[ Total Views: 219618 | Total Replies: 708 | Thread Id: 38560 ]
 Pages:  1  ..  4  5  6  7  8  ..  24
Author: Subject:  The last Hellbug
Memberdangerous
Mood: 591
posted on February 27th, 2007 at 06:07 AM
Originally posted by dumone
there are MARS bars riding on a completion date now:kiss
Sounds like Jeff.
He bet me one back in the 90's he would run a 9 before me.
At the time he was sponsoring Rodney, so I never collected...
Originally posted by westi
That's mad Alan.
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on March 20th, 2007 at 07:48 PM
still waiting for some 1.45 rockers to arrive to be able to finish the spring set up so i've had push on with other bits and pieces.......
flanging the exhaust........
the flanges i had needed opening up to be able to fit the 1 5/8........a holding jig was knocked up and it was back to the lathe to open four flanges up to tightly fit the flared side of the headers joins, and four more to match the tubes O.D to make it all possible......
some CV joint bolts were turned down on the head in order to clear the exhaust tubes.....
http://i31.photobucket.com/albums/c365/dumone/Picture004Small-2.jpg
i'm after both the benefits of additional strength here........
http://i31.photobucket.com/albums/c365/dumone/Picture007Small.jpg
and improved sealing here...........all ready to be tacked, removed and fully welded
http://i31.photobucket.com/albums/c365/dumone/Picture005Small-1.jpg
[ Edited on 2-4-07 by dumone ]
Memberhellbugged
A.k.a.: Daimo Pell
posted on April 2nd, 2007 at 07:53 PM
ooorkay, welded up, time for clean up!
http://i31.photobucket.com/albums/c365/dumone/Picture008Small-1.jpg
being a very tight fit on the slip joints to start with, the slightest blemish created by the mig (in the pipes) was going to need tidying up before the exhaust would even go back together!......more die grinding!:fakesniff: the collector was going to need the most porting/streamlining,
http://i31.photobucket.com/albums/c365/dumone/Picture009Small-1.jpg
but as usual, I can't help but do the works..........
........"at the head" flanges......
http://i31.photobucket.com/albums/c365/dumone/Picture011Small-1.jpg
fiddle de deeeeeeeeee
http://i31.photobucket.com/albums/c365/dumone/Picture012Small.jpg
all the joints and primary's are now clean as a whistle, anything for a couple of horsepower:ninja:
http://i31.photobucket.com/albums/c365/dumone/Picture014Small-2.jpg
must get back to that collector that i was supposed to be doing, so i can install the bung for the air/fuel sensor.......maybe tomorrow:D
Membertassupervee
A.k.a.: Knob Jockey
That really hurts doesnt it!
Threads: 25
Mood: Moody!
posted on April 2nd, 2007 at 08:38 PM
Hey Dumone
Thats a nice merge.
Could you take a pix of up its bum?
Id like to have a look at the merge on the inside from the outlet end.
Secondly, did you take into account the order the zorst pulses enter the merge?
Just interested.
L8tr
E
Im not a complete idiot, quite a few parts are missing....
MemberLIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on April 3rd, 2007 at 09:38 PM
Originally posted by tassupervee
Hey Dumone
Thats a nice merge.
Just interested.
L8tr
E
The absolute "must do's for HP gains of a Formula Vee". Definate HP gains on any motor....
You obviously have set the primaries to a certain length to match cam/engine specs for best power too. Nice looking work there!!
