[ Total Views: 10144 | Total Replies: 61 | Thread Id: 109987 ] |
Pages: 1 2 3 |
rust bucket
Threads: 2
posted on April 25th, 2016 at 05:18 AM |
just installed front and rear centre chassis, 1 and 5 top hats, sills and 6th box section.
keeping the original I beams since they were ok
Error |
Error |
rust bucket
Threads: 2
posted on April 25th, 2016 at 07:32 PM |
classic fab fit ok
Error |
rust bucket
Threads: 2
posted on September 27th, 2016 at 07:33 AM |
new battery tray
Error |
Error |
rust bucket
Threads: 2
posted on September 27th, 2016 at 07:35 AM |
new load bed channel and top hats done
Error |
Error |
rust bucket
Threads: 2
posted on September 27th, 2016 at 07:38 AM |
woodruff key and rat a lowlight steering box for parts
Error |
Error |
Error |
rust bucket
Threads: 2
posted on October 19th, 2016 at 08:24 AM |
I'm doing this build in a single car garage...I had to lower the front in order to get it under the roller door so I can spin it round - park in
backwards to work on the front!
Error |
Error |
Error |
rust bucket
Threads: 2
posted on October 25th, 2016 at 07:46 PM |
time to cut out more rust!
Error |
Error |
Error |
rust bucket
Threads: 2
posted on October 25th, 2016 at 07:49 PM |
chassis is ok after heaps of grinding - testing the relationship with my neighbours
Error |
rust bucket
Threads: 2
posted on October 26th, 2016 at 12:02 PM |
All fits together so now ready to weld
Error |
rust bucket
Threads: 2
posted on November 3rd, 2016 at 09:53 PM |
I was careful to take time doing this weld since its quite a long weld=distortion and right up front
Error |
Error |
rust bucket
Threads: 2
posted on December 2nd, 2016 at 08:30 AM |
front end in
Error |
Error |
rust bucket
Threads: 2
posted on December 13th, 2016 at 08:50 AM |
new gearbox ready
Error |
Error |
Error |
rust bucket
Threads: 2
posted on December 23rd, 2016 at 07:59 AM |
new kit arrived
Error |
rust bucket
Threads: 2
posted on December 23rd, 2016 at 08:01 AM |
and the final panel is in
Error |
Bizarre
Threads: 730
posted on December 23rd, 2016 at 09:27 AM |
Brilliant work mate!
Love to know what the ratio of rust to kept steel is
The "new kit" is that IRS?
rust bucket
Threads: 2
posted on December 23rd, 2016 at 09:08 PM |
Yes, IRS kit built here is Oz, Sydney in fact. I've already bolted it in and it took 10 mins....
I'll run bay window hubs up front and back so be on narrow 5's.
I'd could take a guess at ratio, probably 50/50 - its all new from the cab back, except half a chassis, I beams, side panels from c pillar back and
rear wheel wells.
then forward of the cab probably half is new well.
I'm nearly tired of cutting out rust - worn out two 100mm grinders and 36 cut off discs and I'm nearly out of another 5kg of 0.6mm MIG wire.
rust bucket
Threads: 2
posted on January 6th, 2017 at 11:46 PM |
Kit in, modified the spring plates, hubs on and she's rolling on wheels! not quite low enough yet!
Error |
Error |
rust bucket
Threads: 2
posted on January 22nd, 2017 at 04:52 AM |
work on the cab before and after
Error |
Error |
rust bucket
Threads: 2
posted on February 13th, 2017 at 11:33 PM |
This will fit in the bus
Error |
Scottkombi
Mood: Sick of Work
posted on February 14th, 2017 at 04:31 PM |
Looks great.
Love your detail - the donk looks very nice - what size is it?
88 Caravelle Syncro Camper
89 Caravelle GL microbus - 5 speed
69 Microbus
05 Mk5 Golf 1.9 TDi DSG
rust bucket
Threads: 2
posted on February 14th, 2017 at 10:30 PM |
I cant take credit for the engine, a local guy here put it together and I just supplied the pearl white paint. As you see he has a far cleaner and
larger garage than I. As for the specs its 1680cc with some minor performance parts including, heads, springs, torque cam, EMPI carby, so probably 75
hp at the wheels...
Error |
Scottkombi
Mood: Sick of Work
posted on February 15th, 2017 at 09:40 AM |
Very nice.
I'm interested to see how the carby goes.
There are lots of options out there and most go with the twin carby set-up - so I wonder how well the twin system goes.
69 Microbus
rust bucket
Threads: 2
posted on May 8th, 2017 at 08:10 AM |
had to make room for the carby by moving some of the top hat section but then it fitted easily
Error |
Error |
rust bucket
Threads: 2
posted on May 8th, 2017 at 08:13 AM |
finished off the front
Error |
rust bucket
Threads: 2
posted on May 8th, 2017 at 08:24 AM |
very impressed with the quality of this window
Error |
rust bucket
Threads: 2
posted on May 8th, 2017 at 09:04 AM |
Spent a few hours on the gear linkages, but then reverse and all 4 forward gears were working, so I went for a drive!
Hard to imagine that only 18 months ago it was rusting away in the paddock.
I've spent a lot of time and money researching and buying parts which has been fun.....here are some of the specs that will make it even more fun to
drive....
VW 1960 Single Cab
1680 DP 12 v with balanced crank, torque cam, valve springs etc
EMPI twin 40mm MDF carby
GT exhaust
1968 Ball Joint front beam with bay window disc brakes
1970's IRS syncro gearbox from beetle 4.125 final ratio
New beetle CV at gearbox and new kombi CV at rear hub
1970's kombi front and rear hubs currently with standard 14 inch wheels
H4 Halogen lights
rust bucket
Threads: 2
posted on June 14th, 2017 at 10:56 PM |
try and get it licensed this friday, wish me luck!!!
Error |
Error |
Error |
rust bucket
Threads: 2
posted on June 14th, 2017 at 10:58 PM |
Error |
Error |
Error |
waltermitty
Mood: Hungry for mor
posted on June 14th, 2017 at 11:26 PM |
great effort mate i just read from the start. I wish i had your skills. You must be stoked to be seeing light at the end of the tunnel.
Mitch
23 windows ...8 too many!
Bizarre
Threads: 730
posted on June 15th, 2017 at 07:15 AM |
WOW ................ excellent work
just went and looked at the first couple of pics
Pages: 1 2 3 |
