[ Total Views: 9542 | Total Replies: 90 | Thread Id: 101815 ] |
Pages: 1 2 3 4 |
matberry
posted on November 18th, 2013 at 10:29 PM |
I'd say it is std height. I have a beautiful camper here now, handled like shit on the hiway so I checked the REAR alignment.....15mm toe-out !!!!
The owner had no idea...."it's a kombi" they say !!
DubbyDo
A.k.a.: Dave
Threads: 45
Mood: need more compreshunn!
posted on December 4th, 2013 at 09:13 PM |
Found the reason for the loftiness, has had plates welded to the beam mounts, going to see if I can drop it back into the original holes, fingers
crossed. Also the guy who sold it to me said it was a rebuilt 2L but the engine suffix is CA which from what I can see on th interweb is a 1700. Are
these like type 1 engines where it is a straight forward crank and barrel change to get the extra capacity?
Error |
DubbyDo
A.k.a.: Dave
Threads: 45
posted on December 4th, 2013 at 09:15 PM |
Squashed up pic but its nearly 3" between the bolts and the original holes
matberry
posted on December 5th, 2013 at 11:05 AM |
Engine # on the actual block can be different to the one on the fan hsg, so check the one to the rear of the clip-on breather on the top of the
engine.
Change crank, rods and pistons/barrels to mahe a 1.7/1.8 into a 2.0
DubbyDo
A.k.a.: Dave
Threads: 45
posted on December 7th, 2013 at 10:13 PM |
Started doing the tune up and found some massive vac leaks in both throttle shafts, need to get some new carbs of some sort solex or webers. Does
anyone have a set of carbs that are in good nick for a 1.7/1.8L?
DubbyDo
A.k.a.: Dave
Threads: 45
posted on December 7th, 2013 at 10:17 PM |
On a side note, have been driving the kombi around for the last couple of days and can't wait to jump back in the Beetle for a squirt when it gets
down here. The 1641cc is gonna feel like the King of Speed
matberry
posted on December 7th, 2013 at 10:39 PM |
I have a new set of 40 IDF Webers for type 4 available if you want to go that way Dave.
DubbyDo
A.k.a.: Dave
Threads: 45
posted on December 8th, 2013 at 12:23 PM |
Sorry Matt, pics wouldn't load via pm so here they are.
Got underneath and found that due to the rear being raised almost as high as it can go the cv boot s have split, found receipts in glove box for at
least 2 more sets of boot Replacements in the last couple of years. Guessing having angles like that won't be helping with the lack of power either!
Error |
Error |
Error |
DubbyDo
A.k.a.: Dave
Threads: 45
posted on December 8th, 2013 at 12:26 PM |
The air up there
Anyone have an oxygen mask???
Error |
matberry
posted on December 8th, 2013 at 01:02 PM |
Hey Dave, the gear shift bush is further fwd, at the end of the shift rod.
DubbyDo
A.k.a.: Dave
Threads: 45
posted on December 12th, 2013 at 06:59 AM |
The farm is starting to look like a cool place to be don't think
the in laws are as happy as me, then again, they are Subaru people so they just don't get it.
Back to the origin of this thread, Sanity. Looking decidedly shaky at this stage, finding more and more that needs to be done and time is flying by.
Picked up our new trailer the other day which also needs decking out and our 2 kids who are turning into bigger ratbags every day. Will be interesting
to see if we can hold it together and get it finished before the ferry leaves to Tassie
Error |
matberry
posted on December 12th, 2013 at 08:26 AM |
Progressing....... good luck with it all Dave
Scottkombi
Mood: Sick of Work
posted on December 12th, 2013 at 08:49 PM |
Love it - a true test of a blokes stamina (and marriage!)
88 Caravelle Syncro Camper
89 Caravelle GL microbus - 5 speed
69 Microbus
05 Mk5 Golf 1.9 TDi DSG
DubbyDo
A.k.a.: Dave
Threads: 45
posted on December 16th, 2013 at 06:40 PM |
Did a trial run towing the trailer today, had to move furniture and crap from the farm into Casino to the storage shed, Kombi was pretty much packed
to the roofline and the trailer was jammed full. You could hardly tell the difference, which is good because its not starting from a bar set too high.
All up there was way more weight than what we will be taking on our trip so things are looking up.
Except when I shut the sliding door the little lock hooks all broke off and now the front left wheel bearing is rumbling, seems I find some new issue every time I touch it. Shhh, don't tell the
missus but I do like the excuse to fix things so our trip goes smoother
mnsKmobi
Threads: 27
posted on December 17th, 2013 at 12:11 PM |
Quote: | Originally
posted by matberry
engine.