Memberhellbugged
A.k.a.: Daimo Pell
posted on May 1st, 2007 at 07:04 PM
ooooorkay then, the Zorst's bum:P
this is how it looked with a rough clean up......
http://i31.photobucket.com/albums/c365/dumone/Picture001Small-1.jpg
.....i decided to weld it up and port it out again, if you reckon it still looks rough, well, after welding i was almost in tears-FUGLY!......
http://i31.photobucket.com/albums/c365/dumone/Picture003Small-1.jpg
getting there.....
http://i31.photobucket.com/albums/c365/dumone/Picture034Small-1.jpg
time for the air/fuel sensor........
http://i31.photobucket.com/albums/c365/dumone/Picture030Small-1.jpg
http://i31.photobucket.com/albums/c365/dumone/Picture042Small-1.jpg
http://i31.photobucket.com/albums/c365/dumone/Picture044Small-1.jpg
DOH!!!!!!!, that just created more work.......just look at those flow suffocating bumps!:rolleyes:
http://i31.photobucket.com/albums/c365/dumone/Picture043Small-1.jpg
anything is something after yet another break.......still waiting for those 1.45's..........6 weeks airmail from U.S:?:
i think i've been ripped off for the first time:td:
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
posted on May 1st, 2007 at 07:27 PM
I love you work Daimo....but you gotta give me some details of that splitty up in the air! Is that Luke's maybe?.
I am looking forward to getting stuck into my turbo manifolds (exhaust and inlet) with the mig once the type IV goes in the oval....I got a new welding helmet for my birthday and haven't used it yet!
Keep up the good work mate!
Alan
[ Edited on 1-5-2007 by Dasdubber ]
Memberhellbugged
A.k.a.: Daimo Pell
posted on May 21st, 2007 at 07:23 PM
.......oh that old bit of this, bit of that, ginormous engine bay'd thing......it's just background filler!.........
Tinwear fiddling.........
on other fronts, i have dug up my old engines tinware set and grabbed some watercooled kombi valve covers and bails ready for modifying.........why the h2o covers.....
.... well the theory that they would have been removed far less often due to the hydrualic lifters negating the need to do regular valve adjustments......... definately rang true after cleaning them up...... the gasket surface was perfectly scratch and dent free....
myth confimed
http://i31.photobucket.com/albums/c365/dumone/Picture009Small.jpg
.....it takes a bit of cutting to be able to get those manifolds home..................holes/tubes on both sides of the rear tinware piece, will be vented via tubing down to the area of high air pressure/flow beneath the rear torsion bar housings..........this will help ensure there is enough air available in the engine bay for BOTH the carbs and fan with a closed decklid
exhaust and manifolds fitted up A.O.K........
http://i31.photobucket.com/albums/c365/dumone/Picture047Small-1.jpg
http://i31.photobucket.com/albums/c365/dumone/Picture049Small-1.jpg
........i had to check the angles of "'ol favourites" tappet cover drains. They look spot on to go round the exhaust and will soon be copied to provide the 3/4 inch drains directly back to the sump
http://i31.photobucket.com/albums/c365/dumone/Picture057Small-1.jpg
http://i31.photobucket.com/albums/c365/dumone/Picture053Small-1.jpg
.......they are also vented with a brass oil fitting at the front top corner (1/2 inch), to run back to the breather box, which was raided from the engine currently pushing my daily,along with some other good bits, last weekend.
http://i31.photobucket.com/albums/c365/dumone/Picture052Small-1.jpg
the single port copper intake gaskets are good for sealing at the oil filler:thumb.........
of course the berg breather bolted up perfectly:P
http://i31.photobucket.com/albums/c365/dumone/Picture061Small-1.jpg
the breather is baffled inside to separate the oil out of the air, returning via the filler as usual. the top vent is connected to the aircleaners to provide case vacumn as per standard, each of the lower ones are connected to the tappet covers and fuel pump block off respectively.
german tinwear GOOD, aftermarket BAD!.......
the repro "cool tins" under the cylinders sounded like a good idea......until i tried to fit up the rest!......they interfere with the standard bits.........i had to flatten out the dimples that normally scoop around the cylinder.
http://i31.photobucket.com/albums/c365/dumone/Picture048Small-1.jpg
yeah it looks rusty and rough, as usual, this is just mocking up so mods can be done before paint...
