[ Total Views: 25657 | Total Replies: 315 | Thread Id: 102601 ] |
Pages: 1 2 3 4 .. 11 |
vduboy
Threads: 41
Mood: Dying to get more buggy building time..
posted on August 18th, 2013 at 08:14 PM |
Sweet sounds like a plan, thanks! My 930cv's are coming over with the Manxter kit so ill be busy when that all arrives! I thought i might be able to
cut the lower mount of and flip it so it will now sit inside but higher if that makes sense? Time will tell when I start mocking it all up. How are
the tow'ds coming along?
It will all be OK in the end, if it's not OK it's not the end!
vduboy
Threads: 41
posted on August 20th, 2013 at 09:17 PM |
Nate's Manxter Build
Hey guys thought I'd post some pics as everyone loves pictures..
Re shimmed crank all back together,
Guido spec gold pushrod tubes..
Csp linkages, very smooth, makes the stock kadron ones feel pretty crappy
Error |
Error |
Error |
vduboy
Threads: 41
posted on August 20th, 2013 at 09:27 PM |
Trailing arms all stripped and ready for me to learn how to paint on!
And the reason I havent been getting much buggy stuff done, had to do a freshen up on the top end of my dirt bike, gotta love two strokes, rebuild the
top end for less than $300! Apart and rebuilt in less than two hours including straightening all the bent bits!
Error |
Error |
vduboy
Threads: 41
posted on August 25th, 2013 at 09:11 PM |
Hi Guys,
Got a little more done on the motor this weekend, removed the deep sump I had fitted to the motor while it was still in my daily, fixed a few nagging
oil leaks, flywheel seal, fitted new fully sick pushrod tubes and added a few gaskets under the fuel pump to drop the pressure a tad as it was always
quite high.
Error |
Error |
vduboy
Threads: 41
posted on August 25th, 2013 at 09:12 PM |
Now where did I put my engine stands...
Error |
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on August 25th, 2013 at 09:14 PM |
Pretty
vduboy
Threads: 41
posted on August 25th, 2013 at 09:15 PM |
Also trimmed down the cylinder tinware and welded back in the bits with the cylinder numbers. Also welded up the holes for the thermostats? I have
never had a bug with them fitted!
Looks much neater now
Error |
Error |
vduboy
Threads: 41
posted on September 19th, 2013 at 08:23 PM |
Hi guys been a bit busy playing dirt bikes, had a two day ride so had to get my bike and all the mates bikes sorted as well, got a little buggy stuff done, removed the deep sump and swapped it for
a CB pump with the outlets for the external filter, Cheers CT, will do a proper full flow of the case when it requires open heart surgery. I see why
people don't like the in/out pumps as they are quite restrictive, fixed a few dags up with the die grinder so it flows a little better.
I also had to press the shaft through the drive gear so it had more than 1mm engagement with the cam...
Apart from that the kit should arrive at mine on Monday so should finally have some pics of MY Manxter to post!
vduboy
Threads: 41
posted on September 24th, 2013 at 11:22 AM |
So bit of a crappy update... The bar work wasn't quite ready so that pushed back pick up for a week or so Which I was cool with as I got told about
it, (but got an earful from the freight company) and I find out yesterday that the useless freight company didn't pick up my kit because the pallet
didn't have wheels!! After telling them multiple times they'd need a tail lift and a pallet jack! Now I'm probably going to get stung for storage until the useless twats can come back to get it! And the poor guys
have to walk around my kit for another week...
I might get to see it eventually...
Craig Torrens
Threads: 347
posted on September 24th, 2013 at 02:40 PM |
Bummer re the barwork.
Full flow the case when you do a cam change
vduboy
Threads: 41
posted on September 24th, 2013 at 02:52 PM |
Quote: | Originally
posted by Craig Torrens
Yeah that's the plan. Ill use the life out of this motor first though! I had to reshim the crank the other day though, unsure why.. the bearing had
no play whatsoever, maybe the shims wearing? All good now!
Craig Torrens
Threads: 347
posted on September 24th, 2013 at 05:33 PM |
How much end float did it have ?
vduboy
Threads: 41
posted on September 24th, 2013 at 06:04 PM |
I had 0.15mm, possibly a little more, set it back to 0.10mm
vduboy
Threads: 41
posted on September 29th, 2013 at 08:17 PM |
Hi Guys, the wifey is away on holidays so I get to play buggy building for a whole week with out nagging! I thought I'd get some paint on the
floorpan this weekend.. boy was I wrong. I still had a heap of welding to do, pulled the other seat mount off the original pan half, welded up the
spots where I was a bit enthusiastic with the spotweld drill..
Made up a few little biscuit shaped bits to weld up the outer napoleon hat bolt holes, also a few for underneath. Ill fill this with fish oil to keep
the rust gremlins at bay.