It also could be a 2l with a 1700 case. Only way to be sure is to take a head off and measure the bore and stroke. See here for stock values:
http://www.tunacan.net/t4/reference/displace.shtml
From that table you can also see that if you do have the stock 1700 you can go all the way to 1832 by replacing your p&c's with 2l ones!
matberry
posted on December 17th, 2013 at 12:36 PM |
^^ no you can't, piston pin ht. is different and dish is different which will lower the CR
DubbyDo
A.k.a.: Dave
Threads: 45
posted on December 17th, 2013 at 05:13 PM |
Have the receipt with parts fitted from vintage vee dub, had new 93mm pistons and barrels fitted when it was rebuilt, this makes it 1800 at the most
DubbyDo
A.k.a.: Dave
Threads: 45
posted on December 25th, 2013 at 06:21 PM |
Beetle now in storage after a great run from Lismore to Coolum and back, no issues and more than enough grunt to keep with modern traffic ( passing a
lot of it, within the speed limit of course) and looking a hell
of a lot cooler than a Dunnydore or Foulcan with 50" chrome rims and a sound system straight out of a nightclub.
First thing to do was pull the IDF's off an fit them to the Kombi. Aaaaahhhhh, I found the missing horsepowers, woohoo. Pulls a lot better in top and
the engine bay looks groovy, now just need some straight cuts and a bigger cam
DubbyDo
A.k.a.: Dave
Threads: 45
posted on December 25th, 2013 at 06:36 PM |
And Merry Christmas to everyone, hope you all get a chance to enjoy your Vee Dubs in one way or another over this couple of festive weeks
DubbyDo
A.k.a.: Dave
Threads: 45
posted on December 25th, 2013 at 08:27 PM |
Hah, after years of doing it I finally get to do a "Field Service"
Error |
DubbyDo
A.k.a.: Dave
Threads: 45
posted on January 3rd, 2014 at 12:19 PM |
Can anyone in Devonport/Launceston area repair a Komkbi box that is jumping out of fourth so bad that you cant even hold it in?
DubbyDo
A.k.a.: Dave
Threads: 45
posted on February 7th, 2014 at 09:29 PM |
Been a while, found a new gearbox through family of people we visited in Devonport(luck didn't transfer to the lotto ticket) fitted it and have done
the last 5weeks almost driving all over the place with no hiccups at all. Down the guts to Southport/Ida Bay, across to Strahan then back down the
guts to Cygnet and lastly up the east coast to Bicheno, in Launceston now for the next 3 nights then back on the boat to start the next stage. Tassie
is the best place to go Kombi touring ( without a trailer for the under 2L's!!!)
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
posted on February 8th, 2014 at 09:22 AM |
Glad the gearbox went well dude
Tassie is a magic place to tour.
DubbyDo
A.k.a.: Dave
Threads: 45
posted on May 29th, 2014 at 05:28 PM |
Been a while, made it back up to Darwin via Glasshouse Mountains, Tin Can Bay and Gladstone. Rebuilt a 2L before we left and it is pulling the Kombi
and box trailer like a trooper! However, the 6 rib box is getting louder and louder(bearings, what is it with this kombi and gearboxes?).
After 6 months with 4 of them spent living out of it I am getting closer to the answer of the original question, we still have our sanity but it is
getting shaky! I think, for us anyway, 12 months is a bit ambitious with the 2 kids, 3 months is probably a more realistic holiday. Saying that it is
without a doubt one of the best things we have done, passing another Kombi and getting the big smiles and waves just out of Elliot(NT middle of
nowhere) was the ducks nuts!
vassy66T1
A.k.a.: Marcus Vass
posted on May 30th, 2014 at 07:49 AM |
Awesome!!
I agree 12 months with the whole fam bam is a bit of a stretch
DubbyDo
A.k.a.: Dave
Threads: 45
posted on October 16th, 2014 at 12:21 AM |
In Denmark WA nearly ready to take on the final stretch back to the East coast, Oz has got so much to see and do 1 year isn't nearly enough. We have
found the answer to our original question though, house sitting and lots of it. Every time we pull up now the kids ask if we are staying in a cabin!!! They have grown so much since we started last
December, they don't even fit in the pop top anymore so have to sleep on the floor, till 3am anyway when they crawl into our bed.......
DubbyDo
A.k.a.: Dave
Threads: 45
posted on November 9th, 2014 at 11:26 AM |
So, after 20000+ kms and only 588 from home the dreaded valve recession has caught me. Just going onto the tow truck now. BUGGER
DubbyDo
A.k.a.: Dave
Threads: 45
posted on November 9th, 2014 at 12:01 PM |
Sad as I am not to be doing the last leg in it the A/C in the truck is beautiful on this stinker of a day.
Error |
vassy66T1
A.k.a.: Marcus Vass
posted on November 10th, 2014 at 07:11 AM |
Epic!
Shame it couldn't hang on just a bit longer
DubbyDo
A.k.a.: Dave
Threads: 45
posted on May 20th, 2017 at 11:11 PM |
Quote: | Originally
posted by tar76
Make sure the young ones can see out the windows...they are not blocked by cupboards and cap gear. My old panel use to drive my grommies nuts as they
couldn't see, and long trips they would get very bored quickly and car sick!
Not sure if you are still on here, been a while for me too but was just randomly browsing through this post and your comment cracked me up. After
doing almost all of Tassie twice and anti clockwise round the mainland we bought the missus a new car in Dubbo. the kids jumped in it for the trip to
the Blue mountains to stay with family when she asked them what was the best sight of the trip to which they replied "the Blue Mountains, couldnt see
anything else!!!". note to self, put proper windows in if using a panel van for a camping trip again
Pages: 1 2 3 4 |