same story with the rear tin that runs down to protect the push rod tubes...........yes you can actually use these with a berg exhaust:thumb........ever had a look at a "case" that has been run for a decent length of time without these tins??..............i have and they provide the last peice of the "jig" that holds ALL the other tinwear sturdy enough to not scrub back and fourth aginst the soft magnesium adjacent to the cylinder spiggots........i will also use silicon to stop the gouging:thumb
http://i31.photobucket.com/albums/c365/dumone/Picture051Small-1.jpg
rear of the dog........again, crappy fitment is assured with aftermarket junk. i might even swap out to a late original shroud yet......
http://i31.photobucket.com/albums/c365/dumone/Picture058Small-1.jpg
DOH!!!!!! i never realized just how close i was getting.......
http://i31.photobucket.com/albums/c365/dumone/Picture054Small-1.jpg
..........just need some paint and polish really:rolleyes:.....sure:lol:
http://i31.photobucket.com/albums/c365/dumone/Picture055Small-1.jpg
hang in there baby, not long........
http://i31.photobucket.com/albums/c365/dumone/Picture046Small-1.jpg
fingers crossed for sure, one center stud sheered off, four loose (like almost dropping off!!) and one at 10ftpd, maybe we all need to cross fingers........(yes i have "addressed" those 6 center mains problems...well sort of)...........
ooo oo, just got a big box from the courier, have a look tomorrow for some real induction clobber that will make tose 48's look very old hat indeed!!!!!!!!!
[ Edited on 21-5-07 by dumone ]
Memberdangerous
Mood: 591
posted on May 22nd, 2007 at 06:48 AM
Did your rockers turn up Daimo?
That's mad Alan.
Memberhellbugged
A.k.a.: Daimo Pell
posted on May 22nd, 2007 at 06:21 PM
yes Dave, they did.......back in Pasadena U.S.A!!!!!!!!!!!!!
they got returned to sender for some reason:puke......trying again none the less.
mind you, the mail man did come through with some goodies for me.........
it wasn't my carb linkage tho..........
http://i31.photobucket.com/albums/c365/dumone/Picture063Small-1.jpg
http://i31.photobucket.com/albums/c365/dumone/Picture069Small.jpg
...i found it hard to have "words" with Mr Mailman about the rockers when he presented me with these babies....
http://i31.photobucket.com/albums/c365/dumone/Picture072Small.jpg
complete with injectors, rails and T.P.S:yes:
http://i31.photobucket.com/albums/c365/dumone/Picture074Small.jpg
...even came with 4 aircleaners
http://i31.photobucket.com/albums/c365/dumone/Picture076Small.jpg
all that needs doing is to open the cylinder tin a bit more and they're butter:ninja: linkage looks good to go with the T.B's................computer, wiring harness, decent fuel lines and pump needed
:dork:
Member56astro
Threads: 74
posted on May 22nd, 2007 at 06:35 PM
Unreal man
:tu:
35MPG on 101.3kPa
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on May 22nd, 2007 at 09:18 PM
That is one fine 1776cc :tu:............I think you need to put a stroker crank in!.........................Surely Jeff has one floating around ???:duh
Memberdangerous
Mood: 591
posted on May 23rd, 2007 at 05:50 AM
Very nice Daimo, you must be rich dude!
That's mad Alan.
Memberhellbugged
A.k.a.: Daimo Pell
posted on May 23rd, 2007 at 06:53 AM
nah Dave, big credit card.........those T.B's were cheaper than a set of Kadrons anyways:smirk:
Memberdangerous
Mood: 591
posted on May 23rd, 2007 at 07:34 AM
Cool score!
