[ Total Views: 139410 | Total Replies: 150 | Thread Id: 35720 ] |
Pages: 1 2 3 4 5 6 |
1303Steve
Threads: 556
posted on May 13th, 2006 at 07:21 PM |
What a sleeper!
Oasis
Going alone...
Threads: 77
Mood: Deep
posted on May 13th, 2006 at 07:36 PM |
That looks BEAUTIFUL. :thumb
ricola
Threads: 9
posted on May 13th, 2006 at 07:49 PM |
Great job, that looks much better! Nice to know the horn grill ducting makes a noticable difference too
What's your ground clearance to the bottom of the scoop now?
subaruboxer
Threads: 20
posted on May 13th, 2006 at 08:19 PM |
The scoop is adjustable, I can pull down or push it in. Ground clearance is ca. 3 to 4 " (7,5 - 10 cm) I think.
[ Edited on 13-5-2006 by subaruboxer ]
72RSbug
Threads: 49
posted on May 13th, 2006 at 08:44 PM |
Great job subaruboxer, you've given us food for thought yet again.
pete wood
posted on May 13th, 2006 at 10:32 PM |
that is awesome! amazing how just that little bit of extra air makes such a difference too, great idea and a very sensible mod. BTW, I love the look
of the car too. I almost feel sorry for all those mercedes/BMW/audi drivers...well almost.
gerrelt
Threads: 3
posted on May 14th, 2006 at 03:46 AM |
Looks great! Nobody would suspect there's a radiator.
Nice, 180 km/h for 20 minutes...sounds like fun!
Greetings,
Gerrelt.
boof2332
Threads: 120
Mood: Sympathetic
posted on May 14th, 2006 at 08:18 AM |
I have those grille slits cut in mine, although it gets much more flow from the scoop under neath. I am also about to put a new, early bonnet on the
car so half the grilles will be covered anyway.
Yours is really neat...if you paint the scoop black you can hardly see it at all.
Matt
subaruboxer
Threads: 20
posted on May 14th, 2006 at 06:32 PM |
This is the scoop, I made it the with slots instead of holes.
That way I just have to loosen the bolts, to adjust it.
It has the shape of the front apron. Iif it would be straight at the ends, it would be more visible.
Error |
subaruboxer
Threads: 20
posted on May 14th, 2006 at 06:39 PM |
I used vents out of a Golf (rabbit) dashboard for connecting the hoses to the horn grills. I cut off the end and put it behind the horn grills. You
can even use the hoses that are on the vents in the Golf, but I only had one, and didn´t like to put in two different hoses.
Error |
GeorgeL
posted on May 15th, 2006 at 11:37 AM |
Quote: | Originally
posted by subaruboxer
I tested it on the German Autobahn...went three times 180 kph for 20 minutes.
It must be tons of fun to have those big Mercs pulling over for you, or do they see your bug, get big eyes, and put their foot in it?
George
subaruboxer
Threads: 20
posted on May 15th, 2006 at 09:25 PM |
Yes it is a lot of fun. It happens that I pass a car that is going at 150 or 170, the driver is looking over to me in disbelief and then he follows
me, to see how fast my bug is. If I know where his topspeed is, I sometimes just drive faster than that, there are a lot of cars here that can´t go
faster than 160 !
When I was testing the new setup with the hoses to the horn grills, a Mazda followed me the whole 20 minutes. As I left the Autobahn, he passed me and
gave me a thumb up and had a big smile on his face!
subaruboxer
Threads: 20
posted on May 20th, 2006 at 10:39 PM |
Forgot to post this picture, you can see the space left and right (arrows) and under the radiator is covered. That way all the air got to go through
the cooling surface of the radiator. If you want to have little openings in the front of the car, you have to get the rest as effective as
possible.
[ Edited on 20-5-2006 by subaruboxer ]
Error |
GeorgeL
posted on May 21st, 2006 at 08:56 AM |
possible.
Good show on the shrouding. Do you experience recirculation with the fan? Seems that air could be pushed through the radiator by the fan, then turn
around and recirculate in the area outside the fan.
Might be a non-issue if you have good ram air in motion,, but most fan setups I've seen include a shroud that covers the entire radiator.
