[ Total Views: 29806 | Total Replies: 216 | Thread Id: 105844 ] |
Pages: 1 .. 4 5 6 7 8 |
vduboy
Threads: 41
Mood: Dying to get more buggy building time..
posted on October 30th, 2016 at 06:26 PM |
Is it a alignment issue? Have you double checked it has the right size spigot bearing in the flywheel for your input shaft? Stuck the box in gear and
turned the motor over by hand until it meshes? Clutch cable backed off? I realise you have probably tried the lot of them by now though...
It will all be OK in the end, if it's not OK it's not the end!
baghall
Ben Hal Outlaw Bushranger
Threads: 131
Mood: Kids think I'm obsessed!
posted on October 30th, 2016 at 06:43 PM |
Hydaulic clutch, have spun motor, wiggled and jiggled it but haven't checked the bearing as I assume it is the correct one. My mechanic installed it
for me and I understand they are the same for both 2.1 & 1.9 wbxs.
68 Baja - It's a growing pain!
58 Baja ute - and the pain spreads!
85 T3 Kombi - still growing
89 T3 Kombi - parts car
Special Air Service
Chief "Gunna"
Threads: 210
posted on November 1st, 2016 at 04:19 PM |
clutch and pressure plate the same or did you change them?
[size=5] Calling all NSW Mid North Coast Veedubbers
Click Below [/size]
[size=6]Mid North
Coast VW [/size]
baghall
Threads: 131
posted on November 2nd, 2016 at 09:58 PM |
Quote: | Originally
posted by Special Air Service
All new
rocknrob
A.k.a.: Rob
Threads: 90
Mood: mystic
posted on November 3rd, 2016 at 05:43 AM |
hey Mate, hate to see you stuck. You might have done this but before i tighten th clutch down shine a torch through to the bearing...sometimes it
helps getting perfect alignment
Special Air Service
Chief "Gunna"
Threads: 210
posted on November 7th, 2016 at 02:52 PM |
Quote: | Originally
posted by baghall
All new
Any chance there is compatibility issues between pressure plate and release bearing?
Click Below [/size]
[size=6]Mid North
Coast VW [/size]
baghall
Threads: 131
posted on November 24th, 2016 at 10:05 AM |
Well received my new tig welder/plasma cutter today. Very excited. Just have to get engine mounted after I recover from surgery. Once engine in and
running will start on rear bar with wheel carrier. Hope to get it done during school break.
Error |
baghall
Threads: 131
posted on December 5th, 2016 at 05:24 PM |
Christmas came early for my van.
Recieved a campervan culture order today.
Rear flyscreen with zipper, power flex bushes for front suspension, an upgrade kit to replace the foil at the back of the dash and a set of rear
engine vent scoops.
Error |
vduboy
Threads: 41
posted on December 6th, 2016 at 10:38 AM |
Did you get the motor mounted up yet mate?
baghall
Threads: 131
posted on December 6th, 2016 at 03:18 PM |
Quote: | Originally
posted by vduboy
No had to have surgery for a hernia early November and not allowed to lift anything till 25/12. Puts paid to my plans of having it running by
Christmas. At least I can install some of this smaller stuff in the meantime.
vduboy
Threads: 41
posted on December 6th, 2016 at 03:26 PM |
Quote: | Originally
posted by baghall
Quote: | Originally
posted by vduboy
Sweet I've had three of them! Doc said it is a mess in my stomach.. good to hear!
rocknrob
A.k.a.: Rob
Threads: 90
Mood: mystic
posted on December 6th, 2016 at 06:46 PM |
Quote: | Originally
posted by baghall
engine vent scoops.
very interested in your scoops...i am considering some for my aircooled.
Bunnings sell an indoor outdoor temperature weatherwall for $19...i put the outdoor sensor in the engine bay and not happy about how hot it gets in
there...scoops would improve
nils
Threads: 65
posted on December 7th, 2016 at 08:50 PM |
Quote: | Originally
posted by baghall
Like this Ben?
Quit calling rust patina
baghall
Threads: 131
posted on December 12th, 2016 at 02:27 PM |
Hven't installed them yet. Hope to this week. Seem to be very good quality. Made from fibreglass, approximately 2mm thick. Will post a photo when
mounted.
Quote: | Originally
posted by rocknrob
Quote: | Originally
posted by baghall
engine vent scoops.
baghall
Threads: 131
posted on December 12th, 2016 at 02:29 PM |
Something similar but a bit bigger as planning on mounting Jerry can holder and wheel carrier using some beetle front spindles as the mountings. Also
hope to build a bike carrier for it as well (motor bike that is).