That's mad Alan.
posted on May 24th, 2007 at 11:17 AM
I'm not usually jealous of VW motors, but that is TOTALLY HORN!!!
hurry up and finish it so we can see the dyno readout. :dork:
[ Edited on 24-5-07 by pete wood ]
Memberhellbugged
A.k.a.: Daimo Pell
posted on May 29th, 2007 at 06:56 PM
yes yes Craig, tell me 'bout it!!!.....i've got my eye on a certain 78mm...........and there's another engine there with a custom 77.5mm to come in under 2 liters (with 90.5) so i can come and play with you guys:punk:
apart from that,not much to say today...tins are good to go after doing another set of cylinder covers....... just got to get off my hiney and paint it all now
http://i31.photobucket.com/albums/c365/dumone/Picture079Small.jpg
http://i31.photobucket.com/albums/c365/dumone/Picture080Small.jpg
was wondering where those dellorto stacks were..:smilegrin:
http://i31.photobucket.com/albums/c365/dumone/Picture093Small.jpg
these beasts make me laugh my butt off every time:smirk:
http://i31.photobucket.com/albums/c365/dumone/Picture084Small.jpg
http://i31.photobucket.com/albums/c365/dumone/Picture087Small.jpg
http://i31.photobucket.com/albums/c365/dumone/Picture098Small.jpg
http://i31.photobucket.com/albums/c365/dumone/Picture099Small.jpg
http://i31.photobucket.com/albums/c365/dumone/Picture097Small.jpg
http://i31.photobucket.com/albums/c365/dumone/Picture091Small.jpg
:cool:
Memberbond
Threads: 166
posted on May 29th, 2007 at 08:46 PM
hot. oh so very hot.
nick
Memberdangerous
Mood: 591
posted on May 30th, 2007 at 05:20 PM
Oh? Oooohhhh.
Pass the Kleenex!
That's mad Alan.
Memberhellbugged
A.k.a.: Daimo Pell
posted on June 5th, 2007 at 06:45 PM
good things come in three's..........
A: i finally recieved my 1.45 rockers
B: "found" a haltech ECU
C: more importantly, got one more job done that i had been putting off
Valve cover drains
pucker up and drill some big holes in your sump. doing this feels soooo wrong:fakesniff:.......tap the suckers out.
the holes were located as high in the walls of the sump as possible......
http://i31.photobucket.com/albums/c365/dumone/Picture108Small.jpg
3/4 inch fiitings protrude well into the sump to help prevent the oil running upwards during cornering and needed to be offset different on each side to allow for alignment to the heads
http://i31.photobucket.com/albums/c365/dumone/Picture102Small.jpg
some pipe was bent up, ready for brazing (plz don't look too closely:no:). a holesaw made life easy on the covers
http://i31.photobucket.com/albums/c365/dumone/Picture110Small.jpg
sumthin like this........ready for set up on the motor, then brazing
http://i31.photobucket.com/albums/c365/dumone/Picture113Small.jpg
out of time again:(
[ Edited on 5-6-07 by dumone ]
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on June 5th, 2007 at 07:52 PM
Keep plugging away Daimo - enjoying your progress as usual!
MemberVWCOOL
Threads: 235
Mood: happy to help
posted on June 6th, 2007 at 10:14 AM
Um, don't shoot the messenger but I think you may have a problem with oil running up into the rocker area; drain-backs must be above 'high tide mark' in the sump
Pay your debts, CxxT
Memberhellbugged
A.k.a.: Daimo Pell
posted on June 6th, 2007 at 10:00 PM
it's cool M8,when your sump is about to run dry, they are:lol:
seriously tho, it's nothing new Glenn, it's been done successfully before........
http://www.clubvw.org.au/Inch%20by%20Inch.htm
INCH BY INCH
Hellbug's Jeff Unwin takes us through what it took to squeeze a few extra seconds of performance out of his racing beetle
http://i31.photobucket.com/albums/c365/dumone/hellfrt.jpg
It had been two and a half years since we had turned a wheel in anger in the mighty little beetle and i was itching to get back into hillclimbing. The CAMS newsletter had arrived in the mail and there was an item on the upcoming Australian Hillclimb Championships at Grafton in six and a half weeks and not being one to procrastinate, the decision was made then and there to go for it! The only problem being that companion Jo Smith's car had sustained a huge prang at Bathurst back in 1990 and desperately needed some attention. On that occasion, the fan had exploded at 8000 rev's, taken out the accelerator cable tube and jammed the Dellorto's flat out as she was approaching The Dipper.
