[ Total Views: 150896 | Total Replies: 70 | Thread Id: 40166 ] |
Pages: 1 2 3 |
seagull
Threads: 752
posted on August 8th, 2005 at 01:56 AM |
2
Error |
seagull
Threads: 752
posted on August 8th, 2005 at 01:59 AM |
while your there get a EH / HR sway bar and mount under there , pick ups for the rods of your arms , just close your eyes and think about itnn[ Editedon 7-8-2005 by seagull ]
nbturbo
Threads: 89
Theme: UltimaBB Powder
posted on August 8th, 2005 at 01:37 PM |
Had my eyes closed for a while-still don't see anything.Been a few years since I have done any work on one of those.Does it hook into the 2 holes in
the lower shocker mount???
seagull
Threads: 752
posted on August 10th, 2005 at 01:47 AM |
I post a photo for you in the next day or so .
nbturbo
Threads: 89
posted on August 10th, 2005 at 10:33 AM |
Thanks.
nbturbo
Threads: 89
posted on August 17th, 2005 at 10:17 PM |
Come on Neil-pics please.
nbturbo
Threads: 89
posted on September 6th, 2005 at 02:07 PM |
How about the pics Neil?????
nbturbo
Threads: 89
posted on September 24th, 2005 at 12:17 PM |
Seagull Neil-what happened to the pics?????????nn[ Edited on 24-9-2005 by nbturbo ]
seagull
Threads: 752
posted on October 6th, 2005 at 01:02 AM |
shit I get on to it , sorry
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on January 12th, 2006 at 06:20 PM |
I'm following this thread with great interest, been wanting to do this conversion myself (into my manx) for years. I've got 4 automatic boxes etc
sitting in my shipping container just waiting for me to get couragous and attack my floorpan. Was thinking of supporting the gearbox with a frame from
on top.
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on January 12th, 2006 at 06:57 PM |
Sorry I forgot this in my first post, If you want to know how the trike buiders attack the problem check out http://www.dingbobtrikes.com/trikeframe_03SA_2.htm .Also I
don't know if this the right site mentioned by nbturbo about autostickshift beetles but here it is anyway http://www.vwar.org/
Quote of the week
nbturbo
Threads: 89
posted on January 12th, 2006 at 10:22 PM |
Manx-if you do it like mine and it's in a buggy-you don't have the issue of trying to get the motor to fit properly in the engine bay so it seals
up.You don't have to worry about the correct height either-just have to get it central.If you had a decent roll bar set up-you could fabricate
something like Seagull does on his trikes and do away with the frame horns altogether.I wanted mine to look like a Factory set up from the outside as
much as possible.Thanks for those links-they are good.Want to build a Trike one day with the motor up front like a normal bike-the blokes building the
trikes will be very handy.There are a couple more pics in Members rides under Ovals progress.
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on January 15th, 2006 at 07:39 PM |
1957 Oval
Here is a '57 Oval I've been trying to get for the past 12 months. Unfortunately no progress yet.
Error |
Error |
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on January 15th, 2006 at 07:59 PM |
1957 Oval
as is
Error |
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on January 15th, 2006 at 08:02 PM |
1957 Oval
this is the only real damage to the body apart from stone chips to the insides of the guards "star fracturing" the paint on the outsides
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on January 15th, 2006 at 08:04 PM |
1957 Oval
sorry here's the photo
Error |
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on January 15th, 2006 at 08:08 PM |
1957 Oval
The sunvisor and centre gauges in the dash were fitted by the dealer when purchased. There is also a hubcap style toolkit (unsighted).
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on January 15th, 2006 at 08:18 PM |
1957 Oval
Sorry I'm have trouble with the size of my photos
Error |
Error |
Quote of the week
nbturbo
Threads: 89
posted on March 29th, 2006 at 02:04 PM |
Not much progress of late-got the body back on with motor and trans bolted up-everything fitted perfectly.Trans is in Adelaide at the moment getting
overhauled and beefed up.Convertor has been modified and the front clutch hub is being machined for an extra plate.Will be another fortnight until
finished.Doesn't look like I will be able to run an external cooler-the trans doesn't have any ports in the lubrication circuit to "T" off for a
cooler.Have had all the new mounts,shock tower braces and dipstick tube coated in a gold passivated finish to look a bit flasher than being
painted.
[ Edited on 29-3-2006 by nbturbo ]
Error |
Adolph
Threads: 6
Mood: Fast
posted on May 11th, 2006 at 02:59 PM |
Looks great
Any progress?
Looking to do something similar to my 62 ragtop with type 4 turbo.
Hermann
2000cc turbo type 4, dragster (325Kw)
2714cc no turbo, no gas, street bug (140Kw)
nbturbo
Threads: 89
posted on May 11th, 2006 at 03:39 PM |
You must be Physic-going to Adeaide this weekend to pick the trans up-has had a full rebuild and some beef up mods done.Will get stuck into the refit
next week.Still have to fit a kickdown switch and find a vacuum supply for the modulator.Will keep you posted.
nbturbo
Threads: 89
posted on June 21st, 2006 at 07:31 PM |
At last-fired the motor today and have had the car move in both directions.still need to add a little more trans fluid.Got a small fuel leak issue at
the "T" piece I made between the 2 carbies.Have to get a couple fittings in the morning and can then drive it.
[img] [/img]
seagull
Threads: 752
posted on June 27th, 2006 at 02:23 AM |
This is set up as a top mount , it can be fliped up side down .I be doing this to the 60ie bug
Error |
seagull
Threads: 752
posted on June 27th, 2006 at 02:25 AM |
This would be the cheapest mod to your bug to make it hold the road .The units from a hr holden front .Most modern cars have units fitted
Find a new ford in a car park and have a look under it
nbturbo
Threads: 89
posted on June 27th, 2006 at 11:56 AM |
Thanks Neil-have already put that job on the 'to do' list-still have to round up a good one for the front.
nbturbo
Threads: 89
posted on June 27th, 2006 at 09:08 PM |
Pulled the shifter assembly out again and pulled the lever out.When I put the lever into "Park",it was too far forward and a pain to to get at-so I
applied some heat and bent it so that it now sits vertical in "park" and is real easy to use.Must be good steel,because it didn't tarnish with the
heat,so just polished on the buff and it looks like chrome.
[img] [/img]
seagull
Threads: 752
posted on June 27th, 2006 at 09:41 PM |
I have a shift lock system you can make for this , works off the alarm
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
posted on March 30th, 2009 at 02:12 PM |
How's this project going these days?
nbturbo
Threads: 89
posted on March 30th, 2009 at 06:06 PM |
I have been driving it now for about 18 months.It's everything I hoped it would be.Had a lot of trouble with the fuel injection which took a couple
of months to sort out.I put it on the road around September 07 and haven't had to repair,adjust,bend or modify anything.It has a slight weep from the
auto pan gasket which is a cork type.I will make a new one from gasket material when I change the oil and check the band adjustments(probably won't
need doing for at least 12 months) I have had it on the Drag Strip and changed gears manually.Had trouble working out when to change up just B4 it hit
the rev limiter.Too busy to watch the Tacho.I am now definately going Auto in my Drag Car-I am in the middle of modifying it to fit a Kombi auto.Much
better diff ratio than the Type 3 auto.
nbturbo
Threads: 89
posted on March 19th, 2012 at 07:57 PM |
For Dave-VW54.Good for a read.
Pages: 1 2 3 |
