[ Total Views: 26326 | Total Replies: 144 | Thread Id: 105111 ] |
Pages: 1 2 3 4 5 |
modnrod
Threads: 50
Mood: Old School Volksies!
posted on January 25th, 2015 at 01:48 PM |
OIL FILTERS
Most people use a full-flow set-up, by drilling holes in cases, clearancing tinware, trying to keep the oil lines away from the exhaust, running long
dangling wobbly unprotected oil lines to a cooler near the gearbox, trying to protect the oil filter from being knocked off by reversing into a kerb,
etc.
I like bypass oil filter set-ups because they filter down to less than 5 micron, as opposed to well over 40-50 micron for your average Mann/Ryco/OEM,
etc, oh and coz it reminds me of my uncle's Oval street racer from the 70s . They can also badly restrict oil flow though unfortunately, you have to run them off a separate small oil line from your oil
pressure switch so it takes ages to eventually filter all the oil (when it has done though, the oil is C-L-E-E-E-A-N-N-N).
Readily available now in the heavy machinery world is a spin-on oil filter that now does both! COOL! It works as a normal spin-on oil filter, but has
a very fine 5 micron bypass oil filter section built-in to the canister. Bloody lovely!
Here we have a filter head, a thermostatic spin-on sandwich plate, and a few brass fittings that will end up in the garden somewhere where brass
fitting belong no doubt (I prefer JIC stuff and hefty hydraulic crimps).
(PS: Note the gratuitous free plug for Brad at Bus'n'Bug in the pic, he sent me a free sample in the post of VW Off White headliner material, thanks
man!)
Where to mount it though?
Well, in my case I don't need the stock doghouse cooler, as I want to use all the airflow available to get to the heads (aaahhhh, but that's another
cunning plan Baldrick! ), so a good old-fashioned 70s-style bypass
adaptor will get oil out of the top of the case with really short protected lines.
See that little mounting area on the top middle of pic for the stock OEM electrical test plug?
Well bugger me, the holes even line up.........
Yep, that's the size of the filter (with the part number on it if you want to investigate these new dual-flow filters to maybe suit your own
application...........). It also holds a heap more oil.
Why do all this when the stock engine strainer will get a stock ACVW past the 100K km mark? Uhhmmm, damn good question!
modnrod
Threads: 50
posted on March 6th, 2015 at 05:19 PM |
A friend in the next town said he had a lathe and a mill, maybe we could use them to get some of the engine parts ready at home instead of the 350km
trip to a machinist.
Lathe.
Barrels, pistons, crankshaft, carb venturis (WOW! Is that overkill or what! )
Mill (he has 3 of them, different sizes).
Heads, cases, flycutting, etc.
We might need to send out the case for line boring maybe, not sure yet.
Even if we royally screw it all up, we can keep having a go until we get it right!
modnrod
Threads: 50
posted on March 8th, 2015 at 07:42 PM |
modnrod
Threads: 50
posted on March 15th, 2015 at 07:09 PM |
modnrod
Threads: 50
posted on March 24th, 2015 at 09:49 PM |
No more Flintstones.........
Of course, seat rails and seats would be preferable to a milk crate.
modnrod
Threads: 50
posted on March 25th, 2015 at 04:06 PM |
No more milk crate!
Woo!hoo!hoo!Hoooooo!
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on March 25th, 2015 at 04:41 PM |
Crikey, what are feeding the 'apprentice' ? He's growing like crazy.
Treasure those days, mate...they grow up so fast. My boys are 47 & 49, and I don't know where the years have gone.
modnrod
Threads: 50
posted on March 25th, 2015 at 08:50 PM |
Thanks Greg!
The big TA is 6, the little one is 3.
Must be something in the water.......
Regards,
Dave
modnrod
Threads: 50
posted on March 30th, 2015 at 07:18 PM |
Really bummed out
I am SSOOOO sick of welding on this f@&n thing.
Outside........
Inside.........
Doug Sweetman
Nil Bastardo Carborundum
Threads: 58
Mood: sweeeeet
posted on March 30th, 2015 at 10:59 PM |
Ouch.... Been there, done that on my 73. I'd like to meet who at vw thought it was a great idea to put that foam up there.....
modnrod
Threads: 50
posted on April 9th, 2015 at 07:24 PM |
1, 2, 3......
Step 1.
