[ Total Views: 221683 | Total Replies: 708 | Thread Id: 38560 ] |
Pages: 1 .. 13 14 15 16 17 .. 24 |
pete wood
posted on April 23rd, 2009 at 10:19 AM |
line locker?
you've got 100rwhp and you think you need a line locker?
I'll make it simple so you understand.
1. hold throttle to floor with right foot
2. place stick in 1st gear
3. take left foot of clutch FAST
4. keep throttle on floor until tyres smoking... LOTS!
See, it's not that hard.
p.s. don't forget to have someone hold a video camera.
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on May 3rd, 2009 at 10:01 PM |
Quote: | Originally
posted by hellbugged
why do these boxes keep arriving on my doorstep with HALTECH written on them ........we're not done yet
SO what Haltech did you end up buying ?
C'mon wheres the updates
colonel mustard
Threads: 51
posted on June 28th, 2009 at 10:24 AM |
where is the update!!
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on July 19th, 2009 at 12:04 PM |
not much happening really........34000 km's up.
just finished moving oil cooler to front bumper via copper lines,works a treat...and now holds 10L of oil which makes for a fair investment of castrol
edge each oil change ..... so kafer bars can now be
fitted up too.
will get the line lock plumbed up, 36mm vents back in and rpm limit up to 7000rpm ready for race season.....want to knock off that 100HP mark and run
hard into the 15's and sub 10's
hellbugged
A.k.a.: Daimo Pell
posted on July 19th, 2009 at 05:45 PM |
matberry
posted on July 21st, 2009 at 03:07 PM |
Way cool install Daimo.
Pitty to hear you're not coming up to Dyno day.
hellbugged
A.k.a.: Daimo Pell
posted on July 26th, 2009 at 05:55 PM |
thanx Matt........oil temps down to thermostat opening temp (85 'c), as soon as it opens the temperature stops rising. still heats almost as quickly
as before and difference in heat between return and sending copper pipes is very noticable, so that little cooler is working very effectively.
lifted the number plate up a bit higher to expose more of the cooler, but don't think it needs it at all, maybe summer, just maybe......i might do
some more holes so the number plate can be mounted fair accross the cooler just for the hell of it, looking like the only thing we'll be able to have
adjustable here NSW anyways...........
having set up for it over 6 months ago, finally found the time to strap up the kafer bars.......
another step towards blending street car with race car
colonel mustard
Threads: 51
posted on October 9th, 2009 at 09:40 AM |
the oil cooler looks like a sweet addition. I think i will cut the front apron/valance on my super, like the us spec version (or like joel's super,
or dave carters super..) and fit one behind.
matberry
posted on October 9th, 2009 at 10:11 AM |
Quote: | Originally
posted by colonel mustard
colonel mustard
Threads: 51
posted on October 17th, 2009 at 09:07 PM |
Is that a thumbs up for, good idea? Or just a 'Duh'
matberry
posted on October 17th, 2009 at 09:44 PM |
Thats a double thumbs up for.....just do it.
STIDUB
Over it.
Threads: 57
posted on November 6th, 2009 at 08:53 PM |
ok ive looked but cant find, what kind of pump are you using for the gearbox? i see one inlet pipe but no out, ill guess that the drain plug is the
outlet?
Volkswagen Drivers Club of Queensland - member
hellbugged
A.k.a.: Daimo Pell
posted on November 6th, 2009 at 09:17 PM |
Quote: | Originally
posted by STIDUB
outlet?
no, just a breather......westi had a cooler and pump on the junka at the beginning
i've got a PWR cooler with AN 8 fittings for you if you go down that route, give me a holler
colonel mustard
Threads: 51
posted on November 6th, 2009 at 10:01 PM |
Hey,
this might be a dumb question, but are berg 5's just swingers?
hellbugged
A.k.a.: Daimo Pell
posted on November 6th, 2009 at 10:03 PM |
Hey,
no either way.......swing axle or C.V joint
colonel mustard
Threads: 51
posted on November 6th, 2009 at 10:18 PM |
cool thanks for that
hope the vw's are treating you well
cnfabo
Threads: 140
posted on November 6th, 2009 at 10:21 PM |
what size copper lines and oil pump u running dam0. im going down this route aswell... and howd u go about primming the lines...
STIDUB
Over it.
Threads: 57
posted on November 7th, 2009 at 12:23 AM |
Quote: | Originally
posted by STIDUB
outlet?
Will do, had a quick look thru westi's thread because someone i know is curious if i could make a similar dry sump tank, couldnt find specifics on
gearbox cooler though, will look later on, currently ive had a long arse week & its 30mins into the only day i have off so on that note im going
to bed!
(if you have the info of his cooler/pump etc on hand that would be nice) if not ill have a look for myself later on!
hellbugged
A.k.a.: Daimo Pell
posted on November 7th, 2009 at 08:27 AM |
Quote: | Originally
posted by cnfabo
3/4 inch copper...26mm oil pump.
definately run an external oil thermostat tho so the car gets warm quick.....and worth getting oil pressure relief pump cover as my sisters car did
not have one and when cold blew the lines of several times, despite them being clamped on barbed fittings
prime the lines with a "plunger" oil pump like used in 20L drums. i just disconect the lines at the rear of the car and pump away till it
returns..........hook the return up and keep going till the oil level shows on the dipstick
cnfabo
Threads: 140
posted on November 8th, 2009 at 01:21 PM |
thanks dammo
hellbugged
A.k.a.: Daimo Pell
posted on June 27th, 2010 at 09:56 PM |
SHELVED
71-BEETLE-SEDAN
AKA Josh
Threads: 108
posted on June 27th, 2010 at 10:07 PM |
why???????
johny rotten
why ?
johny rotten
posted on June 27th, 2010 at 10:08 PM |
gearbox failure ?
cnfabo
Threads: 140
posted on June 27th, 2010 at 10:10 PM |
whats going on???
hellbugged
A.k.a.: Daimo Pell
posted on June 27th, 2010 at 10:16 PM |
http://www.youtube.com/watch?v=OUfb5z1lpk8
johny rotten
posted on June 27th, 2010 at 10:24 PM |
clear as mud
hellbugged
A.k.a.: Daimo Pell
posted on June 27th, 2010 at 10:30 PM |
driveline fine.....Chassis R.S
got bored one weekend pulled it apart.......time for "Ratstoration"
matberry
posted on June 27th, 2010 at 10:42 PM |
"Ratstoration"
Into it dude. You actually filmed it leaving for the last time???
hellbugged
A.k.a.: Daimo Pell
posted on June 27th, 2010 at 10:46 PM |
ha Haa yeah Matt.......never been able to resist a lap without the muffler......it's always first thing removed when work begins
"Ratstoration"
how long till Valla ?
