[ Total Views: 10923 | Total Replies: 96 | Thread Id: 107623 ] |
Pages: 1 2 3 4 |
Smiley
A.k.a.: Daniel Stephens
Threads: 110
Mood: Synchro'd
posted on August 18th, 2016 at 10:40 PM |
Quote: | Originally
posted by Scottkombi
I love this bus and how it keeps evolving.
Keep going - its awesome!
Thanks mate.
We are just getting started!
Smiley
Smiley
Threads: 110
Mood: Synchro'd
posted on August 19th, 2016 at 05:59 PM |
A few other little things that have happened on the bus. Some today, some in the last month or two.
Added oil temp and pressure gauges to the bus. They are just temporarily through the speaker grill on the top of the dash for the time being. I intend
to put them down in the dash at some point. Whoever cut the hole out for the stereo put it right in the middle of the dash and let no room top or
bottom for gauges.
Also, my little elephant road tripping buddy has a better seat now
I have added a sandwich plate on top of the filter so I can run some hoses off to an additional cooler. I added a bit of heat shielding where the
hoses pass under the tinware. And trimmed the tin back a bit to allow the air to flow out nicely still. Adding the hoses and fittings blocks the
outlet up somewhat.
Then the hoses run down the side of the transaxle and switch over to the RHS of the bus.
The cooler is mounted between the chassis rails on a piece of angle that I trimmed one side off that would have blocked the leading edge of the
cooler. It sits on the RHS of the bus between the heater hose and the chassis rail. It is mounted so the front edge of the cooler lines up with the
back edge of one of the floor tophats. Then the hoses come out of the top of the cooler just behind the tophat and run to the back. I might mess
around with shrouding in the future to see if I can encourage some more airflow through the cooler, but I think it will see plenty of wind where it is
for the time being.
The view from the front. Don't mind the table under there. I was just using it to block the sun so I could take a picture that wasn't dark.
There may be room on the other side to mount a second cooler. But most of the lines and cable tubes are on this side and I think they will all get in
the way.
Have picked up some steel to make a rear bar. Just need to get some more think wall angle. I thought I had a length at home, but alas I was
mistaken.
Have a small(ish) To Do list that I am working my way through. I also adjusted the steering stops today, as well as tightened the handbrake cables and
adjust the gearstick a little more rearward.
More soon.
Thanks for looking.
Smiley
Smiley
Threads: 110
Mood: Synchro'd
posted on August 23rd, 2016 at 08:09 PM |
Made a start on the rear bar this afternoon.
I want to to look basically the same as a stock one. But it will be 100x100mm box with the stock bar wrapped around it. It will also have a hole in
the middle for the tow hitch. And eventually I will add the swingout tyre carrier for the spare too.
You can see in the next picture that I don't want to drop the bar at all from its currently position. It will foul the exhaust tip. I might even
raise it slightly so I can redo the exhaust at some point to get a little more clearance under it.
It's official, buses look completely weird with the rear bar removed. Gives a bit better view of the new heat shield though
Here is the box sitting in place. It is currently too long. I am going to trim it back to the same width as the chassis rails in the back, 1115mm for
those playing at home. Was actually a lot easier than I thought to cut through it with the 100mm grinder.
Bar sitting back in the stock location...
...but now it has the box insert sitting inside it
That's all I got done today. Hoping to get the mounting plates fabbed up tomorrow so I can mount the box up to the chassis.
Thanks for looking.
Smiley
Smiley
Threads: 110
Mood: Synchro'd
posted on August 24th, 2016 at 09:46 PM |
Got a little more done this arvo on the rear bar.
I noticed when I removed the factory bar, that the brackets bolt to the underside of the chassis with two M10 bolts. But there is a third threaded
hole in the chassis a little further forward. I ran a tap through all of them and will be using all three for the mounting plates. Does anyone know
what the factory used the third hole for?
I am using some 40x40mm angle that will bolt up to the underside of the chassis and weld to the bar.
In addition to the angle I am making some side plates out of 6mm plate that will weld to the ends of the box and cap them off. I am basically copying
Andrew's bar he made for his bus but changing a few things. His build here http://www.manxclub.org/phpbb3/viewtopic.php?f=2&t=1582&start=60
The plates will bolt through the chassis with some M12 bolts and crush tubes. Just have to make sure that it clears the rear engine mount bar.