George
subaruboxer
Threads: 20
posted on May 21st, 2006 at 07:28 PM |
Here a view behind the radiator, all the air is going out down there. I don´t think that there is any recirculation. If so, it could happen only,
when the fan comes on. The fan is very rarely coming on, so that is not an issue.
Jörg
Error |
subaruboxer
Threads: 20
posted on May 22nd, 2006 at 05:41 AM |
Hi Rich,
measured the ground clearance to the lowest point of the scoop.
It is 10 cm to 12,5 cm. Til now, I drove with the scoop in the highest position. Might need the low position in the summer. Or might not need it, as I
will get a new gearbox with longer third and forth gear. The rpm will be some 600 lower than now. That will be a difference!
Jörg
subaruboxer
Threads: 20
posted on May 28th, 2006 at 07:43 PM |
I never liked the routing of the hose to the waterpump around the outside of the engine. Always wanted to change the direction of the hose, to go
directly to the front.
Jenny posted a thermostat cover that would be just what I wanted, but I could not get the thermostat cover here in Germany. Sometimes the solution is
closer than you might believe! I took a closer look at my daily driver (Subaru Legacy Turbo) Liberty RS! And I could not believe it! It is just what I
was looking for!
I ordered a new cover at my friendly Subaru dealership.
Here is how it is looking like.
[ Edited on 30-5-2006 by subaruboxer ]
Error |
Error |
Error |
subaruboxer
Threads: 20
posted on May 28th, 2006 at 07:50 PM |
It is perfect for my conversion, you see the hose and pipe in the background in this picture. I just have to put a hose from the cover to that pipe,
and put the hose coming from the cooling manifold on the engine over to the right pipe. And change the two hoses at the front to the radiator, of
course. It is better protected now, and I have a little less coolant in my system!
Error |
seagull
Threads: 752
posted on May 29th, 2006 at 12:12 AM |
well thats great .
what headers did you get there mate ?
subaruboxer
Threads: 20
posted on May 29th, 2006 at 12:27 AM |
Hi seagull,
it is an OBX header that is made for the N/A impreza. Will custom fit it now, I am not sure yet about the catalytic converter! Have to pay a higher
taxrate without it, but would have estimated 8 horses more without it, too.
Jörg
72RSbug
Threads: 49
posted on May 29th, 2006 at 04:11 AM |
nice solution on the water pump connection there, to bad that won't work on my EJ20TT. You can polish that part to match the headers by the way (that
is if you're a nutter like myself )
subaruboxer
Threads: 20
posted on May 31st, 2006 at 05:29 AM |
It is better for me not to polish the cover!
I know, I might end up polishing all the parts and the engine, too! It is hard to stop polishing when you are into it!!
subaruboxer
Threads: 20
posted on June 4th, 2006 at 05:20 AM |
Got the new gearbox today. It has a longer third( 1.22) and fourth (0.82) gear. I am sure this will have an influence on the temps.
[ Edited on 9-6-2006 by subaruboxer ]
Error |
subaruboxer
Threads: 20
posted on August 6th, 2006 at 02:33 AM |
Here a few more pictures of the new front!
Error |
Error |
Error |
pete wood
posted on August 6th, 2006 at 03:50 PM |
damn I love your car. Such a sleeper.
Is it lowered much?
subaruboxer
Threads: 20
posted on August 7th, 2006 at 05:44 AM |
Thanks Pete,
it is not lowered that much, the front end a bit more than the rear!
flat_iv
Threads: 28
posted on August 24th, 2006 at 01:11 PM |
I read where you added a line from the bottom of your expansion tank to the heater circuit. Does your expansion tank have a small line in the top of
it? And if so, did you just plug the line up or did you route it back into the cooling system? Great find on the thermostat cover. I have one on order
now.
Richard
[ Edited on 24/8/2006 by flat_iv ]
subaruboxer
Threads: 20
posted on August 25th, 2006 at 04:38 AM |
Hi Richard,
I have a small ( 8 mm ) hose running from the radiator to the top of my expansion tank.
psimitar
Threads: 148
posted on May 10th, 2009 at 04:20 PM |
Sweet motor mate. love the sleeper look cooling solution!!!!
madness is in the eye of the beholder
VW1274
Threads: 2
posted on April 10th, 2010 at 12:35 AM |
awesome sleepy built you got there.. |
