[ Total Views: 23984 | Total Replies: 21 | Thread Id: 25277 ] |
vwtyp2
Mood: over it
posted on June 30th, 2004 at 11:59 AM |
Electric supercharger. Anyone had any experience with one?
Just doing a bit of browsing and came across this.
http://www.electricsupercharger.com/index.htm
theres a couple on ebay at the moment.
Anyone tried one of these or similar?
they say 4-6% improvement in hp at the wheels.
doesn't seem too bad for the money.
I'm looking for opinions on this product if anyone has used, or is using one.
I'll be fitting it to the 3.8l v6 in my kombi.
space restrictions limit using a mechanical supercharger without doing any body modification.
HotRodMatt
If it's old or rare - cut it!
Threads: 361
posted on June 30th, 2004 at 12:28 PM |
Sounds very RICE to me..... It isn't forcing the air into the cumbustion chambers only helping it into the air intake.
I can't see how there would be any BOOST after the injectors...
MickH
A.k.a.: Michael Hutchinson
Hairy Gutted Sloth
Threads: 29
posted on June 30th, 2004 at 01:35 PM |
Yeh...looked into them ages ago. One model will guarantee a 1psi boost with there unit which can be fitted in series to give you 2psi. The only
trouble is they are turned on at WOT and can only be run for a maximum of about 30 seconds. With the $$$$ you would spend it would be more economical
to get the real thing or a turbo and at least have the power all the time. Having said that.. they do work but for the $$$ it is not worth the effort.
Still a lot of development going on overseas..............
tssnq.com.au
vwtyp2
Mood: over it
posted on June 30th, 2004 at 01:56 PM |
won't any other type of forced induction only increase pressure in the intake?
isn't that why turbo's and superchargers are termed forced induction.
Doesn't turbo charging or supercharging force charge through the injectors or carby (be it draw through or blow through) anyway?
Isn't this why with most mechanical supercharger kits, they also provide larger injectors?
vwtyp2
Mood: over it
posted on June 30th, 2004 at 02:07 PM |
they provide an explanation as to why they only work at WOT.
if you want more hp at half throttle, you simply put your foot down further and give it more throttle. till the throttle is wide open.
I think that you'd probably end up changing gears and backing off the throttle within 30 seconds of flooring it.
the only thing may be for highway use, cruising in 4th at WOT for a long period of time. then you'd be exceeding the speed limit anyway.
Desert Moose
A.k.a.: Chris Hill
Cut Cut Cut
Threads: 175
Mood: I don't know if I'm indecisive
posted on June 30th, 2004 at 03:18 PM |
I looked into it years ago when A mate got one. Its almost a waste of time. it gives you a little H/power at first but it restricted the air flow on
his car at 5.2rpm and this was his peak housepower rev. he couldn't get the computer to run it. I think I still have it in the shed, I will have a
look tonight.
It was one like this
Desert Moose
A.k.a.: Chris Hill
Cut Cut Cut
Threads: 175
posted on June 30th, 2004 at 03:22 PM |
Quote: | Originally
posted by Desert Moose
look tonight.
Error |
vwtyp2
Mood: over it
posted on June 30th, 2004 at 04:11 PM |
what do you think was the issue?
was it the type of engine, or something with the AFM?
was it an installation issue?
or was it just the unit itself?
they reckon that these things don't restrict airflow when they aren't spinning.
shouldn't the AFM automatically correct for the increase in airflow?
let me know if you wanna sell it.
I'd be interested to give it a try for the right price.
I'm tired of all these quick, easy cheap bolt on horsepower gains.
I want something that is easy to just bolt on, that is cheap and adds horsepower.
Desert Moose
A.k.a.: Chris Hill
Cut Cut Cut
Threads: 175
posted on June 30th, 2004 at 05:43 PM |
it was on a nissan:puke sr20 and I have no real idea why. but I was thinking that maybe once the car was at big rpm with WOT that the turbulance over
the fan was slowing down the flow. what made me think of this was, you backoff and the hp would spike for a sec. Why? as I said no idea.