While I was lying under the car looking at how I was going to mount the bar I noticed that the flange for where the exhaust tip bolts to the muffler
was cracked on the underside. I removed the muffler and gave the crack a cleanup, and then laid a bit of weld in there to fix it up. I was lucky
enough to have some new exhaust gaskets left over from my dad's bug (we ended up with two sets for some reason). So I refitted it back up with the
new gaskets.
Then I spent a while taking a lot of measurements and working out where I want the box and rear bar to sit. I have decided to lift it up 15mm higher
than factory. And the gap between the rear or the body and the box will be 30mm. Then I drew this all out on a cardboard template to see if it would
fit. I like to write the measurements straight on the template for a quick reference. Then I tried it on the car, I had to adjust a few dimensions to
get it to fit perfectly. Also sat the box in place on jackstands to offer the template up to it.
Last thing I got done this afternoon was to let the hole through the centre of the main box for the tow hitch box to go into. First I marked out the
centre point on the main box and marked out where the hole needs to be for the smaller box to go through.
You can see in the previous picture that the corners of the small box are very rounded. I didn't want to be filling up large gaps with weld. I wanted
to make the join as snug as possible so the welds can be airtight and strong. In the future I would like to used the large box section of the barwork
as an air compressor tank.
With that in mind I measured the radius of the corners and used a 20mm drill bit to put the curves in that I needed. Then I just cut the straight
edges with a thin cutting disc and tapped the waste out with a hammer. Ended up with a nice pair of home made Iron Crosses at the same time
With the holes cut I just had to tidy the perimeter up a little with the die grinder until the small box was a nice fit. I can tap it through with a
hammer and block of timber. The final length still needs to be worked out. It will need to protrude through the stock bar enough that I can get the
hitch pin in it. I will be sticking it about 5mm through the front side so I can get a nice weld on it.
As always, thanks for looking.
Smiley
nbturbo
Threads: 89
Theme: UltimaBB Powder
posted on September 20th, 2016 at 04:18 PM |
Smiley,you have gone pretty quiet.The big trip across the Nulla bor slow you you down a bit???
Smiley
Threads: 110
Mood: Synchro'd
posted on September 25th, 2016 at 11:16 PM |
Quote: | Originally
posted by nbturbo
No more than my usual snail pace! Trying to get a few things sorted for the run down to Warwick.
This is the rear bar bolted up in the factory location. I was messing around trying to work out where to fit the trailer plug on the rear bar. I am
aware that there is currently one in the engine hatch but there is no wiring to it and I don't want it there, I also think that the tyre carrier
might get in the way of plugging the cable in.
I though maybe I could fit in in between the box and the rear of the body. But with it in place that gap to the back of the vehicle looks horrible.
The bar is stood off a mile. It doesn't look so bad in the pictures, but in the flesh it looks like the bumper is falling of the back of the bus. Way
too much gap.
Even with the box pushed in to where I plan to run it has more gap than I thought it would. The next picture the box is gapped to the back of the bus
and the bumper is pushed as far over it as possible. But hoping that the tyre carrier will mask some of this gap.
I cut out the mounting plates that will be welded to the ends of the box section. I have also cut some 40mm angle that will be bolted to the underside
of the chassis too. Will get some more pictures of this tomorrow.
When I cut the plates out I drilled some 10 or 12mm holes at the inside of the radius of any corners. I didn't want to cut squarely into the corners
with the thin cutting disc and create a stress area that cracks could start at. Has to be strong enough to snatch 4WDs out when they get stuck, so
don't want it snapping of the back of the bus!
I dropped the 100mm box off to get sandblasted inside and out. I am planning to use the box as an air tank so I wanted it clean inside. Prior to
welding it up I will spray some oil in it for the time being to stop it rusting up. Then later I can add fittings and pressure relief etc.
Next up I started work on the cold air intake for the engine. I bought some tube and bends off eBay. And was trying to work out the best way to mount
them to the side of the engine bay.