Well, what can i say, fate was really kind not to roll her over. (the car that is) so there was no body damage but three corners of the suspension were badly bent and the right hand front shock tower had put a 50mm deep dent into the inner guard.
The car had then been retired to a relative's farm at Binnaway, and suffered the indignity of sitting in a barn there and accumulating a solid layer of bird poo while it sat forlornly in the the farm shed. I took a quick trip to Binnaway one day and loaded the very bent bug onto a trailer and then took it home the next day- all without incident. I was very lucky to have three untiring helpers in the form of James McKinnon, Grant Camper and Shimo.
Previously we had raced the "Bug out of Hell" in the road registered class and later as a sports sedan. Times had changed however and with the introduction of the group 2E Silhouette Class i,e 60 series tyres, no 'glass guards and a maximum seven inch rim size for cars up to 3000cc.
This formula posed a couple of problems. Firstly our old gearing was too tall (the 3.88:1 diff, 3.4:1 1st, 2.21:1 2nd, 1.48:1 3rd and 1.125:1 top were nowhere near close enough) and secondly, we had no 60-series tyres because back in the '80s we used 50-series.
As it turned out we had bought and old drag race gearbox earlier in the year, so we had a few extra ratios to choose from (this included 4.375:1 ring and pinion and 3.8:1, 2.06:1, 1.58:1 and 1.21:1 gears). In the end we came up with a great little close ratio 'box using the 4.375:1 diff gears and 3.4:1, 2.21:1, 1.58:1 and 1.21:1 gear ratios which worked in really well with the 205-60X15 tyres.
There was a huge list of chores to complete before we headed to Grafton. This included stealing the front end out of the old race car, replacing wheel bearings, tie rod ends, ball joints and control arms, recondition the calipers and fit new metal pads. other tasks undertaken including replacing steering coupler and dampner, fitting a race seat, harness and half cage.
Next we rebuilt the entire rear end, bushes and breaks and then stripped down several gear boxes to salvage the required parts to make up one good unit.
The 1904cc motor was stripped and freshed up ready to be raced. We then went over to Eastcoast suspension for a 4 wheel allignment and then back home to fit the sway bars ( 20mm front and 22mm rear ).
We then packed up all the spares and headed off for Grafton ( a day before practice started Jamo and Grant drove up and met me there on Thursday morning )
Grafton's track had been lengthened, resurfaced and was alot tighter than what I could remember from 5 years earlier so I had the car scrutineered early to be one of the first cars out onto the track. Even though the track was a bit green ( leaves and branches littered the track and no rubber had yet been laid down ) , I was still quite happy with how the borrowed rubber was gripping. I was only about 3 seconds off the old record.
A quick check of the tyre pressures and off I went again, this time really getting the feel back again and throwing the car around like a Formula one car when suddenly the oil light came on. I turned it straight off and coasted down the return road. When we pulled the Oberg filter apart there were parts of a big end bearing straing at me. It appeared that we should have put the oil surge gates back in from our old Hellbug motor as now the sticky tyres were generating the same G-forces as the soft slicks I ran before.
There was a fair bit of dissappointment in the camp. In fact, Grant and Jamo were shattered. I ended up driving to Kempsey, taking a 1916cc motor out of a buggy and fitting up our Webers. But alas the off-road motor had an inappropriate cam and didnt really go. We managed a last-in-class finish and the distinction at being the only vehicle unable to spin the wheels off the start line. At this stage I must thank Mark and Luke Pell for their help with all our problems over that weekend. It was their motor that was so generously lent to me.