Quote: | Originally
posted by nils
Quote: | Originally
posted by baghall
Like this Ben?
baghall
Threads: 131
posted on December 18th, 2016 at 03:21 PM |
Finished the update to the dash cluster and also changed out the white LEDS for green for the dash lights. Won't complete install of dash till I get
a new speedo cable. Clip snapped off when removing it. Also got the rear vent scoops mounted and painted. Only showing one because I forgot to wipe
the first one with prepsol so the paint lokks rubbish. Gonna have to sand it back and repaint, dam it.
Error |
Error |
baghall
Threads: 131
posted on January 2nd, 2017 at 05:03 PM |
Wel still had troubles getting engine mounted, so got a mate over to help and he suggested I drop the box mate them up and lift as one piece. Seemed a
good idea to me so dropped box cause I remembered I had ordered a new poly bushes for the front mount. Well dropped the box (gently) and have not been
sucessful in removing the old bush. Anyone got any suggestions.
Also wondering if there are different bush sizes depending on engine types in these buses. The new bush is approximately 10mm larger than the hole?
TIA
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on January 2nd, 2017 at 07:11 PM |
T3Technique list the mounts in 74mm and 59mm. http://t3technique.com/suspension-bushings/powerflex-suspension-bushings/2wd-...
Think there is a how to on thesamba.
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on January 2nd, 2017 at 07:14 PM |
http://www.thesamba.com/vw/forum/viewtopic.php?t=490867&highlight=poly+mount
Quote of the week
baghall
Threads: 131
posted on January 3rd, 2017 at 07:24 AM |
Thanks for the help mackaymanx. Was having problems finding someone with the smaller mounting. Forgot about T3 Technique. Have no bought complete
front bushing set as well. Not cheap but should be well worth it.
baghall
Threads: 131
posted on January 7th, 2017 at 08:22 PM |
Finally found a solution for the snorkel. A little bit of modification (squashing it) had it fitting nicely.
Also my fire insurance arrived yesterday, will be fitting it once engine is finally installed. Ended updeoppong gearbox as nedded new front rubber.
Needless to say I bought the wrong ine (larger) so have now ordered the correct size poly replacement.
Error |
Error |
baghall
Threads: 131
posted on January 13th, 2017 at 10:46 AM |
Well been upskilling on new 3D CAAD for work during the holidays. Decided to make it somewhat productive and designed som new cabinetry for the van.
Looking at a steampunk influence.
All edges to be done using copper tubing with all the latches to look like brass and may even do some gears etc as dummy windows.
Also have another idea but not steampunk.
What do people think?
Oh and have now dropped the gearbox to try and get engine mounted. Looks like I need a new front gearbox bush as well. Currently waiting on that and a
full set of poly buhes for front and rear.
Error |
Error |
rocknrob
A.k.a.: Rob
Threads: 90
Mood: mystic
posted on January 13th, 2017 at 06:22 PM |
yeah autocad 3D is great fun...i used it to design all the pipework when i fitted a turbo but your upskilling shows!
baghall
Threads: 131
posted on January 16th, 2017 at 05:18 PM |
Thanks for the complement rockncob
Smiley
A.k.a.: Daniel Stephens
Threads: 110
Mood: Synchro'd
posted on January 16th, 2017 at 10:00 PM |
Love the Steampunk mate. I say go for it!!
Smiley
baghall
Threads: 131
posted on January 17th, 2017 at 11:06 PM |
Thanks Smiley, pretty sure that will be the look, just hope I can pull it off!
baghall
Threads: 131
posted on January 19th, 2017 at 03:47 PM |
Had a hell of a time getting out the old gearbox bush. Took several attempts but ended up having success using cold chisel and driving a screw driver
all the way between bush and housing which helped break the seal. Nocked oit with hardly any impact after that but not even me smashing on a large
enough socket with a framing hammer was enough. Now just need to make sur inside of housing is still good.
Error |
baghall
Threads: 131
posted on January 28th, 2017 at 08:01 AM |
Ordered these from T3 in USA about 5 weeks ago. Some were not in stock so they held off sending order for around 3 weeks. Been on school holidays and
they finally arrive on my first day back at school. So much for doing them over the Chriatmas break.
Oh and accidentally ordered 2 gearbox mounting bushes. So if anyone needs one!
Error |
Boozo
Back in the bug
Threads: 34
Mood: cruisy
posted on January 31st, 2017 at 09:20 PM |
coming along nicely. I'd be losing my marbles not getting the engine in for that long, hope it all comes good. And i'll definitely be getting one of
those T3 front bushes in the not too distant future.
Rear mounts alone made a huge change on mine.
[size=4] '59 or Kombi?....feeling confused [/size]
'59 bug
'68 bug
'82 import T3 BUS. aircooled
baghall
Threads: 131
posted on February 4th, 2017 at 02:44 PM |
Well can sell you one for cost price if you want. What gearbox you got. I have the larger one for auto and the smaller one for 5 speed. Let me know if
you want one and yes it is driving me mad not having it done. Will be doing a long drive once done just to make my head space better.
Quote: | Originally
posted by Boozo
