[ Total Views: 123301 | Total Replies: 1116 | Thread Id: 85894 ]
 Pages:  1  ..  23  24  25  26  27  ..  38
Author: Subject:  Steves 1303 buildup, found lots of kilowatts
posted on September 23rd, 2014 at 11:02 AM
I'm thinking about getting one of these barrel air filters from Summit Racing.
Gotta love computers, I sent Leigh Harris the cal file from my ECU, he altered it to suit the new injectors, he emailed it back to me, I loaded it into the ECU and its started and idled like it always does
Membervlad01
Mood: Side ways
posted on September 23rd, 2014 at 08:50 PM
Originally posted by Jak Rizzo
unenclosed pod filters have always been illegal in NSW. Don't know why.
Although I don't know how it's any different to twin carbies sitting in your engine bay.
Either way, it's not good for your motor / intake temps anyway
well, depends on the engine bay heat. intake might only be 10-15 above ambient in a water cooled engine bay when its moving.
I would think carbys with filter be more dangerous as it can back fire with flames and there is liquid fuel. There is none of that with EFI.
71 notchback,
posted on September 25th, 2014 at 10:59 PM
I just got back from a quick test drive, even on gate pressure of 8 psi it's fast, comes on pretty early as well, tune on Monday.
Thanks to Brad (Westy) for turning my dreams into solid metal once again.
He shortened the ice box for me as it was a bit too large to fit where I needed it to fit and he also fitted a coil of aluminium fuel line inside it so now I have fuel cooling on the return line.
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on September 26th, 2014 at 12:02 AM
:tu:
Membervlad01
Mood: Side ways
posted on September 26th, 2014 at 01:12 PM
arhhh spaghetti !
there are enough hose clamps in that one shot for 3 of my cars :lol:
71 notchback,
posted on September 29th, 2014 at 05:15 PM
Just got back from the tuner, shit day for tuning a car, 31 c. Made 220 kilowatts with some more to come after a few cheaper mods.
posted on September 29th, 2014 at 06:14 PM
I cant speak highly enough of how good the tuner Dvs Jez is at his job, 1st he did a smoke test on the system which showed up a few leaks and then preceded to do a few power runs, it became obvious to him that my exhaust is limiting things, so a few more mods should see even more power.
posted on September 29th, 2014 at 08:53 PM
WOW!!! :spin:
MemberCamo
A.k.a.: Kev
Threads: 209
posted on September 29th, 2014 at 09:16 PM
It certainly comes on a lot stronger at the 145 kmph mark with the new turbo, you must have an even bigger smile on your face now than before :D
Kev :tu:
posted on October 7th, 2014 at 09:49 AM
I had great time at Warwick, getting a handle on launching the car. A quick video that my son put together https://www.youtube.com/watch?v=uhgVgzf5oD0
posted on October 7th, 2014 at 10:44 AM
Great video
I assume you put the new bars in? really not bogging down at all??
Looks like you got you take off pretty good
Love it :tu:
posted on October 7th, 2014 at 12:13 PM
Thanks Baz, Im really happy with the new bars, just enough squat. I was running 33 psi in the rear tyres so there is lots more traction still to come if I need it
posted on October 22nd, 2014 at 09:05 PM
Went to see Westy today and he made new less restrictive exhaust for my Beetle, just need to finish of my air box now and then back for another tune and more kilowatts.
Memberboof2332
Threads: 120
Mood: Sympathetic
posted on October 25th, 2014 at 08:21 PM
That's sick Steve..
How does it drive compared to your quick spooling little vf35..which is a non ball bearing vf34. Any lag?
With regards to the intake.. I cut my up pipe and turned it about 45 degrees so the intake runs under the front of the manifold and my filter sits just in front of my starter motor.. lots of cool air hits it there and the engine bay looks really clean.
Nice figures on the dyno!!!
Matt
Membervlad01
Mood: Side ways
posted on October 25th, 2014 at 08:33 PM
could also use a foam filter from UNI filter. Couple of us guys have found them not only filter much better and finer dust but also breath better compared to top brand cotton cloth pod filters, worth a few Kw in NA applications, boost should be a fair bit more as boost engines are sensitive to intake restrictions. Aussie made too. :tu:
71 notchback,
Memberboof2332
Threads: 120
Mood: Sympathetic
posted on October 25th, 2014 at 09:02 PM
I used to have a uni filter ram pod.. was awesome but was really big and hard to position.. just use a KandN pod now.
