on October 17th, 2016 at 07:30 PM |
Hi Mate ,
maybe im too late with my reply but I recently got quoted $200 a day to use a booth in North Brissy
Tony
psimitar
Threads: 148
posted on October 17th, 2016 at 10:02 PM |
Quote: | Originally
posted by tonytyga
Hi Mate ,
Tony
Wow, that's pretty good. If you end up using it yourself just make sure the lighting inside is good. Otherwise you struggle to see the wet edge and
run into problems
As for me, I finished the paintwork back in March but thanks anyhow
tonytyga
Threads: 9
posted on October 19th, 2016 at 08:31 PM |
Thanks yeah, i will check it out in more detail ...........to be honest ....Im not really confident to spray the car myself but i will give it a go if
i have too !
Currently looking at estimates of a pro job .
psimitar
Threads: 148
posted on October 19th, 2016 at 09:53 PM |
Quote: | Originally
posted by tonytyga
i have too !
The money is all in the prep mate and that's the easy part. So long as you have a good feel for undulations in bodywork. You can buy a pretty good
set of sanding blocks on Ebay and so long as you coat bare metal and bondo in an epoxy primer, to protect from moisture, then it's just sanding.
I found a guy in Oxley that would do the spraying for $800 but his booth wasn't heated. Still shows you that you can just get the base n clear
sprayed without shelling out a small fortune on the prep work cos the paint guys know this is where the money is. Base and clear takes little more
than an arvo to lay down with a heated booth.
Things like masking can take a full day and that's $1000 if they charge at the normal hourly rate. $1000 for masking up?!?!?!?!?!?
tonytyga
Threads: 9
posted on October 21st, 2016 at 03:18 PM |
Im cool with the prep work mate ....done a fair bit of diy over the years ..my problem is .... im working in a single garage in an integral unit so
neighbours may object if i start gasing them out with 2 pac toxins !
Body shops wont warranty apparantly unless they prep (so ive been told )
The booth in Nundah is available but ive never laid 2 pac down and i want a good job on my 60 bug daily driver .
More contacts are now coming up through the forum so ill make an informed decision when the quotes come in !
psimitar
Threads: 148
posted on October 22nd, 2016 at 10:34 PM |
Quote: | Originally
posted by tonytyga
Blah blah blah. That's just an excuse cos they can do a cash in hand job plus if it's all the same paint system and the primers degreased then any
base and clear adhesion problem is down to them. Anyway, they bug me.
I did find a guy in Warner with his own booth. Found him on Gumtree along with the dude in Oxley.
Good luck and shame about your garage. Still, as I said you need really good lighting. The colour is pretty easy to apply as you can see the wet edge
against the primer. The clear is much harder to see if the lighting isn't good.
