[ Total Views: 974 | Total Replies: 4 | Thread Id: 113854 ] |
m4co
Threads: 37
posted on September 28th, 2020 at 12:27 PM |
Fitting VW Beetle Tow Bar
Hello,
Does this tow bar require the guard to be cut when installing on VW Beetle?
Does anyone have pictures of it installed?
Thank you
grumble
Mood: happy all the time
posted on September 28th, 2020 at 07:03 PM |
Quote: | Originally
posted by m4co
Hello,
Thank you
I thought that I had seen nearly all of the towbars on the early beetles but I have never seen one of those. I do not know of any that required body
panels to be cut as this would weaken them, there was a similar one that was popular but apart from the bumper mountings the mounting arm went
forwards and another hole was drilled to support the bar.
bushed
Threads: 66
posted on September 29th, 2020 at 09:27 AM |
looks extra heavy and weird as Grumble said...unseen b4! I would cut off the top above the bar and dd another bolt inside add strong larger washers
when bolting the 3rd hole.
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on October 1st, 2020 at 08:07 PM |
That tow-bar would not be any good for serious towing. There would surely be some damage done due to 'stretching'.
There was a tow-bar available once, that connected to the torsion-bar tubes, the 2 'big' engine bolts, and the bumper bracket mounts. The towing
loads were distributed over a wide range of strong points. I successfully towed my Formula Vee behind the '68 1500 Beetle, using this tow-bar.
grumble
posted on October 2nd, 2020 at 06:35 PM |
Quote: | Originally
posted by HappyDaze
They were a good bar and we must have fitted hundreds during the 1960's 1970's but there were a lot of other bars that were just that and stretched
the bum of the beetle.