Matt
Membervlad01
Mood: Side ways
posted on October 25th, 2014 at 10:51 PM
yeah i just got their custom range to match up a K&N style pod. 140 D x 140 L, can also specify a custom size if needed.
And the fact I can go a whopping big sized one later for my other car that doesn't have the same space restriction is a big plus.
At least 140 D X 200 L :yes: may even go 180 x 200 :crazy:
71 notchback,
posted on October 26th, 2014 at 07:11 AM
Matt its a little less torquey down low but just over 4 its hits like a hammer, but now with the new exhaust it seems to come on earlier again, hopefully a touch up tune next week.
The VF 30 is a plain bearing VF 34, but the VF 35 is similar to the VF 30.
I going to use a Mondeo (3/95 - 04) air box with the lid removed, it will sit at the engine lid vents and suck air through there, its 397 x 150, photos soon, I cant believe how it all just fell into place.
On a shit note my sons Skyline was totalled last night. Some guy jumped in his car, hit 3 cars in his street, then hit my sons Skyline then drove anther 200 metres and hit another car and then crashed into someone's front yard, all in very quiet Lugarno
Membervlad01
Mood: Side ways
posted on October 26th, 2014 at 08:51 AM
with a paper panel filter or hi flow replacement?
I found the stock panel paper ones just choke the shit out of the engine.
71 notchback,
posted on October 26th, 2014 at 08:59 AM
I will test either way with the filter.
posted on October 26th, 2014 at 10:03 AM
did they catch the guy ?
insured?
posted on October 27th, 2014 at 09:42 PM
They caught the guy, his two front wheels were ripped of so he didnt get far.
Just had my entry confirmed for the Snowy Mountains 1000 in November, its a 1000 metre sprint/drag race on Cooma airport.
Cant wait.
posted on October 30th, 2014 at 09:16 PM
I just made new air filter box using the base from a HC Mondeo air cleaner, I will have to see how it goes, road trip tomorrow to Shepparton to have a look at the Skyline Nationals.
Thanks again to Westy for his help with the aluminium doughnut he welded up for me.
posted on November 5th, 2014 at 08:41 AM
Just got back from a road trip to Shepperton in the bug. I'm really happy with how the car performs now with the new turbo. It comes on at 4200 like you just got hit up the bum by a train.
So cruising at 120kph its off boost at about 3,000 rpm so its very quiet, it picks very nicely in 5th at that speed with a few psi of boost, if I stick it back to 3rd at that speed its nuts.
After stops for fuel etc you could really see how the new intake setup dropped temps back down again after some heat soak from the stop and something that I haven't seen before is the intake temps varying depending on load, so if I boot it intake temps would rise and fall back down again when cruising.
posted on November 14th, 2014 at 01:35 PM
Another shit day for a tune, very hot.
I've reached the limit of the current set-up now which is what I wanted to do, next cams & E85.
Membervlad01
Mood: Side ways
posted on November 14th, 2014 at 06:52 PM
boost does this, you can reduce it with yet bigger intercooler. What temps do you see at full load?
In NA application its goes the other way, temps drop with more load as more air volume consumed allowing less time for the manifold to heat the air.
Another trick you could try is phenolic intake insulator spacers to stop intake heat soak.
71 notchback,
posted on November 15th, 2014 at 05:29 AM
I'm running a massive PWR intercooler already, my intake temps are usually 10-15 above ambient.
I'm not complaining about the heat soak, maybe I didn't make myself clear, previously the intake temps would take forever to drop down after stopping the car and I wouldn't get the variation I do now that is dependent on load, it just shows that the new intake is able to take heat out quickly when on the move.
I already have phenolic spacers under the inlet manifold.
Membervlad01
Mood: Side ways
posted on November 15th, 2014 at 07:36 AM
ah ok.
71 notchback,
posted on November 15th, 2014 at 08:49 AM
235kW - Holy Bat Bug!
And on a 35+ day
Unbelievable Steve :tu:
posted on November 23rd, 2014 at 06:10 AM
Had a great run at the Snowy Mountains 1000, the results are here http://racing.natsoft.com.au/635946593/object_682127.82H/Result?8
[ Queries: 40 ] [ PHP: 11.3% - SQL: 88.7% ]
