[ Total Views: 1793 | Total Replies: 3 | Thread Id: 111387 ] |
donn
Threads: 428
Mood: LAID BACK AND CONFUSED
posted on August 5th, 2016 at 11:37 PM |
Problem with 79 kombi door
Had a bit of a mishap with my kombi today, the sliding door actually came totally adrift from the body and landed on the ground, I've rectified (
sorta 🙄😳 the damage which was minor and sourced a
replacement bottom runner as I found the one on the bus was missing a bearing, I've managed to get the door back on but am unable to open it as the
rear hinge U piece isn't able to swing out enabling the door to run past the body, I'm thinking that it was somehow "rearranged" when the door
came adrift but can't see how to rectify the problem. Any one else out there had this problem and can give me any hints on how to overcome it?
Don
bushed
Threads: 66
posted on August 13th, 2016 at 02:21 PM |
you need a helper pulling with a hook into the far end while you try the handle and force it.
Failing that someone thumping it from the inside on the stuck edge
unbolting the catch from inside will help reduce the jambiing
a pic may help to show if the door closed incorrectly onto the front lock
lightice
Threads: 3
posted on August 19th, 2016 at 12:49 AM |
The hinge piece that has the roller bearing has a hook that catches once the U hinge moves past a certain point.
Remove the track cover, look near where the U hinge goes through the roller bearing carrier and you will see a spring and 2 flat metal pieces.
The lower piece is the one that locks the roller carrier into place.
Push the back of it, then force the U hinge back and you'll be able to move it back into position.
I'll add in a picture tomorrow to give you an idea, without photo editing software right now.
donn
Threads: 428
posted on August 27th, 2016 at 05:28 AM |
All good now thanks, now works better than ever.