I was around helping someone with a few things on their bus and noticed that it had factory mounts for an intake pipe. Because my bus is injected it
had the airbox mount but not these two intake brackets. So I went and had a look in the back of one of the Bay wrecks that I have and sure enough, it
has the mounts. Cut them out with a cordless grinder and they happen to be the perfect size for the 2.5 inch tubing. And the hose clamps I have fit
nicely into the back of them.
Started mocking up where I wan the intake to run. I wanted it a bit higher in the bay than this to get it up clean of the battery and out of the
way.
I ended up cutting one side of the 45° bend as short as possible. This brings the bend closer to the intake where it clamps on and further away from
the side wall of the engine bay. So it angles up for longer and tucks up higher out of the way.
I cut one leg off the alloy tubing to shorten it up to hug around the corner of the firewall above the battery. The piece I cut off happened to be the
perfect length to put between the 45° and 90° blue bends. This is the intake pipe all assembled how it goes in the car.
I fitted the intake mounts using nutserts. I figured bolting them it was easier than trying to weld in the engine bay. And they are super easy to take
in and out now too. The first one is basically where the factory had it. And the one above the battery I moved further out to the right of the car to
support the end of the tube as much as possible.
I clamped the intake in place before getting a picture of the second mount. It is under that hose clamp there.
Intake all fitted in place.
Looking down the hatch in the back.
Heaps of clearance above the battery.
And that's how you fit a cold air intake to you bus
Thanks for looking, more soon.
Smiley
Smiley
Threads: 110
Mood: Synchro'd
posted on October 6th, 2016 at 08:51 PM |
Got some more work done on the rear bar before the Warwick VW Drag weekend.
I cut the hole in the rear bumper for the tow hitch to come through. I drilled the corners first with a 10mm drill to get the corners of the hole a
nice radius.
I decided to fit the trailer plug through the box section. But because I want to use the bar as an air tank this means keeping it all airtight. So I
picked up a length of heavy wall tubing, sliced a bit off and will weld it in place to create a void for the plug to go in so I don't have to space
the rear bar a km off the back of the car.
The tubing I got is seamed. So when I cut the slot in it I made sure that I cut the seam out of the tube. One less weak point to worry about.
I worked out where I wanted it on the box and marked and cut it out so the tube was a nice hammer fit.
A little tidy up and you can see where the plug will sit. I have some 6mm plate that will also get welded on top of the bar. This is so I have
something to bolt the plug down to without drilling holes in the box section. Still needs to be trimmed to shape and welded on.
Back to the bar mounts. It was suggested from a friend that I drill the mount bolts through the chassis and clamp through the whole thing. He said the
thread in the chassis isn't the strongest. He has done the same thing on his bus and tows a car trailer with it so no arguments from me.
You can only do it with the front two bolts. The rear one is inside the pillar at the back of the engine bay so you can't get to the top of it.
Then I bolted up the mounting plates. They are only tacked together at the moment. The large side plate will be bolted through the chassis in three
places. Only one for the time being. There was one 10mm holes in the chassis already that I am using. But the engine needs to come out to drill the
other two, these will be 12mm. I will also enlarge the other one to 12mm too. And the 40mm angle is bolted up through the chassis in the 3 factory
holes. I made some plates out of 6mm that sit on the top in the engine bay.
You can see in the next picture how the box will be welded to the mounts. The side plate caps the end of the box and the angled piece will be welded
to the side of the box. I tacked it, then removed the angled piece so I could fully weld around the end of the box and make an airtight seal with the
end plate. Then the angle was welded on second.
I took the box section and had it blasted. So it would be a bit cleaner inside and nicer to weld up.
Smiley
Smiley
Threads: 110
Mood: Synchro'd
posted on October 6th, 2016 at 09:15 PM |
I fitted the tow hitch box section into the main bar. Then level this up behind the bus. I used the blue screw jackstand to tune in the angle of the
tow hitch. I measured the roof gutters of the bus with an angle finder and made it the same angle on the tow hitch. So should be level if the bus
is.
Then I tacked it up so I could see how it looked before I welded it out. I Trimmed the hitch back too, left it a little oversized so I can set the
right length later.
