[ Total Views: 1515 | Total Replies: 4 | Thread Id: 113838 ] |
hulbyw
Threads: 130
Mood: I'm OK, RU?
posted on August 14th, 2020 at 10:43 PM |
Slowing Down Rust Inside Beetle Sills
Is it worthwhile spraying any liquid inside the sills to slow down rust that can be seen on the heater channels and if so, what do I use? Cavity wax?
Deoderised fishoil? Lanolin? Anything else? Or am I wasting my time.
vw54
posted on August 15th, 2020 at 07:13 AM |
its worth doing
I would wait for a hot day then drill a hole in the back of the sill so you can flush out all the dirt n dust from the inside with water
allow to dry then spray in Cavity Wax
you have to remove all the loose stuff first other wise its just going to continue to rust
Also remove the running boards and back seat interior panels using a hacksaw black and water again flush out the rear quarter panel using the blade
up the drain holes to make sure there unblocked
The front quarter panels also hold dirt and rust make the small hole bigger in the bottom of panel n flush out with water
also using rust converter is a good idea as no paint in any of the areas
I think Wurth has good product it will smell for while but use the heaters for few days
bushed
Threads: 66
posted on August 15th, 2020 at 09:52 AM |
early bugs were dipped in a gal type primer ? meaning inside of channels etc and not sure if aussie ones were from ( ca 1960!) So yes, drilling holes
also the size of a good rubber drain plug will be good. then fit it -
the ones where water gets out but not easily in..(funnel shape...)
MR930
Threads: 73
Mood: VW crazy.
posted on August 19th, 2020 at 05:53 PM |
We sell a lot of techtyl to car resto customers. Some mix it with fish oil too.
hulbyw
Threads: 130
Mood: I'm OK, RU?
posted on August 22nd, 2020 at 02:11 PM |
Thanks folks. Once the weather warms up (10 degrees in Melbourne atm) I will get some wax and give it a go.
