[ Total Views: 19220 | Total Replies: 263 | Thread Id: 106947 ] |
Pages: 1 .. 7 8 9 |
adlbeetle66
A.k.a.: Denver
Under the car.........again!
Threads: 98
Mood: ICH BIN VW NUSS
posted on November 9th, 2015 at 07:48 AM |
The current state of the passenger rear inner guard...
Error |
ptjcmaavw
Threads: 3
posted on November 18th, 2015 at 05:36 PM |
Hey mate, havn't been on here in a while to catch up with what you're doing.
Looking great, and from the pic above, it looks like the heater channel is missing?!
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on December 6th, 2015 at 09:06 PM |
Yes, thats true. I have cut the heaters out and am trimming the new ones carefully as i go.
I left a bit of the passenger one in, still to be neatened up a bit so that it'll all blend in...
Excuse those old terrible welds there...
Error |
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on December 6th, 2015 at 09:08 PM |
Some work in progress on the fan shroud...
Error |
Error |
Error |
m4co
Threads: 37
posted on December 18th, 2015 at 12:11 PM |
Cool idea for the fan shroud, I might do the same thing since I replaced my rotted out heater boxes for j-tubes
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on December 18th, 2015 at 03:53 PM |
Thanks. I will have some updates on here soon > Now that i am on school holidays
Finky
posted on December 19th, 2015 at 07:34 PM |
looking forward to more posts. Your doing a great job!
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on January 19th, 2016 at 08:21 AM |
Here we are, the finished product of the fan shroud. Its not for a $100k show car, so it doesn't bother me.
Now coming along fast, the current progress of the engine.
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on January 19th, 2016 at 08:22 AM |
Oh, now that i have a new installation kit for my sway bar its now ready to go in!
Error |
wombatventures
Threads: 44
Theme: UltimaBB Pro Orange
Mood: BUSted, BUGgered & NOTCHed
posted on January 20th, 2016 at 06:34 PM |
Fan shroud looks ace Denver.
Keep up the good work.
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on January 21st, 2016 at 08:46 AM |
Thanks man
Got a new breather on the oil filler too
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on January 21st, 2016 at 08:50 AM |
And yes - the manifold isn't quite lining up
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on January 22nd, 2016 at 03:30 PM |
Trying to get the driver heater channel all sorted - as well as the fire wall.
Error |
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on January 22nd, 2016 at 03:31 PM |
We made a gusset to join the heater just before the B pillar. The front is just all tacked in for the moment.
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on January 22nd, 2016 at 03:33 PM |
And the passenger heater to date.
Quite a bit of lining up to do, the second picture shows how poor quality these are
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on March 13th, 2016 at 07:34 PM |
Been a while since an update, so here we go!
Got the heater on the passenger side all tacked in, and we're just slowing trimming the firewall / bulkhead when we get time.
But had another issue. I went to pull the distributor out to put it into another bug as i was having ignition issues with it, and the drive came with
it
So this view is down the hole
I was told that there was supposed to be 2 shims / washers on the bottom of the drive, and they didn't come out when i pulled the drive out, so i put
a fine screw driver down the hole and poked around, and i was sure there was only one there, so i got in there with a fine magnet and pulled it out.
And there was only 1.
I thought for the worst and pulled out the sump plug, drained all the oil with the engine sitting on two old coke- crates and then pulled the sump
plate off. Still no sign i shook it, flushed more oil though, and nothing.
Error |
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on March 13th, 2016 at 07:35 PM |
So i took a photo of the shim between the calipers, and send it to a good friend of mine, a VW mechanic.
Thankfully, he replied that it was an early thicker type, and only the 1 shim was required
Got the shim lowered down with some forceps, and then thanks to karmann141 and vwo60 on here, i used the distributor drive puller tool to put the
drive easily back in the right place.
So in went the spring, then the distributor itself, and clamped it all down!
Turned over the engine, and all was perfect!
Well at least i know the drive is in correctly now!
Error |
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on March 13th, 2016 at 07:36 PM |
So then we had the fuel pump on and the weber & linkage on.
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on March 13th, 2016 at 09:38 PM |
Next me and my brother got it off the crates and onto the chassis.
I slowly and carfully bent the pre-heaters into their correct shape (empi quality once again shining out), and onto the car.
On with the extractors and the muffler and clamped up everything nicely.
We wiried up the coil and the starter motor ready for a test run.
Its half running, but spitting backfires everywhere and causing aero start cans to catch on fire, so we might just re-think that before we give it
another go
Error |
Error |
Fat Boy
posted on March 15th, 2016 at 11:59 AM |
Great stuff!! A lot of work a credit to ya
born again bugger
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on March 15th, 2016 at 04:16 PM |
Thanks! Got some more pics i'll post later on
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on April 25th, 2016 at 07:08 PM |
Order from CB Performance !
GO CB PERFORMANCE!!
Here in just over a week from payment.
Easy service to use and top parts!
Got a few goodies here including;
New clutch - installed.
My own Dizzy Drive tool
Gear Shift Coupler
Weber Re-Build kit
Coil Re-Location bracket - will keep this updated. My coil leads were hitting on the weber linkage, and i didn't think of this when i finished the
tinware...
Error |
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on April 25th, 2016 at 07:11 PM |
Then today we let her see a little sunlight again
Error |
1cut808
Threads: 2
posted on May 5th, 2016 at 04:31 PM |
Getting there nicely!
Pages: 1 .. 7 8 9 |