I welded the hitch in first. Then both ends. Then fitted it back to the bus so I could tack the angled pieces in place and then weld them on too. I
think it pulled a little when the angle was fitted. It was a little tighter on the chassis and needed some hammering to get on. This doesn't really
bother me. Once it is finished and on for the final time I don't intend on removing it again.
I welded a couple of nuts on the ends so I could bolt the bumper in place to head down to Warwick (900km each way). Will make some better mounts now
that I am back. The towball is just in there for show. I hadn't drilled the pin hole at this point.
I am happy with how it looks. It has spaced the bumper out a bit. But I think the tyre carrier will cover this up. It is super strong and that is what
is most important.
Drove the car down 900 odd km to Warwick for the VW drags. I am fortunate that my grandma lives 30km away the next town over. So I always have
somewhere nice to stay every year when I go down for the drags. I gave the bus a good wash the Friday before the show.
Bus setup next to the drag strip watching the racing. Was going to put it in the show and shine, but we liked having the shade a lot more. Plus he
doesn't exactly shine
This afternoon I finished off the trailer hitch on the bar. I marked then drilled the holes through for the pin.
Then I trimmed off the excess length I didn't need.
I slid the towball as far in as it would go and used the hitch as a guide to add a new set of holes in it. So now I have two different spots it can be
at. But I think I will just use it on the holes that have it furthermost in.
So now we have towbar! Just need a plug and it should be good to go. That's all for now folks.
Thanks for looking.
Smiley
modnrod
Threads: 50
Mood: Old School Volksies!
posted on October 7th, 2016 at 07:05 AM |
How many times have you lost your knee on the towbar so far?
Every time I read this thread I get the Kombi itch BAD!
I noticed the green door and yellow sides, then remembered the John Deere sign over my back fence.
Just an observation.........
rocknrob
A.k.a.: Rob
Threads: 90
Mood: mystic
posted on October 7th, 2016 at 06:18 PM |
and what are you towing?
Smiley
Threads: 110
Mood: Synchro'd
posted on October 13th, 2016 at 08:45 PM |
Quote: | Originally
posted by modnrodHow many times have you lost your knee on the towbar so far?
None so far, but I know it is coming.
Quote: | Originally
posted by modnrodI noticed the green door and yellow sides, then remembered the John Deere sign over my back fence.
He'll be all one colour some day!
Quote: | Originally
posted by rocknrob
Trailers, dragging wrecks out at home to be stripped, 4WDs out when offroading and anything else that I want. You know, the usual things you use a
towbar for.
Smiley
Smiley
Threads: 110
Mood: Synchro'd
posted on October 13th, 2016 at 09:02 PM |
I put my trailer on the bus the other day to see how it looked. I was expecting it to be a lot more nose up. But I think Houdini's saggy butt has it
sitting fairly level.
Took a mate that was visiting for a day for a run out to 5 Rocks. Haven't been out there since the bus has been lifted so was interested on how he
would go. Was a bit softer than last time but made it up the big dune to get in no worries. This is us at the top. Had to air down a bit though
Drove up through the small township and out onto the headland. Got some good pictures. Scott had a far more fancy pants camera than me. So when I get
some pictures off him I will post them up too.
Headed down to the beach and cruised around some more. Found some rocks to flex on. Houdini is a little lacking. But when I get back in the car the
front right compresses up a lot more.
I was very happy with the way the bus performed in the sand. With the tyres down and the mass balanced a little more to the rear with the new back bar
he got the power down nicely. You have to back off with the grunt of the Type 4 otherwise he just wants to spin wheels. Have to just let him chug of
through.
Was a great test run before Fraser this weekend to check things and get a feel for the bus.
Smiley
Smiley
Threads: 110
Mood: Synchro'd
posted on October 13th, 2016 at 09:27 PM |
After the beach run I got started on fitting up another oil cooler. With the Summer heat already getting up around here and the Fraser trip looming I
thought it would a good addition to keeps the temps down. Longer term plan will probably be to swap one or both of these small coolers out for a large
one with a thermostatically controlled fan.
The new cooler is mounted to the same frame as the first one.
I also added an extra support bracket to hold the centre of the frame up and stop it sagging in the middle.
