[ Total Views: 6666 | Total Replies: 88 | Thread Id: 111134 ] |
Pages: 1 2 3 |
kiwiev
Threads: 2
posted on September 30th, 2016 at 06:45 PM |
Just a wee update got the controller chiller, battery charger and motor side covers mounted today.
Cheers Kiwi
Error |
Error |
wombatventures
Threads: 44
Theme: UltimaBB Pro Orange
Mood: BUSted, BUGgered & NOTCHed
posted on September 30th, 2016 at 07:05 PM |
Mate... It's Electrifying!
Awesome work. Hope you'll put up a video once its mobile.
Can't wait.
nbturbo
Threads: 89
Theme: UltimaBB Powder
posted on September 30th, 2016 at 07:19 PM |
That's a neat looking install Kiwi. With those engine covers, will they keep cooling air away from the motors? With that battery power- how far would
you expect to travel at highway speed? Would the recharge cycle take long?A lot of questions
kiwiev
Threads: 2
posted on September 30th, 2016 at 08:14 PM |
Quote: | Originally
posted by wombatventures
Can't wait.
Thanks mate cant wait either will post video btw should do 0 to 100 in sub 8 seconds.
Cheers Kiwi
kiwiev
Threads: 2
posted on September 30th, 2016 at 08:20 PM |
Quote: | Originally
posted by nbturbo
Thanks Greg
Engine covers wont stop air cooling, air comes from gearbox end and out the back and up to hood vents.
Battery capacity works out at approx 1.5km per 1 % battery at 70 mph.
The charger we installed will take 8 hours on a 10amp plug but I could put a charger in that takes 2 hours.
F I do another bug I can get Tesla batteries for the same weight as these range would be 320 km.
Cheers Kiwi
matara
Threads: 255
Mood: 356'd
posted on October 1st, 2016 at 07:22 PM |
Hi, is this the complete $18,990 kit, or did you buy the starter kit and get the batteries over here?
kiwiev
Threads: 2
posted on October 1st, 2016 at 08:48 PM |
Quote: | Originally
posted by matara
Hi Steve
We are a dealer so we get most of our parts from EV West but source batteries from China for CALB and Tesla batteries from EV West.
But we can do a conversion starting from $29, 990
Cheers Kiwi
kiwiev
Threads: 2
posted on October 13th, 2016 at 04:39 AM |
Not sure how to link YouTube videos here but I will put link below.
Sorry for the poor audio and the Hang over look.
There is a bit of the bug on it.
Cheers Kiwi
https://youtu.be/5_nVmdSjuvM
kiwiev
Threads: 2
posted on October 28th, 2016 at 06:24 PM |
So managed to push two 25mm conducts thru the transmission tunnel from the front to the gear linkage cover. We had already drilled 2 gland nuts in the
side to exit 50mm2 cable.
Mounted and fitted front 12 batteries really happy with the result looks clean.
Cheers Kiwi
Error |
Error |
nbturbo
Threads: 89
posted on October 28th, 2016 at 10:32 PM |
Good work Kiwi.What do you reckon that lot of batteries would weigh?
kiwiev
Threads: 2
posted on October 29th, 2016 at 04:17 PM |
Thanks Greg
Weight about 60Kg so maybe 20Kg more than the fuel tank fill of gas, hopefully start on the rear box this week.
Then thats most of the hard items done and the rest is really only wiring up 3-4 days.
Cheers Kiwi
kiwiev
Threads: 2
posted on November 14th, 2016 at 05:40 PM |
Wee bit more progress over the weekend finally got the rear battery box and batteries in. We used eight 6mm countersink bolts thru the bottom with 2mm
plate washers 100 x 50mm.
then I had a brain wave and we drilled 2 holes thru the fire wall at the top of the box to locate the threaded rod retaining the batteries.
Cheers Kiwi
Error |
Error |
kiwiev
Threads: 2
posted on November 15th, 2016 at 04:57 PM |
Finally got a day off with my mate to mount the rear battery box. Worked out well 8 bolts thru the base with 100 x 50 mm plate on bottom to stop the
bolts pulling thru. Also feed 2 of the threaded rods thru to the rear motor compartment so happy the box won't move in an accident. Also the box sits
behind the lip at the front.
So the bug is all loaded up now and sitting level.