BACK TO THE OLD DRAWING BOARD
Not to be put off by such small hassles I had the motor rebuilt in 2 weeks ( this time with all the baffling in the sump ). And competed in the show and climb at Canberra winning the class, being 2nd outright and the fastest Group 2E bug. Now we were cooking and competed in 5 more 'climbs before Christmas managing class wins in each of. So the poor little motor was owed a bit of work by the time the years racing was complete.
Upon this assembly some very interesting observations were made: 1: The tunnel of the case had worn out allowing the centre main bearing to move and the crankshaft to flex. 2: Some evidence of oil starvation was still present in rod bearings #1 and #4 and: 3: The breather system had not been adequate because the 2.0-litre catch-tank was always filling with oil at the end of each days racing.
After a meeting with Shimmo and Peter Gonad, a complete revamp of the breathing and oil system commenced. This was a two-pronged attack to ensure that I had adequate breathing as well as adequate oil in the pick-up area (deep sump centre ).
I had purchased a late-model AS21 fuel injection case ( with the huge oil galleries throughout ) from Gene Berg in 1989 as a back-up for the 2213cc motor. This already had all the machining done, i.e. decked , bored for 90.5mm barrels, fully flowed, 8mm case stud nut lands spot-faced for the 15mm head nut conversion and die ground to fit a Washington Antishocker.
To increase the breathing of the internals, a 32mm hole was machined where the fuel pump hole should have been ( PI* case remember! ) I then fabricated a baffled breather tube and fitted a motorcycle air cleaner to stop dust getting in.
The rocket cover breathers were increased from 3/8" i.d to 3/4" i.d and a small baffle plate brazed over the breather outlet hole on the cover. This then necessitated enlarging the breather pipes on the Berg breather box-cum-oil-air filter to take the larger hose. Another motor cycle air filter was used on top of the Berg breather to stop any restriction in the system.
As far as oiling went this was somewhat more perplexing and a lot of testing and rethinking was needed before the final tolerances was initiated. A deep sump already had a quadrangle set-up with flapper valves so that the oil in the sump could only find its way from the four outer corners into the central pick-up area. The only thing that could possibly stuff this up would be if the oil wasnt returning to the sump fast enough.
As the oil pressure had always been adequate ( when the oil was there to suck up ) at 700kpa at 7000rpm with a 30mm Berg pump. When fitting a larger oil pump you not only get a higher pressure but also a much larger volume. therefore, if we cut down the volume being pumped then it will take longer to drain the 3.5 litres in the sump giving us a few extra seconds of supply before we run dry. A 26mm very plugged oil pump was fitted as a result of this logic.
How to get more oil into the deep sump?
Once again a two-pronged attack was required. A new oil pick up was bent with open flowing bands so that there was no added weld-on parts that picked up the oil in the sump. The hood that normally went over the oil strainer area was also not used so that the oil in the engine sump had a much larger area to fall through.
As I always ran the oil level at the top mark of the dip stick and already used windage push rod tubes, the premise was that a fair bit of oil was sitting in the rocker cover area ( because we could not stop the oil from running up the push rod tubes on very hard cornering ) A quick look at Col Matthews' porsche to see what "Big Brother" was using gave us the answer. Two 0.75in. oil returns were fabricated on the bottom of each rocker cover going straight down into the top of each of the sumps four corners. Voila!
As it turned out this system has worked perfectly with the main bearings and CAM bearings being only changed annually and the rod bearings at half yearly intervals.
Now that the engine reliability problems had been solved we went about a full revamp of the steering and suspension set ups. Its funny how the fickle finger of fate changes from the "you beaut" thumbs up of success to the heavenly - pointed middle finger of dispair in a matter of seconds.
friday nights trip to the first rund of the Hillclimb Championships at Bathurst was miserable weather, rain, sleet, fog - everything you'd expect going to Bathurst. When we got to the top of River Lett Hill doing about 80 clicks around an 80-rated corner while flat-towing the bug on an A-frame behind the ute, I felt the tail of the ute come out. After a big correction I thought I'd saved it only then to pirouette 360 degrees followed by a 180-degree turnaroundand finish up against an embankment. In the olympics that stunt would have gained me a series of 9.5's from the judges as it was all we achieved was some battered suspension and sheetmetal.