All plumbed up. You can also see the extra brace. It bolts through an 8mm holes that was already in the tophat frame.
Last time I had the engine and box out I noticed some play in the front mount. This demonstrated itself on the sand with the engine revving itself up
and down slightly at points. So I ordered a new mount when I got some other parts.
Here is the old mount removed.
Unfortunately the new mount was a different shape. Slightly smaller and more rounded on the corners that face towards the front of the car. I thought
that perhaps my mount cradle was beginning to wear out. So I grabbed another cradle be came up with the same result, the new mount is just the wrong
size.
You can see the gaps in the corners of this picture.
The old mount was actually still in good condition. Just a little loose in the cradle. So I decided to deck the back of the cradle where it sits
against the gearbox. This will clamp the rubber up tighter and take the slack out of the mount.
I trimmed about 2-3mm off the cradle with the grinder and then flattened it out with a hand file. You can see the inside is polished up from the
rubber moving back and forward in it.
This did the trick and the mount bolted up far more firmly in the bus.
Today I also added a plug under the back seat for the fridge. Still have to run some wire to it. Will be 6mm straight from the battery.
That's all for now. Will get some pictures on the Fraser run.
Thanks for looking.
Smiley
baghall
Ben Hal Outlaw Bushranger
Threads: 131
Mood: Kids think I'm obsessed!
posted on October 24th, 2016 at 04:12 PM |
Nice photos on the beach. Love the idea of using the RHS as an air tank, mind if I pinch it for my bus. Was going to use RHS on the rear bar but never
thought of using it for an air tank.
Also if you are snails pace I must be catatonic.
68 Baja - It's a growing pain!
58 Baja ute - and the pain spreads!
85 T3 Kombi - still growing
89 T3 Kombi - parts car
Carl and Emily
Threads: 38
posted on October 29th, 2016 at 06:46 PM |
Yeah!, Thanks for posting,.. it's a great read.
Your fabrication skills are something to envy.
rocknrob
A.k.a.: Rob
Threads: 90
Mood: mystic
posted on November 5th, 2016 at 08:02 PM |
Smiley,,Rob here,,very impressed by your work. Just wondering how your oil coolers are going and why you felt the need? Have you figured out what revs
you are doing at 100 klicks with those big tyres? that when a vw engine is working hardest,,,just curious to whether i need an oil cooler...Rob
Smiley
Threads: 110
Mood: Synchro'd
posted on November 6th, 2016 at 10:23 PM |
Quote: | Originally
posted by rocknrob
Coolers are going great mate. Normally sits around 80°C while cruising on the highway. We are about to have a hot week up here so I will see how it
goes. It tends to slowly creep up a bit if you push it along hard.
I am planning to remove one of them and fit a larger one with a thermostatically switched fan on it. I found at Fraser that chugging around slow on
the inland sand tracks that the temp was getting up near 100°C at times. An 80°C switch for the fan would combat this low speed heat soak by getting
some airflow through the cooler.
I have a spare RX-8 cooler so I might end up using that if I can find an IP67-68 fan to put on it.
Don't have a tacho yet, but putting much numbers into a calculator gives around 2800RPM at 100km/h with the 33s.
Smiley
rocknrob
A.k.a.: Rob
Threads: 90
Mood: mystic
posted on November 7th, 2016 at 04:47 PM |
Thanks for that Smiley. I,ve been reading up on oil temp and its a complicated topic. 80c may even be too low...anyway have fitted and oil temp gauge
and will start keeping track...cheers
Smiley
Threads: 110
Mood: Synchro'd
posted on November 7th, 2016 at 08:00 PM |
Quote: | Originally
posted by rocknrob
Was more like 90°C on the way home today. Came up very quickly too. It was bloody hot today!!
Smiley
Smiley
Threads: 110
Mood: Synchro'd
posted on December 8th, 2016 at 09:02 PM |
A few pictures from a Rover Scout camp I went down and helped out at last weekend. Was held and Awoonga Dam near Gladstone and we went out to Boyne
Island/Tannum Sands Saturday.
I took a canoe down, towed my trailer down with a tent in it and took 3 people down and all their camping gear. And Friday's temperature was like a
firestorm from hell. Probably the worst conditions I could have towed in with all that weight. Oil temp was at about 100°C most of them time but did
come down a bit on the flat and coasting down hills. Very happy with how it went, but would still like to add a fan to one of my coolers.
