[ Total Views: 1368 | Total Replies: 4 | Thread Id: 114065 ] |
hulbyw
Threads: 130
Mood: I'm OK, RU?
posted on January 25th, 2022 at 06:41 PM |
1968 Beetle Heater Connectors Asbestos?
Hi folks
The ribbed connectors that connect the heater boxes to the bakelite tubes which then connect with the steel heater tubes that go through the body
appear to have asbestos around the connecting flanges at each end. Anyone else with a '68 noticed that? And if so what did you do?
If I am right I have a challenge as the heater tubes available new are way too long.
Cheers.......Wayne
viiking
Threads: 58
posted on January 26th, 2022 at 07:26 AM |
I believe that the cuffs indeed are asbestos. I haven't yet got to this point of reassembly of my 68.
Here's what the SAMBA says about the solution.
"I would recommend replacing the asbestos with silicone cuffs from an aircooled Vanagon because they seal better and are better for your health."
http://www.ratwell.com/technical/Heating.html
AA003
A.k.a.: Phill
Threads: 39
posted on January 26th, 2022 at 12:17 PM |
I just left them.
Sometimes Volkswagen dealers sell spare parts. Amazing isn't it!
vw54
posted on January 26th, 2022 at 03:57 PM |
out
hulbyw
Threads: 130
Mood: I'm OK, RU?
posted on January 26th, 2022 at 04:41 PM |
Thanks guys. Not a big fan of asbestos so leaving them in is not an option for me.
Silicon Vanagon ones would be great but I would need 4 so finding good used is also likely not going to happen. Guess that leaves me with p/n 111 819
945. I will email WCM and ask for dimensions. Another possibility is replacing the asbestos with some silicone gaskets cut from a muffin tray and re
using the steel ring that holds the asbestos in place.