The left-hand front wheel from Joe's carhad come around and hit the left-hand rear wheel of the ute. I had to disconnect the buckled A-frame and flat tow the Beetle into Bathurst with a wire sling. By ten the next morning we had a wheel alignment done, tyres changed over to some non-buckled wheels and a trip to the panel beater to have the bumper and damaged guard knocked out so that I could race.
Meanwhile, the right-hand rear trailing arm was still bent with 2.5 degrees positive camber instead of 1.5 negative, but we still managed to take the class win and set a new record on the day.
This little last adventure was probably the main turning point that helped me change the handling set-up of the car forever. As the beam was bent a tad I did the first of our camber restorations on the top arms and dialled in a two-degree negative per side and the car loved it.
I then got to thinking, "How much negative camber can a Beetle take before it gets totally out of hand?"
They say nothing improves the breed like racing and after one full year of Hillclimbing I now have all the formulas for setting up and making a car handle straight out of the box. By "handle" I mean being able to take on just about any street car on the road today and wave goodbye to them when you come to corners. We atarted off the year 35th outright at Bathurst and peaked at 10th outright at Huntley in 1993 and to say the team is having a ball is an understatement.
Once the handling and braking has been taken care of you can then concentrate on more engine development. The motor now sports 44 x 37.5 Berg race heads and extensively modified ( by Henry Spicak ) 48mm Webers. The big change for 1994 had beenthe fitting of a GB 315 ( FK87 ) camshaft as opposed to the old GB311 ( K10 ) on the 112 lobe centres which were set-up retarded.
This one change took .6-second off our eighth mile drag racing times ( 8.9 to 8.3- sec ) and added 9km/h to the terminal speed.
This yarn is being written just before Parkes Hillclimb championship round, so the motor is once again apart but more for a freshen up and re cam to a GB 316 ( FK 89 ).
All these changes have made the Bridgestone 610s unable to cope so a change to gumball Dunlop 78Js should help us to stick. And it will keep on going like this, trying to screw that extra little bit out of the Bug. Because one day it would be nice to go to South Australia to run the class at the Australian Hillclimb Championships and then blow all those twin cam Datsuns away.
We work on the theory that the harder you work the luckier you get.
http://i31.photobucket.com/albums/c365/dumone/P1000265Small.jpg
MemberVWCOOL
Threads: 235
Mood: happy to help
posted on June 6th, 2007 at 11:59 PM
yeah, I remember that from Jeff's car a while back, but Jeff's car appeared fumy. Could this have possibly been due to surge of oil UP the drain-back pipes and leaking out the rocker gaskets?
Is there any way you could fit some sort of flapper/one-way valve in the tubes?
[ Edited on 7-6-2007 by VWCOOL ]
Memberjohny rotten
posted on June 7th, 2007 at 10:18 AM
Blahh
Quote Glen T..............And Jeff's car always was 'fumy'...
end Quote
WTF thats suppose to mean Glen ?
I think your fuming at the mouth again.
[ Edited on 7-6-2007 by johny rotten ]
Member555bug
WRX Bug Boy
Threads: 79
Theme: UltimaBB Vintage
Mood: turbo charged
posted on June 7th, 2007 at 08:54 PM
1) top job
2) what sort of compressor do you have that lets you port for such long periods?
