[ Total Views: 139459 | Total Replies: 150 | Thread Id: 35720 ] |
Pages: 1 .. 3 4 5 6 |
psimitar
Threads: 148
posted on April 13th, 2010 at 12:28 AM |
I'm really tempted to see if it's possible to have 2 custom rads either side of the gearbox to do the cooling.
2 reasons. 1) I don't like the idea of having to cut the front end about and 2) hey why not be different
I do love the sleeper look tho
madness is in the eye of the beholder
Joel
posted on April 13th, 2010 at 01:16 PM |
people have tried it using motorbike rads and such
the setup works ok at low speeds but the faster you go the worse it gets till you get to the point where the fans cant keep up
Gerrelt went though it with his bug
even with fancy scoops still noone yet has found a way of getting adequate air flow through the rads at speed
Micks bug only had minimal cutting out in the front
psimitar
Threads: 148
posted on April 13th, 2010 at 08:24 PM |
nah, motorbike rads won't cut it. I mean a custom ali 3 core rad on either side of the box and possibly a vaned scoop infront to direct air from top
to bottom as a single scoop will only aid flow at the bottom of the rad.
I'm sure it's do-able but not necessarily the cheapest option which the front mounted rad surely is. I'm always one for trying to think of ways to
get stuff to work
ian.mezz
Threads: 280
posted on April 13th, 2010 at 09:07 PM |
just whack one of these radiators on the side of your bug
psimitar
Threads: 148
posted on April 13th, 2010 at 11:18 PM |
thats the one
She'll still look like a sleeper, well from the drivers side
Joel
posted on April 14th, 2010 at 10:12 AM |
there was a bug in bastards and abortions thread that had the rad mounted on the roof rack
just put an old esky around it, you'll blend right in with the ratlook pack
crimson ghost
Threads: 2
posted on May 5th, 2010 at 07:26 AM |
Car is turning out great !!!!
Corrado VR6 turbo
Karmann Ghia EJ20
itawolf
Threads: 1
posted on July 13th, 2010 at 03:47 AM |
nice look mate--and alot of good info for us
Done the RX-7 thing in a baja but now going the subie way
Bugaru03
posted on August 10th, 2010 at 12:17 AM |
is there any update be made??
P4UL
Threads: 1
posted on November 27th, 2010 at 08:26 PM |
Quote: | Originally
posted by subaruboxer
Got the new gearbox today. It has a longer third( 1.22) and fourth (0.82) gear. I am sure this will have an influence on the temps.
How did the new gearbox work out?
What r&p have you used? |
subaruboxer
Threads: 20
posted on November 29th, 2010 at 06:06 AM |
HI Bugaru03,
you are right it is time for an update. Because I havent been here for some time. But I changed my cooling system again.
The radiator is still up front, but the spare wheel is, too.
Take a look at the pictures. I rode it like that for a year.
It was pretty good for our northern climate here in Germany.
The radiator is too small for a hotter climate, for sure.
Error |
Error |
Error |
subaruboxer
Threads: 20
posted on November 29th, 2010 at 06:24 AM |
The core size of the radiator is 535 x 230 mm
Hi P4AUL,
my gearbox is great. I can shift into 4th gear at a mere 40 kph, and the engine is still accelerating fast. Not like in 3rd gear, but strong enough
for city traffic. And I can do 200 kph in 4th gear, that is at 5 600 rpm! For a test I once did 6 500 rpm in third gear. I made 175 kph then. I am
totally satisfied with the gear box. And r& p are stock.
Cheers Jörg
Error |
Error |
pete wood
posted on November 29th, 2010 at 11:19 AM |
you're a legend. Always coming up with new ways of making it stealth!
subaruboxer
Threads: 20
posted on November 30th, 2010 at 07:37 AM |
Hi Pete,
thanks, I guess you like it. Here is one more picture.
