[ Total Views: 4837 | Total Replies: 43 | Thread Id: 112327 ] |
Pages: 1 2 |
kiwiev
Threads: 2
posted on June 19th, 2017 at 07:10 PM |
Well I pulled the trigger on the Subigears box from Todd great bloke picking up Thursday.
Cleaned the wheels up today.
Also a pick of Subi gearbox as Todd confirmed a WRX turbo box.
Cheers Kiwi
Error |
Error |
Error |
kiwiev
Threads: 2
posted on July 5th, 2017 at 09:18 AM |
A few updates
Boxed up the rear fire wall I think it will work
got tyres on wheels
And got a a mokeup motor to mount Subarugears gearbox and mounts in
Cheers Kiwi
Error |
Error |
Error |
kiwiev
Threads: 2
posted on July 5th, 2017 at 09:20 AM |
Looks like I will have cut inner rear guards out for cam covers
Cheers Kiwi
Error |
Error |
Error |
kiwiev
Threads: 2
posted on July 19th, 2017 at 05:16 PM |
Did some more hacking and cutting to get 860mm across the back for the quad cam covers also fabricated removable rear deck. Waiting on new panel
now.
Cheers Kiwi
Error |
kiwiev
Threads: 2
posted on July 23rd, 2017 at 03:17 PM |
Fibre glassed on rear guard today a prick of a job doing it from underneath but I had to keep the guard bolted to the bug.
So now the guards are 4" wider than stock, just have to fill in the hole where I cut the Torana lights out.
Cheers Kiwi
Error |
Error |
Error |
kiwiev
Threads: 2
posted on July 23rd, 2017 at 03:22 PM |
Also while was playing around I had a thought about the cooling lines to the front, nothing was really jumping out at me going underneath. Then I had
a look at the heater tubes the poke out right into the engine bay, but trying to get 1 32 mm pipe in and around would require some serious
fabrication.
Then I remembered the hydroflow pipe I bought when we built the house it was put in the slab for heating, rated at 120 deg has a aluminium and 2 poly
pipe construction rated at 600 psi and you can bend it into shapes even right angles in 200 mm
So Do think this idea would work??
Cheers Kiwi
Error |
Yogie
Threads: 108
posted on July 23rd, 2017 at 05:23 PM |
The problem with the heater tubes being used is the heat from the pipe could produce moisture inside the tunnel which can then lead to rust. I
suppose it depends how well insulated that pipe is though but just something to consider.
Yogie
Bone
Threads: 43
posted on July 24th, 2017 at 06:27 AM |
Yes I think the hydroflow pipe would be fine. Is this the Ensign pipe?
kiwiev
Threads: 2
posted on July 24th, 2017 at 08:28 AM |
Thanks Guys
Good points to consider I live in the Snowy Mountains so low humidity and maybe a bit of warmth.
The pipe is FlowPex from Sydney at the ends I can crimp on a 90 deg or thread of tail to slip a radiator pipe on can you get 32mm ?? or do I have to
step up??
Where would I take out the front??
Thanks in advance
Cheers Kiwi
1303Steve
Threads: 556
posted on July 25th, 2017 at 08:37 PM |
You could run the tubing under the car like I did following the chassis bolts, or bring the tubing through the front bulkhead
This is how I did my engine bay widening for the cam covers,
Error |
Error |
kiwiev
Threads: 2
posted on July 31st, 2017 at 11:45 AM |
Thanks Steve
I did my a bit different but I will use the 2 tabs where you cut the rear apron to stop it from rattling.
I finished the rear guard mods and took out the torsion bars to work on the air bags , I like the low look.
Has anyone got any photos of the air bag mount please.
Thanks Kiwi
Error |
Error |
adlbeetle66
A.k.a.: Denver
Under the car.........again!
Threads: 98
Mood: ICH BIN VW NUSS
posted on July 31st, 2017 at 04:00 PM |
Those guards are FAT
nbturbo
Threads: 89
Theme: UltimaBB Powder
posted on August 1st, 2017 at 03:08 PM |
Quote: | Originally
posted by kiwiev
Thanks Steve
Thanks Kiwi
There are a few pics on my build Kiwiev.I retained the torsion bars,but machined off the inner splines to just turn in the anchor.
nbturbo
Threads: 89
posted on October 8th, 2017 at 06:38 PM |
Good day Kiwi- how is your electric motor conversion going? I can't find your original posts.I have had some out of the box thoughts on that
conversion.Would like to have a chat with you.
Pages: 1 2 |
