[ Total Views: 1660 | Total Replies: 9 | Thread Id: 110628 ] |
Whitty
Threads: 27
Mood: so happy I could shit
posted on February 28th, 2016 at 08:35 PM |
175/60/15 = ???/??/14
Team,
Got a 72 super on lowered struts running a 175/60/15 on a 214 replica rim. Good setup, does rub slightly at full lock but otherwise ok. Getting a set
of old school 14 inch Globe rims because they are cheap and handy to me, and I used to have some on another super so bit of nostalgia there. Anyway,
all the tyre resize calculators i can find want to go up a size, not down, so i am having trouble finding a size tyre to match up rolling size i have
on there at the moment. Globes have 185/75/14 tyres on, obviously no good to me. Anyone able to help??
Bizarre
Threads: 730
posted on February 28th, 2016 at 08:41 PM |
try this?
http://www.tyresizecalculator.com/
says 195/60/R14
Might be a bit "baggy"
vwo60
Threads: 71
Mood: good
posted on February 28th, 2016 at 09:13 PM |
Will the offset work on the front of the superbug, I remember see these wheels always outside the edge of the guard.
STIDUB
Over it.
Threads: 57
posted on February 29th, 2016 at 01:34 AM |
http://www.willtheyfit.com
Volkswagen Drivers Club of Queensland - member
karmann141
Threads: 47
posted on February 29th, 2016 at 12:12 PM |
Don't get the Globes, even if they are cheap. The only thing right about them is the 4X130 PCD. They are totally the wrong ET and they will stick out
beyond the standard guard.
With the correct ET +50 x6" front and +40 x7"rear (Boxster 16's) as an example will fit inside the standard guards without rubbing and you could
run a 205/55 front and 225/50 rear.
Most of the oldskool 4x130PCD wheels are the wrong ET for the car.
1961 K Ghia - Porsche 5 sp, EJ20T, Brembo's, Dble A arm susp
1974 L Bug - Porsche 944 brakes, Boxster 16's
1974 Bay Camper - EJ20, twin radiators, Boxster 16x7's
Half Beetle trailer with Boxster 16x7's
2011 Tiguan TDI 4Motion
2010 LR Discovery 4 TDV
modnrod
Threads: 50
Mood: Old School Volksies!
posted on March 1st, 2016 at 10:59 AM |
175/60r15 = 591mm tyre diameter (175mm x 1.2, add 381mm for 15").
175/70r14 = 600mm diameter (175mm x 1.4, add 355.5mm for 14").
You get the idea.
helbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on March 1st, 2016 at 09:52 PM |
You can get 175/70/14 or 175/65/14 cheap brand Fullways for as low as $55 a tyre. It is the offset of the rim that makes the difference
1303Steve
Threads: 556
posted on March 1st, 2016 at 11:26 PM |
the bottom of the ball joint often scrapes on 14 inch wheels on 3 bolt supers
Whitty
Threads: 27
posted on March 2nd, 2016 at 12:07 PM |
Thanks all, something to think about. Unfortunately Porsche Boxters are pretty thin on the ground in central Queensland, so you have to grab what you
can, when you can, and the globes were cheap and accessible. Might have to wind up the front and back a touch to fit them under.
karmann141
Threads: 47
posted on March 2nd, 2016 at 07:39 PM |
At the end of the day it's your choice.
The biggest problem with air cooled VWs in my opinion is the restrictive 4x130PCD.
The best thing you can do is a Pcd change to popular modern cars eg 5x100 or similar. This opens up a world of cheap factory and aftermarket wheels
with the correct ET. Your car will look great with wheels filling the guards, better choice of tyres, better handling etc etc. In my opinion wheels
make the car and nothing looks worse than a wheel even smaller than the factory diameter and a high profile tyre (unless on a buggy) but it's your
car, your choice.
We only used Globes etc in the old days because we had no other choice.