Cut of the heater cable outlets in the frame horns then stitch welded them for some strength. Gave the whole pan a pretty good wire wheel, and killed
my ozito grinder, you just cannot get quality for 26 bucks anymore. Only got 15 years out of it too!
Error |
Error |
Error |
vduboy
Threads: 41
posted on September 29th, 2013 at 08:18 PM |
And here is the stitch welded frame horn, had to dig through a pot load of atf sludge just to see it!
Error |
vduboy
Threads: 41
posted on October 8th, 2013 at 11:26 AM |
Its here! Finally! All tucked away in the garage, haven't had a chance to unpack it yet... Already got a nice gouge in the front guard.. not
impressed, at least I don't have to worry about christening
it now.
Will get stuck in when I get home and start unwrapping all the goodies and get some piccy's up.
vduboy
Threads: 41
posted on October 8th, 2013 at 11:31 AM |
it now.
vduboy
Threads: 41
posted on October 9th, 2013 at 08:50 PM |
So finally got to spray my floorpan, have been avoiding that like the plague.. but my first go at spray painting turned out all right.
But before I threw some paint at it this fell out of the tunnel...
The bloody clamp for the handbrake cable...
So I found the spot weld drilled and tapped it for a 5mm allen bolt and got my skinny arm up the bum of the chassis bolted it in from the inside out
then welded the bolt in place.
Error |
Error |
Error |
vduboy
Threads: 41
posted on October 9th, 2013 at 08:52 PM |
And then...
This arrived!
Error |
vduboy
Threads: 41
posted on October 9th, 2013 at 08:53 PM |
How sexy is that cage and barwork? Awesome welding on all of it..
Error |
Error |
vduboy
Threads: 41
posted on October 9th, 2013 at 08:55 PM |
My wife wanted to be the first person in the car.. she was also the first the bang her head on the roll cage!!
Error |
Craig Torrens
Threads: 347
posted on October 9th, 2013 at 10:22 PM |
she probably wished that her first "bang" in the car would have been kinda different to that ?!
vduboy
Threads: 41
posted on October 10th, 2013 at 06:44 AM |
Hahaha that's disgusting Craig, they pee from that...
baghall
Ben Hal Outlaw Bushranger
Threads: 131
Mood: Kids think I'm obsessed!
posted on October 10th, 2013 at 09:03 PM |
This is gonna be cool, looking forward to the finished product.
68 Baja - It's a growing pain!
58 Baja ute - and the pain spreads!
85 T3 Kombi - still growing
89 T3 Kombi - parts car
vduboy
Threads: 41
posted on October 11th, 2013 at 11:09 AM |
Quote: | Originally
posted by baghall
Cheers thanks mate. Just going through with the engineer now in regards to what he wants done to the chassis stiffener/lift kit with crush tubes etc.
vduboy
Threads: 41
posted on October 14th, 2013 at 09:27 PM |
nate's Manxter Build
Well I couldn't leave that awesome bar work naked so I got stuck in and got it all in primer. Also got the chance to coat the pan in the raptor
lining, that stuff is so fantastic, it makes my first spraying attempt look professional! Really happy with it, cheers Ben and Brad from MMA for
getting me onto it.
Also got the engineer driving up from the gong to check it all out mainly how he wants the chassis stiffener bolted up so far he sounds really
promising. Well thats all for now ill get some pics up..
Error |
Error |
Error |
Craig Torrens
Threads: 347
posted on October 14th, 2013 at 09:37 PM |
I like the paint on the pan.
vduboy
Threads: 41
posted on October 15th, 2013 at 08:30 AM |
Me too, was really pleased with it, so easy to spray on too.
vduboy
Threads: 41
posted on October 17th, 2013 at 06:20 PM |
So just had the engineer come round and check out the project.. good news all happy with it. He wants crush tubes through every hole in the chassis
stiffener which will be a lot of work but it'll pass with flying colours he thinks. He is also happy to try and push for the maximum tyre size
allowed which is good. And would like an upgrade to discs on the rear so Ill send him the specs of the disc kit I have and he will go through it for
me. Finally found a engineer that doesn't have his head up his ass...
On the down side my chassis stiffener wasn't quite welded at the right angle over the rear of the pan so that has to be sent back to be rejigged.
But it's all good I still have a few things to do...
vduboy
Threads: 41
posted on October 23rd, 2013 at 07:37 PM |
Been busy painting... sick to death of being in that plastic room! But the bar work came out nice. Not as satin black as i'd hoped its more glossy in
real life. I probably used the wrong thinners..
Am going to try and suss out which direction to go with my hydraulic clutch conversion. I have a few ideas now thanks to the guys who gave some
ideas.
Also started to fix the lift kit so the angles match up at the rear of the pan.
Error |