Cheers Kiwi
DasAuto77
Threads: 4
posted on November 16th, 2016 at 09:12 AM |
gilmore
I can vouch for the AC kit from gilmore for the bay window bus. Very complete, good instructions. Fitted it earlier this year, worked well for me in
sundays heat in brisbane.
kiwiev
Threads: 2
posted on February 5th, 2017 at 06:38 PM |
So a few updates
The 66 BUG is on the road hooning did its first Friday night lapping around town amazing the people that come out and look at her and are blown away
when they see the motor. The power is more than enough for this old girl :mrgreen:
Cheers Kiwi
Error |
kiwiev
Threads: 2
posted on February 5th, 2017 at 06:39 PM |
another show off photo
Error |
kiwiev
Threads: 2
posted on February 5th, 2017 at 06:40 PM |
And of course I had to lay some rubber
Error |
kiwiev
Threads: 2
posted on February 5th, 2017 at 06:41 PM |
https://youtu.be/K_nm5rc5bRs
a quick video
kiwiev
Threads: 2
posted on February 7th, 2017 at 01:12 PM |
and another one
https://www.youtube.com/watch?v=yumnzeMF6gY
matara
Threads: 255
Mood: 356'd
posted on February 7th, 2017 at 02:18 PM |
Looks great, nice neat build. It would be interesting to see the itemised build cost for this conversion if possible. I have been thinking about
getting a EV West kit and running it off 16550 batteries if possible.
kiwiev
Threads: 2
posted on February 7th, 2017 at 07:02 PM |
Quote: | Originally
posted by matara
Hi Steve thanks mate.
We are now supplying and installing EV west Kits in Australia with 18650 Tesla packs we can fit 30Kwh of these packs in the floor to give a solid 200
Km range PM for more details.
follow us on Instagram
https://www.instagram.com/evtorque/
Cheers Kiwi
kiwiev
Threads: 2
posted on February 7th, 2017 at 07:19 PM |
So the 66 does 0-100kph in just under 10 seconds which scares the S%^T out of me enough power to get in trouble.
SO I would like your thoughts on the blue super bug:
I have fibreglass front guards with 66-68 headlights sloop back look, will cut the rear Toranna lights out and go old school pre 60 tail lights keep
the 14" mag wheels but powder coat and polish the outer rim edge. Try and get this bug sitting at 100mm of the deck when converted to electric and
remove as much dead weight as possible.
Remove the front bumper and integrate front indicators Porsche style LED.
I know it wont be everyone's cup of tea.
All comments good and bad always welcome.
Also like this colour
https://www.instagram.com/p/BOSsMmejfJY/?taken-by=singervehicledesign
Cheers Kiwi
wombatventures
Threads: 44
posted on February 8th, 2017 at 07:49 PM |
Pretty sure you will have seen this Kiwi but thought I'd share it anyway.
https://youtu.be/9kXTqNqxK3s
kiwiev
Threads: 2
posted on February 9th, 2017 at 05:19 PM |
Yeah stay tunned to Jehu we maybe doing something together
Cheers Kiwi
nbturbo
Threads: 89
posted on February 10th, 2017 at 02:34 PM |
You have done a top job on the Bug Kiwi-it looks the part as well.I like the emblem you have on the front hood.
kiwiev
Threads: 2
posted on February 10th, 2017 at 04:33 PM |
Quote: | Originally
posted by nbturbo
Cheers mate we are installing the headliner and trying to source carpets any recommendations' mate?
Cheers Conrad
nbturbo
Threads: 89
posted on February 11th, 2017 at 04:38 PM |
No mate-I have only done one new interior.I had a new headlining made here for my Oval-because I fitted the steel sunroof,so had to modify everything
to get it fitted.The carpets I cut out myself using OG carpet pieces for templates.I had a lady edge everything with a machine they edge house floor
mats with.I will do everything the same again on the hotrod.I have a spare steel sunroof complete-been thinking of grafting it into the hotrod-just
won't be able to wind it fully back.
kiwiev
Threads: 2
posted on February 18th, 2017 at 06:53 PM |
Quote: | Originally
posted by nbturbo
Thanks mate I will keep looking.
Cheers Kiwi
kiwiev
Threads: 2
posted on February 19th, 2017 at 04:53 PM |
https://youtu.be/KCwy4iJRc8s
A wee update
Cheers Kiwi
Pages: 1 2 3 |