Put a sticker on the motor to cheer me up.
Step 2.
Discover the cause of the fire that led to it's transport to the wrecker (where I was able to save it).
Eeeeuuuuwwwww.
Step 3.
Carefully dismantle to try to save the stock pistons for a quick re-ring, to try to save the heads for a quick valve re-grind, etc, etc.
Yeah right!
At the moment I'm thinking about upping my plans to possibly change things from a mild 1584cc to a torquey 1760cc or 1807cc (74/76 x 87 bore).
Hhhmmmmmm...........
adlbeetle66
A.k.a.: Denver
Under the car.........again!
Threads: 98
Mood: ICH BIN VW NUSS
posted on April 9th, 2015 at 07:54 PM |
MMMM.....
modnrod
Threads: 50
posted on April 15th, 2015 at 03:28 PM |
Shed clean up
A few bits and pieces I found from the good-old-days.
A good time was had by all!
modnrod
Threads: 50
posted on April 22nd, 2015 at 09:49 PM |
Engine Balancer Puller
modnrod
Threads: 50
posted on May 11th, 2015 at 04:43 PM |
20 years ago I would have rolled this Superbug down to the Lions scrap metal yard, then gone out and bought a cheapy early-70s Kombi to get to work in
until I could find another straight Bug for a hot streeter..
My how times change hey?
*sigh* OK, Lets get it over and done with........
1.
2.
3.
4.
5.
6.
modnrod
Threads: 50
posted on May 17th, 2015 at 02:27 PM |
Two heads are better than one.
CCing heads to figure out compression.
I want really small chambers (better flame speed and burn), but have to balance that against engine capacity, cam duration and pinging it's head off!
Just a cheap kit from CIP1 to give me some idea.
The stock VW 113 chamber comes out at about 52cc (averaged across 4 chambers) with the stock 0.055" step. So, if you have a stock 1584cc motor, and
run zero deck on the pistons (level with the cylinder tops), you will then get 8.62:1 compression. Throw in a Web163 or Engle 110 and your good to
rip.
If you take the step out like I need to (because I'm not running 85.5mm bore) by flycutting it flat, then the chamber without the step is now only
44cc, which makes compression.....uhhmmmm......lots! (about 10:1 comp with zero deck). I can gain a few cc's with valve seating and a bit of chamber
work, so hopefully that won't affect the chamber size I want too much. I'll strip them down and take them into Harris Engines down in Perth to get
them to throw in new seats ,take out the guides, and flycut them flat before I line the things up with intent for "cleaning" them up a bit.
I'm also thinking about adding an oil spraybar to direct cool oil (after it's gone around the inlet manifold a few times maybe?) straight at the
exhaust valves or exhaust rocker and valve tip.
Maybe bring it into each head here (where the toothbrush cleaner is) then run it across the head under the rocker arm shaft.
What do you rekn?
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 17th, 2015 at 02:52 PM |
Nice little bit of rust you have there
Love the idea above!! Will be interesting to see how it all goes!
modnrod
Threads: 50
posted on May 17th, 2015 at 05:01 PM |
Quote: | Originally
posted by adlbeetle66
Love the idea above!! Will be interesting to see[size=5] IF [/size]it [size=6]EVER[/size] goes!
Fixed!
Thinking about it for a while now, so it has me curious too.
Oh, and one C pillar is done, the other side to go.
Thanks.
modnrod
Threads: 50
posted on May 20th, 2015 at 02:49 PM |
Huh! The maths works! Well bugger me.
83mm pistons inside stock thick 1500 barrels.
Stock 1500 pistons are like hens teeth, but Isuzu/Holden Gemini pistons are common as muck, and you can also get decent quality hypereutectics. 83mm
is 0.040" O/size. I had them machined for pin clips, and they slide straight onto stock rods perfectly.
I also had the piston tops machined just a touch.
A really rough dummy-up to double-check heights, this is with a 69mm crank.
4.5mm down the hole. So if I double that (9mm) then add the stock stroke (69mm), I get 78mm. That's lucky hey?
Of course, you could also just buy a cheap off-the-shelf thickwalled 88mm slip-in P&C kit for similar capacity, but where's the fun in that!
modnrod
Threads: 50
posted on May 28th, 2015 at 01:00 PM |
Torque Tools are the best!
