[ Total Views: 20038 | Total Replies: 58 | Thread Id: 49875 ] |
Pages: 1 2 |
Anthiron
A.k.a.: Nicko McKay
The Baja Rejuvenation Begins
Threads: 310
posted on August 29th, 2009 at 03:40 PM |
Chris, how far advanced did you have your timing?
it had nothing to do with the fuel and everything to do with your advance.
ask drag racers why they dont run the same advance on their street cars that they do on their drag cars........cos they will go boom.
I run 98BP Ultimate in my baja. its the only fuel that i trust. Shell 98 runs like crap in my engine and ive been burnt by bad fuel from independents
too many times.
i rarely run a valve lubricant. sometimes i do just for kicks. maybe every 8 or so tanks i put a little bottle of valve saver in.
i run my 009 statically timed to 7.5BTDC and i have no issues.
1974 Chevrolet Luv
1970 MK2 Ford Cortina GT
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on August 29th, 2009 at 04:15 PM |
yep and a 009 has a 22 deg advance curve.......so 7.5 static plus 22 will give you 29.5deg max advance
If you think high octane fuels run hotter than low octane fuel in the same motor you're a goose
Gixer41960
Threads: 4
posted on November 16th, 2009 at 09:11 AM |
I only run 98 octane in my car as I know that they don't add additives like ethanol to it.
Ethanol will introduce too much water to the vehicles fuel system and engine causing problems with corrosion etc.
68AutoBug
posted on December 14th, 2009 at 04:12 PM |
Quote: | Originally
posted by Anthiron
009s need to be timed at maximum revs to get the correct timing... 30-32 degrees maximum revs...
I have been using SHELL 95 & 98 in My 1600 single port engine for the past few years [engine overhauled low kms]
and recently I filled up with normal ULP and My beetle has been going the best it ever has gone... I had installed new spark plugs and leads, dizzy
cap and points.. tappets done.
I do have a new SVDA with Pertronix to fit soon..
[from air cooled.net in USA]
the timing has NOT been adjusted... apart from adjusting the points.. always checked with a timing light...
68AutoBug
posted on December 14th, 2009 at 04:18 PM |
Quote: | Originally
posted by Gixer41960
Ethanol is ONLY in Petrol that IS labelled ETHANOL... E10 etc..
Not in any others... it cannot be added to ULP without being labelled...
I ran a magna for years with BOGAS petrol with Ethanol...
without any problems...
although I wouldn't use E10 in My beetle... or any of My cars now,,, not because of the rust?? issue...
Gixer41960
Threads: 4
posted on December 22nd, 2009 at 07:11 PM |
Water is attracted to ethanol, newer cars that run platic and rubber throughout everything don't have as much a problem but older cars that have
metal fuel tanks and fuel lines etc will find problems with the extra water that is running through the car. I've heard that the eastern states plan
to have ethanol mixed fuel only at the pumps in the near future and that includes higher mixes of e20 and up. The following quote is from - FCAI
SUBMISSION TO THE VICTORIAN INQUIRY INTO MANDATING THE USE OF ETHANOL AND BIOFUELS IN VICTORIA
AUGUST 2007
"ETHANOL/PETROL BLENDS
EXISTING VEHICLE FLEET
MATERIAL COMPATIBILITY ISSUES
The use of E10 blended petrol is widely accepted in many modern makes of car. However, ethanol can cause early deterioration of components in fuel
systems such as fuel tanks, fuel lines/hoses, injector seals, delivery pipes, fuel pump and regulators, particularly in older vehicles.
Vehicles with carburettor fuel systems may experience hot fuel handling concerns and may also experience a lower level of durability in some fuel
system components.
Some manufacturers advise not to use E10 with any model equipped with a carburettor because of material incompatibility.
Also this was taken from our RAA web site on E10 fuel.
Will Ethanol damage my vehicle or affect its performance?
Most metal components in fuel systems will corrode or rust in the presence of water. Ethanol increases petrol's ability to absorb water without
separating and Ethanol blended petrol can therefore ‘hold’ more water and carry this through the engine. The greater the concentration of ethanol the
greater the ability to ‘hold’ water.
Several studies have examined the effect of E10 on fuel tanks and fuel system components and have concluded that ethanol up to 10% does not increase
corrosion in normal, everyday operation.
Ethanol blends may have a deteriorating effect on the rubber components of an engine. Other additives, such as benzene may also have an effect.
In older models, deposits in fuel tanks and fuel lines are occasionally loosened by E10, and the fuel filter may become plugged. This is remedied by a
fuel filter change.
If very Ethanol rich fuel is used this may cause an engine to stall.
Laboratory tests have shown that blends of 20% pure Ethanol in petrol can damage some conventional automotive paint.
chippy
Threads: 14
Mood: Volksie!
posted on January 31st, 2010 at 08:14 PM |
I have glanced over the previous posts to ask this, so please forgive me if it has been answered. Do I need to use a lead additive in a 66 beetle? I
dont even know if it is still available. The last time I owned a leaded fueled car the price of fuel was 55c/l . Do I need to "retune" my engine to
run better on unleaded( be it ULP PULP or E10) and if so what needs to be done?
Cheers Todd
Lettuce
Threads: 0
posted on February 22nd, 2010 at 01:31 PM |
You should be able to use straight unleaded fine, but adding a lubricant isn't a bad idea. You shouldn't need to re-tune. |
Uber Kafer
Threads: 50
Mood: Need a bigger shed..
posted on March 2nd, 2010 at 10:39 AM |
with regards to the comments about ethanol on older cars, I recall reading something somewhere (would have been on the internet so it must be true)
that ethanol has different fluid properties to normal petrol and tends to flow though weak points that petrol wont flow through (leak).