Yes I still have it here but only the fan and filter, it has two wires on it. I put it on a battery and it still works all the wiring harness stuff is
gone. I have the pic of it and will post it tonight (need other computer) I will also ring my mate and see if he will sell it
seagull
Threads: 752
posted on June 30th, 2004 at 08:15 PM |
I know the importer of these Chris ,they sell the hyclone as well .
Desert Moose
A.k.a.: Chris Hill
Cut Cut Cut
Threads: 175
posted on July 1st, 2004 at 02:52 AM |
Sorry not for sale........ Bugger. I will upload pic tomorrow but
vwtyp2
Mood: over it
posted on July 1st, 2004 at 03:10 PM |
I think I'll spend the money on getting a set of extractors for it instead.
Probably get the same performance gains, and look and sound better too.
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
posted on July 1st, 2004 at 04:00 PM |
These are an absolute waste of time.
To compress enough air to a high enough pressure to be of any use requires a fair bit of HP to do it.
A turbo gets the HP from the exhaust gases, and the backpressure on the engine.
A supercharger gets it straight from the crankshaft.
A crappy little electric fan ain't gunna have enough HP. If you did have a big enough fan, it would draw way too many amps to be useful.
A 1600cc engine at 5000rpm will need 4000L/min of air (assuming 100% volumetric efficiency). To compress that much air to even 5psi will require 3hp
(pressure x volumetric flow = power). Then the electric motor and fan efficiency will mean you need to put about 6HP in to get the 3HP into the air.
So you would need a 5-6HP electric motor attached to a fan to get 5psi of boost. That's a big motor. And of course to run it on 12 volts will require
nearly 400amps. I have you have a good electrical system and alternator.
Of course the ebay fans are much smaller than that, so can't make the boost and won't make a difference.
Jenny
Threads: 20
Mood: Is it Friday yet?
posted on July 17th, 2004 at 08:29 AM |
Here's another version
http://home.earthlink.net/~mfirehawkta/index.html
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
posted on July 26th, 2004 at 01:10 PM |
I just went through that last link. That site is so funny, you'd have to be so dumb to believe anything on that site. here's my favorite stupid
quotes.
but first, the dyno chart is also the biggest piece of crap I have ever seen. It's not even scaled to show you the curve properly. And the different
curves are using different rpm ranges if it's supposed to be done in the same gear. I'd ignore the dyno.
Quote: | The most powerful
electric turbo available to the public! (THIS IS NOT A BILGE PUMP) Single motor w/ steel casing: 1.7 psi @796cfm to 2 psi @800CFM (See Air Flow Chart
Below), 3.6 Lbs per unit, 22 blade blower fan, all steel (45 degree pitch), Casing made of 650 degree polypropylene plastic, Uses only 19amps (less
than most aftermaket stereo components)
Ok, so lets run some quick calcs on these numbers. Assuming it's a really efficient fan (80%), then the amount of power required to generate 2 psi
@800CFM is 8.7HP. Yes that's right 8.7HP. 6.5kW. That's a pretty damn big electric motor. Then of course divide that power by 12volts and you have
the required amps, which is 542amps. yes, that right 542amps, not 19 amps. These guys are on drugs.
Quote: |
Want To Know How Much Horsepower
Your Car Will Gain?
Use This Formula:
The liters of your engine X (times)
803 single or 1606 twins (cfm of the E-turbo)
Devided by 1/2 (half) the Wheel Horsepower of your Motor -(minus) 8 = The E-turbo Horsepower Gain for Your Car
(Estimated Figures)
Best estimate for wheel horsepower: Take manufactures (crank) horsepower and minus 30 = wheel horspower
THIS FORMULA CREATED BY CONTRACTED ENGINEERS
WITH THE U.S. AIR FORCE
There is so much wrong with all that I don't know where to start. How about the crank to wheel horsepower one, so an old 25HP vw motor will have
-5rwhp? hmm, not quite right.
How about a VW kombi 2lt engine, they got around 50HP at the wheels. how much would twin fans add...