3) any advice on carbide bits after your 100's of hours?
hope it goes like stink
Stephen
Memberhellbugged
A.k.a.: Daimo Pell
posted on June 18th, 2007 at 06:34 PM
thanx.
to answer your questions.......
a bloody great big 3 phase compressor at 120psi. i was a bit worried today when it didn't need to "top up" for 1/2 an hour, thought it was broken:rolleyes:....
http://i31.photobucket.com/albums/c365/dumone/Picture081Small.jpg
carbide burrs.....i like the ones with rounded tips as they don't leave big edges. you can take a lot of material out with flapper wheels which are relatively easy going. turn your rotary grinder down so it runs slowly at full throttle.ear muffs, safety glasses and lots of clothing.
don't try and use a bit that makes a particular job hard/risky, if you can, stop and swap it for a more suitable one from your selection :smirk:..........
http://i31.photobucket.com/albums/c365/dumone/Picture082Small.jpg
it should run strong.........if it doesn't...........it's nothing EFI, turbo and intercooling won't fix:cool:
[ Edited on 18-6-07 by dumone ]
Memberhellbugged
A.k.a.: Daimo Pell
posted on June 18th, 2007 at 07:03 PM
VWCOOL
i hear what your saying. looked at non return valves, nothing off the shelf that i found for it. many schemes have been nutted about
the fittings in the sump protrude well into it so oil doesn't flow up the walls and into them. the return side of fittings are "ported" to a knife edge. as are the openings in the rocker covers
i'm finding the starvation (oil light on) is happening as i come out of the corners and approach full revs for the first time, not in the middle of the corner (maybe this relates to my driving style). i'm using windage pushrod tubes allready, so the thoughts are that the oil is running up to the rocker area via the pushrod tubes despite. as i reach full engine noise after/in the corners the LAST REMAING oil in the sump gets pumped away..........because the oil still gathered up in the rocker covers has not got a direct/quick enough return to the oil pick up area.......
so if we can get ANY more oil back to the sump before it goes dry, it may just be enough to keep pressure for that second or two until the cornering subsides and oil is again gathering at the pick up tube area.
i might baffle the sump or lines yet.....maybe just borrow Jeffs:punk:
yes it's a hard one to get round in ya brain.
it's done now....we will see.....
http://i31.photobucket.com/albums/c365/dumone/Picture078Small.jpg
http://i31.photobucket.com/albums/c365/dumone/Picture079Small-1.jpg
the 1/2 inch oil fitting was drilled out as large as possible to help breathing too
http://i31.photobucket.com/albums/c365/dumone/Picture080Small-1.jpg
http://i31.photobucket.com/albums/c365/dumone/Picture085Small.jpg
http://i31.photobucket.com/albums/c365/dumone/Picture077Small.jpg
clearance is good......not too much.not too 'lil:thumb
http://i31.photobucket.com/albums/c365/dumone/Picture076Small-1.jpg
theres not much choice for where the returns go....
http://i31.photobucket.com/albums/c365/dumone/Picture087Small-1.jpg
getting around the exhaust and tin wear would be difficult
http://i31.photobucket.com/albums/c365/dumone/Picture088Small.jpg
SPAGHETTI:yes:
http://i31.photobucket.com/albums/c365/dumone/Picture089Small.jpg
it's all tucked up above sump level tho.......
http://i31.photobucket.com/albums/c365/dumone/Picture092Small.jpg
http://i31.photobucket.com/albums/c365/dumone/Picture093Small-1.jpg
Memberbond
Threads: 166
posted on June 18th, 2007 at 08:55 PM
looks the goods man! question - will the piping between the tappet covers and the sump require fastening with s/s clamps to the fittings? is it under much pressure?
nick
Memberhellbugged
A.k.a.: Daimo Pell
posted on June 18th, 2007 at 09:27 PM
yes there will be hose clamps at both ends.
there is no pressure at all, simply 3/4 inch gravity fed return lines. an alternative route for returning oil aside from the pushrod tubes.
(C) 2001-2024 Aussieveedubbers
[ Queries: 40 ] [ PHP: 10.9% - SQL: 89.1% ]