This is Friday Afternoon when we showed up.
Saturday morning down at the beach. I nabbed a good spot right next to the sand and put the awning out for everyone. The shade was most welcome.
I backed into the park. People were guiding me over next to the gutter but no one was looking behind me. I stopped the bus and got out to set up and
thought, "That ute is a bit close". Probably could have just put a feeler gauge between them! Lucky I didn't go back any further. In my defense
though, I am in my park
A nice picture from the canoe.
Was a little windy but the awning stayed put all day. Lucky I had some big sand pegs to hold it down.
Saturday afternoon we went down to the dam for a swim. We were camped at the Scout grounds about 500m away so I took about 10 people down in the back
of the bus. I drove all the way to the water's edge.
A few other people came down as well in 4WDs. None of them could drive back up the bank to camp because the ground was a little loose and rocky. They
all had to put it into 4WD. I offered them a tow Gee they make easy shit
look hard sometimes. Houdini chugged back up there without even a hint of wheelspin, even with the extra bodies on board (the extra mass might have
helped!)
If anyone wants to know what the tent looks like. This is why you need a trailer to move it
All loaded back up and ready to cruise home Sunday.
Thanks for looking everyone
Smiley
beetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
Mood: Drive bugs hard
posted on December 9th, 2016 at 05:20 AM |
Looks like it was a great weekend. :-)
From your ole' mate Jeff
rocknrob
A.k.a.: Rob
Threads: 90
Mood: mystic
posted on December 9th, 2016 at 05:32 AM |
great pics Smiley! I know those places well. Igrew up in Gladstone. The Boyne is a mighty ferocious river in full flood. Is it time to slap some
wethertex house paint on houdini with a brush?
modnrod
Threads: 50
posted on December 9th, 2016 at 06:52 AM |
Weathertex with a brush?!!?!?! That's a bit rough isn't it?
Killrust or Solagard with a foam roller for a quality finish.
Thks for the write-up Smiley.
BlasterTheRedBajaBug
Threads: 78
Theme: UltimaBB Pro Charcoal
Mood: Playing the cards, like they were what I wanted
posted on December 27th, 2016 at 10:51 AM |
Quote: | Originally
posted by Bone
Quote: | And a locker
that is sitting around looking for a home
| Hey Smiley I have found a home for that locker diff! Here on the Sunny coast in a 5 rib box under my Baja! You know you want to make
some shelf space! Lol.
Where are you on the Sunny Coast?
Nobody can drive you crazy, unless you give them the keys.
Smiley
Threads: 110
Mood: Synchro'd
posted on December 27th, 2016 at 10:16 PM |
Quote: | Originally
posted by BlasterTheRedBajaBug
Quote: | Originally
posted by Bone
Hey mate. Shane is around Black Mountain area.
Smiley
Threads: 78
posted on December 30th, 2016 at 10:30 AM |
I'm a little further South than that I'm at Warana.
rocknrob
A.k.a.: Rob
Threads: 90
Mood: mystic
posted on January 7th, 2017 at 05:55 PM |
[img][/img]
Hey Smiley i was resetting the rear torsion bars to accomodate the extra weight of a holden V6 and i remembered your milk crate test....yep...nearly
an inch to spare!
Smiley
Threads: 110
Mood: Synchro'd
posted on January 7th, 2017 at 09:54 PM |
Very nice Rob!
I'm liking that tyre carrier too. I have to make one for my bus to go on the rear bar. Do you have any more pictures??
Smiley
Bone
Threads: 43
posted on January 8th, 2017 at 07:17 AM |
Cutting and making Kombi"s into Baja Kombi's!!! Is nothing sacred!!!
rocknrob
A.k.a.: Rob
Threads: 90
Mood: mystic
posted on January 8th, 2017 at 07:21 AM |
[img][/img]
Hey Smiley, its just 25mm rhs...two posts welded to the bumper supports or towbar...just check the geometry make sure everything opens...the bumper
actually supports the weight of my spare
Pages: 1 2 3 4 |
