[ Total Views: 3151 | Total Replies: 15 | Thread Id: 13341 ] |
type3kid
A.k.a.: Aaron
Mood: evolving..
posted on September 16th, 2003 at 11:56 AM |
hmmmm....is it posible to squeeeeze
a 2.5lt liberty motor has come up for sale and has taken my interest.
is it possible to get it into a t3 squareback without excessive fuss? where the hell do i put the radiator??
thanks all
baybuscamperkid
Threads: 335
Mood: transported
posted on September 16th, 2003 at 01:16 PM |
there would be a fair bit of chopping involved internally, but i believe with the lid closed it would be invisible - no external change. as for
radiator, check out bus conversions with that engine, roadcow i think is one, see what they do and see if it will be any help.
Kombicol
Threads: 18
Mood: subariffic
posted on September 16th, 2003 at 01:26 PM |
Roadcow is a good site for general suby information and i used it extensively for help sticking the EJ20 in my kombi,
but you may wish to look here
http://www.cnr.colostate.edu/~kevinlh/type3_conversion_to_subaru.htm
Col
I believe the external dimensions of the EJ22 and EJ25 are the same.
type3kid
A.k.a.: Aaron
Mood: evolving..
posted on September 16th, 2003 at 10:44 PM |
hmmm sondin like a lot of work....but i don't think i can say no to an engiune upgrade
Adam_C
Threads: 164
Mood: could be lower
posted on September 16th, 2003 at 10:50 PM |
bloke i know has got a typw3 with vents welded in the front apron... ill look for sum pics and shoe you ......
you may have seen it at valla or what not, greeny early type 3 with type 4 motor in it .... broken clutch ?
adz
Adam
Adzslick@iprimus.com.au
type3kid
A.k.a.: Aaron
Mood: evolving..
posted on September 16th, 2003 at 11:03 PM |
can' remeber it dude. the guy isn't selling for a few months so i have time to doi some research
Adam_C
Threads: 164
posted on September 17th, 2003 at 12:14 PM |
k well its in peices but ill look thru and find sum pics. . . the vents in the front apron are similar to the ones in the back og a beetle under the
window only longer . . . they loos shit hot . . . stay tuned and ill get sum pics
adz
Adam
type3kid
A.k.a.: Aaron
Mood: evolving..
posted on September 22nd, 2003 at 10:42 PM |
sweet man thanks
65square
Threads: 21
Mood: hip 2 b square
posted on September 22nd, 2003 at 10:52 PM |
There was a purple Fasty in ye olde Australian VW magazine (a couple of years back) that had a golf motor in it. He'd used superbug decklid vents
in the front apron to feed a radiator. It looked really neat. Didn't detract from the front of the car at all.
Oasis
Going alone...
Threads: 77
Mood: Deep
posted on September 23rd, 2003 at 01:13 AM |
I've got that mag here. I'll see if I can get a friend to scan it and post the pic. That purple notch looks great too.
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
posted on September 23rd, 2003 at 08:55 AM |
you'd need some pretty custom engine mounts to make it work, since the gearbox has no rear mounts on the type 3. The side engine mounts may even
be in the way of the wide subaru engine. You'd have to measure it up and see. The Subaru motors are a lot wider than VW motors, just remember
that.
Be careful of buying a bare motor. The cost of getting a loom made, and finding a computer, may be more than just buying a front cut in the first
place.
Cam
Threads: 187
Mood: addicted
posted on September 23rd, 2003 at 10:53 PM |
Jeff Unwin who used to run Hellbug has a scooby motor in his notch. Amazer told me he had something like 5 hydraulic engine supports. Perhaps U2U
amazer and get his details, can't hurrt to ask someone whos done something similar.
type3kid
A.k.a.: Aaron
Mood: evolving..
posted on September 24th, 2003 at 08:40 AM |
thanks for the feedback guys, it's much appreciated. i'll look into it more and find out exactly what he is selling.
amazer
kombi pilot
Threads: 308
Mood: Peachy!
posted on September 24th, 2003 at 10:41 AM |
The subaru motors are bloody heavy. 2 'normal' people struggle to lift one. That is where most of your problems will come from. Type 3
mounts sometimes crack with a standard engine. Forget about using those. You would have to have a swingaxle rear end with frame horns (possibly weld
trailing arms in). You would have to make up your own engine support to go to the rear bumper mounts. Jeffs engine still moved around something fierce
and tramped severely. So had to make up some tie rods that triangulated across the back and 2 hung down from the parcel shelf which you wont have in a
square.
I havent done any work on a non turbo one, but I dont think you would get it under the lid.
Then there's the gearbox? what you going to use?
If you can get the engine in securely, the radiator is easy.
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
posted on September 24th, 2003 at 10:55 AM |
This document says the EJ20 is 130kg, and the EJ20T is 147kg
http://www.surrealmirage.com/subaru/files/SAE_boxer.pdf
I don't know what's attached to those engines at the time of being weighed though. Not much probably.
My V6 with absolutely everything on it, flywheel (10kg!) exhaust up to the merge, complete intake, power steering pump, alternator, etc is 176kg.
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
posted on September 24th, 2003 at 11:05 AM |
An EJ20T in a notch has been done a few times. The blue one raised the rear gearbox / engine mounts to give the sump some ground clearance.
amazer
kombi pilot
Threads: 308
Mood: Peachy!
posted on September 24th, 2003 at 11:52 AM |
Quote: | Originally
posted by Baja Wes
What does a type 3 or a type 4 engine weigh?
Im only going by the pressure on my sphincter. I'm not the strongest guy around, but have a little bit of muscle. With one other person I can
carry around a type1 engine all day. A type 4 engine I can carry across a workshop then lift it high enough to get it in the tray of a ute. With an
EJ20 I can push a trolley jack next to it and lift it onto the jack. Nothing else. And the bloody things want to fall off too. not like the good old
VW engine.
Thinking about it I dont reckon you would get even a non turbo one under the lid of a square. The intake manifold and alternator are probably the same
height as a turbo one which IS too high.