This flywheel bolt was torqued to 270ft/lb 86000km and 42 years ago, and hasn't been touched since.
Light one-handed pressure and it's off, easy-peasy.
I rekn I could have used a short 7/16" spanner and still got the flywheel bolt out with an extra grunt.
modnrod
Threads: 50
posted on June 18th, 2015 at 12:28 PM |
Yes. torque tools ARE the best.
It's an unfortunate fact of life in the real world, that to get to work over hill and down dale, I have resorted to a hand-me-down car (from my
wife!) to use, hoping it will last until my next stoooopid little VW will be done and put to good use. I actually try to use my bike first, but hey,
it was below 10*C overnight last week!
I long ago christened the Commode "The Jolly Red Tugboat", due to it's propensity to make all who sail in her bloody seasick (suspension on a
Series 1 VX is really awful), oh yeah, and coz it can "tow heavy fings". Well, until it overheats again at least.
*sigh*
So, I still need to fix the thing. A lot. And without the wonder of a VW torque tool, I need to resort to the more usual swearing, big hammers,
"freeze and release", big breaker bars, 1/2"drive rattle guns, quite a bit more swearing (Daddy DOES know a lot of daddy words, doesn't he mum?),
all to get the hub off and replaced so it doesn't sound like a Cessna going down the road.
Give me a torque tool any day over this lot.........
modnrod
Threads: 50
posted on July 2nd, 2015 at 05:26 PM |
bugmaniaar
Threads: 18
posted on July 3rd, 2015 at 05:14 AM |
This is keeping me entertained.......
modnrod
Threads: 50
posted on July 22nd, 2015 at 01:34 PM |
Things rarely go according to plan.
I've waited 2 months for some basic machining to get done. It sat in the box untouched, so yesterday I went and got it all back.
And because life happens and takes priority over everything else, I'm not prepared to splurge on a decent stroker crank.
Supply difficulties it seems for some other things planned have cropped up as well.
So yesterday I came home from the Vee Dub Centre with 85.5s in a pretty blue box. I was there, and so were these, in stock and at the right price
(thanks John and Jackie).
A warm zippy 1600 is WAY better than having it sit there waiting interminably long for either a 78 x 83/88, or till the end of time for a 76 x 92
Oxyboxer.
The boys are pretty happy about getting ready to re-assemble the engine again. I was pretty happy that I have successfully taught them what pistons
are and do.........
"They will suck the air into Herbies engine, won't they dad?"
Oh dear. I hope I can remember where everything goes.
I'll start with the Solex 34-3 and stock ignition to make it run (it has already run on that carb and dizzy), but add a centremount 2BBL when I start
playing with it a bit.
I'm really looking forward to it all again, I enjoy tweaking stock parts, bit by bit they start to go well.
At the end of the day, these few basic parts and time and attention added will make it easily quicker and more fun than the VX V6 Tugboat I have for
wintry days now.
Now.
Back to the floors and the seam sealer.
modnrod
Threads: 50
posted on August 29th, 2015 at 02:18 PM |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on August 31st, 2015 at 08:13 AM |
modnrod
Threads: 50
posted on September 9th, 2015 at 05:39 PM |
I've scraped all the jute and nasty 42 yr old fluff from under the roof, I'll be using new soundproofing all round.
While using the scraper I could feel the dents in the roof turret, so swept off the dirt to have a look...........
I'm going to leave them in there. I noticed them when I saved it, and had a bit of a giggle.
Nothing screams old abandoned Volksie more than smashing the roof in frustration, then dumping it at the wrecker!
Doug Sweetman
Threads: 58
Mood: sweeeeet
posted on September 9th, 2015 at 10:35 PM |
I've seen / owned some rusty l and s bugs - but that takes the cake ! Kudos on the c pillar repair.
modnrod
Threads: 50
posted on September 15th, 2015 at 01:03 PM |
custom tools
Now I know why they make the 17mm allen key for the IRS pivot bolts with a 3/8" drive...........so you can break your ratchet trying to get the bolts
out.
What's needed is a bit more leverage, combined with a gentle tap to shock them free.
VW Special Tool Set #1973.IRS.2..........
modnrod
Threads: 50
posted on September 25th, 2015 at 07:11 PM |
The paint quality is crap so I have to re-do it, but I think the colour match to VW Off-White headliner is not bad........
Pages: 1 2 3 4 5 |