2 x 1606 / (0.5 x 50) - 8 = 120HP! wow!
Quote: | NOT FOR USE WITH
FORD, MAZDA, OR AUDI Sorry!
So those brands need different magical equations then?
And the storys from customers all have the same real crap writing style as the rest of the site.
and they are trying to sell those things for $350 US!
vwtyp2
Mood: over it
posted on July 26th, 2004 at 01:54 PM |
I figured they must be a p.o.s. otherwise everyone would run them.
thinking about one of these now instead.
http://www.rodshop.com.au/superchargerholdv6.htm
anyone here dealt with castlemaine rod shop?
Error |
Desert Moose
A.k.a.: Chris Hill
Cut Cut Cut
Threads: 175
posted on July 26th, 2004 at 04:05 PM |
Quote: | Originally
posted by vwtyp2
Yeh, allways been good on price to me but sometimes send the wrong stuff by post (they have fixed it up at their cost but) I would use them tomorrow with out a problem..... :thumb
vwfastback
Threads: 12
Mood: Ready for Boost.
posted on December 15th, 2004 at 11:55 AM |
Got a HQ to Chev Disk brake conversion kit from them. It works well.
Considering the 202 supercharger kit. Very cheap horsepower compared to my fastback. But not as much or as fun.
aintgotitmusthaveit
A.k.a.: Nick
Threads: 75
posted on September 16th, 2006 at 04:34 PM |
With respectto the ebay ones. Go read the feedback the seller has had on the said items. ON short marginal if any performance improvement. I agree the
watts been ridiculous amps!
Turbo54
Mood: Boost'n
posted on November 14th, 2006 at 03:02 PM |
Dan I have a chip at home that was put on my V6 commodore when I took the blower off, it is the factory chip with refinements to the fuel and air
ratios. It was done by awesome automotive. I was going to chuck it on evil bay. Let me know\
I have done 2 supercharged v6's (S'Trim Vortechs and intercooled) now and they go good but supercharging robs power because of the friction in the
belt. Better results on turbocharging. Street machine magazine have just done a article about getting more output of your v6. last issue or the one
before. If you want to talk about it let me know.
Heath
C'mon kids gather round,
gazman
Threads: 7
Mood: hypo
posted on June 28th, 2007 at 06:31 PM |
you're definately better off with a toyota SC-14 blower like the CRS kit. i've fitted heaps of them and they work well. if your interested view my
'how to' page at:
http://www.geocities.com/gazman_4/supercharger.html
2443TT
A.k.a.: Ian
Threads: 68
posted on June 24th, 2009 at 08:35 AM |
Ever seen the leaf blower supercharger's? Not too practical but they actually work.
http://www.youtube.com/watch?v=XkQTHhCjyc8
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
posted on October 14th, 2009 at 10:46 AM |
My calculation of power and amps has been proven, here's a guy that makes electric supercharger kits that work;
http://www.turbomagazine.com/tech/0406tur_knight_turbo_electric_supercharger/index.html
Eaton supercharger driven by 3 modified 5kW @ 10,000rpm starters (can only be run for 15 seconds at a time due to heat).
He also has centrifugal style electric superchargers;
Requires some serious battery power
(attached)
I think you'd be pretty silly to install one of these.
Error |
baghall
Ben Hal Outlaw Bushranger
Threads: 131
Mood: Kids think I'm obsessed!
posted on May 2nd, 2010 at 09:27 AM |
I looked into these and found that generally the electric super/turbochargers on ebay generally only push air through at approximatley the same psi as
normal induction would so there is no real benefit to fitting them. I do like the look of the ones bajawes shows, certainly would push through a lot
more psi but I don't think you can beat 'old school styles'. They are affected by throttle changes whereas the electric ones would either have to
be set to a certain rev range or decent mods need to be done to throttle and make it a type of fly by wire setup.
68 Baja - It's a growing pain!
58 Baja ute - and the pain spreads!
85 T3 Kombi - still growing
89 T3 Kombi - parts car