Error |
Error |
pete wood
posted on December 2nd, 2010 at 12:35 PM |
to say I like it is an understatement. well done!
gerrelt
Threads: 3
posted on December 2nd, 2010 at 07:54 PM |
Very nice!!
subaruboxer
Threads: 20
posted on December 4th, 2010 at 08:50 PM |
Hi gerrelt,
Alfa Romeo got a nice radiator in the Alfa 33 Alfasud models, it is
545 x 228 x 40 mm core size. Might use it in the future, with my new body. The beige beetle is gone, now. I did so many cuts and welds to it, I was
ready for something better. It is already painted, have to put it back together over the winter.
You have a nice website, by now. And man you have put a lot of effort into your build.
I had some problems with my computer and lost a lot of of pictures of the new body. Just got a few left.
Error |
Error |
Joel
posted on December 5th, 2010 at 09:34 AM |
Thats the one I'm running and its handled plenty of hot aussie temps already, I'm sure one would work well in Germany
gerrelt
Threads: 3
posted on December 5th, 2010 at 08:36 PM |
Thanx, SubaruBoxer!
Please keep posting updates of your project on here! You do great work.
subaruboxer
Threads: 20
posted on December 5th, 2010 at 09:26 PM |
H i Joel,
the alfasud radiator is a bit bigger, and most important, deeper than the Opel radiator. It is surely working over here. But I didn`t expect it to
work in your hot climate, too. It is even cheap. A good choice, no need for an expensive race-all-aluminum-radiator.
Hi Gerrelt,
I will keep posting new pictures of the new project.
Here a few more of the new one before getting painted.
Made a bit more space for wider radiators in the front.
And a few holes in the decklid, these are covert by the licenseplate.
Error |
Error |
Error |
Error |
ElusiveStranger
Threads: 30
posted on December 7th, 2010 at 09:50 AM |
Jorgen, what's happened to the beige one? I loved that bug!
Joel
posted on December 7th, 2010 at 11:54 AM |
H i Joel,
The Alfasud and early 33 rads like I've got work well, i know a few people running them with turbo and NA engines, the later 33 like Gerrelts are
even bigger again.
I did look at an Opel corsa rad (SB barina here) as theyre very low profile but theyre also very wide too.
subaruboxer
Threads: 20
posted on December 9th, 2010 at 06:52 AM |
Hi ElusiveStranger,
I loved the beige bug,too. But it was time for a change. When I started the conversion I picked the beige one to be the right one for all the testing
that I did. With all the cuts and welding, it was only meant to be the test bug. I always intended to replace it, when I would know what could be
done.
I gave it to a friend.
The new bug is VW dove blue, one of my favorite 1960 colours.
Hi Joel,
it is good to know, that the alfasud rad is working fine, even down under. I will use it, it is available here for 50 Euros.
Thanks for the information.
Error |
subaruboxer
Threads: 20
posted on May 7th, 2012 at 02:44 AM |
Cheers ,
finally I decided (well maybe my beloved wife decided) it is about time to put the bug back on the road.
Here some pics of the painted new body, it was painted in dove blue.
Error |
Error |
Error |
subaruboxer
Threads: 20
posted on May 7th, 2012 at 02:46 AM |
Here two more.
Error |
Error |
ElusiveStranger
Threads: 30
posted on May 20th, 2012 at 11:04 AM |
Can't wait to see what you do to this.
Shame you got rid of the old one, that rocked. :'(
madness726
Threads: 3
posted on May 27th, 2012 at 03:35 AM |
Nice, Looking forward to see what you do with this one.
Gotta work on the Nut behind the wheel before you start fixing bolts on the Car.
subaruboxer
Threads: 20
posted on May 28th, 2012 at 05:25 AM |
Here is one of the front, still lots of work left.
New subaru wiring harness and a new exhaust will be made, too.
Error |
itawolf
Threads: 1
posted on July 5th, 2012 at 10:44 AM |
same year as mine
i cant wait to see urs done
--yet i,ve
got too many irons in the fire
1960 bug ej turbo 50% done
1990 300zx 2+2 now TT and 95% done
1997 4runner with VW 1.9 turbo and 35 mudders 75% done
1999 prelude with h23 turbo 350hp --done
sander288
"Bolt-on Master"
Threads: 183
posted on March 3rd, 2016 at 09:13 AM |
Just re-read this thread; awesome build of the beige bug
Any updates on the Dove Blue beetle?