So, and apart from the corrosion problems caused by the water holding properties outlined above:
Ethanol doesnt so much cause failures in older fuel systems, it 'finds weak points'....
Theres a difference between chemically destroying components, or leaking past them.
Note: I'm not bothered if this is debunked, but its the best I can recall.
Paulc1964au
posted on March 16th, 2010 at 08:23 PM |
Let me get this straight I can use Premium unleaded in my 1969 VW (it has a 1600 twin port).
I was going to add a Fuelstar inline catalyst but after reading this thread premium unleaded will be just fine???
Lucky Phil
Threads: 16
Mood: I'm a legend in my own lunchtime!
posted on January 1st, 2011 at 11:06 PM |
Quote: | Originally
posted by bajachris88
Quote: | Originally
posted by humpty
Higher Octane = Cooler running.... And I have never run additives either...
no no!
As octane gets greater, the Hotter in fact it actually runs.
the burn is slower, and more 'heat' energy is released. if the octane is high enough, the burning fuel would actually still be in the burning
process whilst passing through the exhaust valve and manifold, resulting in burnt valves and a dramatic increase in engine bay temperature.
{NOTE: this is not a back fire as the 'ignition' for this burning mixture took place in the combustion chamber, however is finishing up in the
exhaust manifold)
(practically the complete opposite of detonation/pinging from 'too low' octane which obviously you don't want from too low octane otherwise it
ain't half obvious that internal pressures are going to go off the charts).
I speak from a VERY nasty experience after running a combo of 98 octane and 4 point nulon racing octane booster. (yes stupid but it was an experience
to get the most hp by advancing the ignition as much as possible with the higher octane to increase the ability to advance the timing without any
pinging). mind you that was ONE VERY nasty cruise. overheating is never fun.
People have established that unleaded fuel is vw friendly. if it pings at 91 octane, check that timing is not too advanced and properly timed. if it
is, then go 95 octane. but there is no need to jump to 98 if 95 isn't pinging. It will run hotter with no hp benefits, unless you advance the
ignition timing by feel to keep the 'mixture burn' in that combustion chamber.
and you would probably squeeze a couple more hp by advancing so as the higher octane contains the greater energy. I doubt 98 would cause any damage
though, but let it be out there that it will definitely not run cooler with a higher octane.
It may or may not pose any damaging threats, but if 95 works, why risk unless certain?
baghall
Ben Hal Outlaw Bushranger
Threads: 131
Mood: Kids think I'm obsessed!
posted on February 12th, 2011 at 04:20 PM |
I've always run additive thinking that I needed to, but it seems I may not need to. My only concern is that I have no idea when the heads on the
engine were made, due to the amount of modification and time that VWs can have on them.
68 Baja - It's a growing pain!
58 Baja ute - and the pain spreads!
85 T3 Kombi - still growing
89 T3 Kombi - parts car
helbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on February 12th, 2011 at 04:38 PM |
Been running standard 91 unleaded in our stock 1971 Beetle for 5 years. No additives, and it has been fine, goes quite well.
Paulc1964au
posted on February 12th, 2011 at 04:55 PM |
Problem is hard to find 91 that doesn't have ethanol these days so i usually use 95 and use an additive
humpty
Threads: 139
Mood: Totally boosted!
posted on February 12th, 2011 at 09:20 PM |
It amazes me that this thread keep coming back.... If you have an engine that was either built or rebuilt since 1970, you will have no problem running
unleaded fuel.... All VW engines should be running hardened seats and silicone bronze valve guides...
Run the best fuel you can afford.... I use only 98 in my cars (the octane argument aside).... And even then only Caltex.... BP is shit IMHO..... I
have never had any problems since I made the change way back in 93...
68AutoBug
posted on February 12th, 2011 at 10:45 PM |
YOU CANNOT BUY LEADED FUEL ANY MORE
YES
This thread keeps popping up....
ALL Petrol sold in Service Stations across Australia is UNLEADED..
The New Problem is ETHANOL.....
I lose about 40% of power using 91 with ethanol...
You can still find NON Ethanol 91 petrol at older service stations
ALL New Servos in NSW Only have 91 BIO with Ethanol...
NON Ethanol 91 was supposed to be phased out this year in NSW... but due to the floods... and crop failures..
the date has been put back another year...
I use 98 plus valve saver... SHELL usually...
so... You do Have to Use Unleaded Petrol in Your Beetle...
ETHANOL --- its up to You....
Error |
humpty
Threads: 139
posted on February 13th, 2011 at 12:42 AM |
Can't get ethanol-unleaded or bio-ethanol blends here at all.... This is the wild west after all!!!!!.... Though I am looking forward to E85
arriving.... I hear it works wonders with turbo charged engines!!!
barls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 295
posted on February 13th, 2011 at 08:39 AM |
Quote: | Originally
posted by humpty
strange cause i only use bp or shell in the bug dont like caltex at all.
Paulc1964au
posted on February 13th, 2011 at 08:54 AM |
Quote: | Originally
posted by humpty
So since i have a 1600 TP in my 69 (yes not the original motor) I do not need to use an additive?
Bizarre
Threads: 730
posted on February 13th, 2011 at 08:59 AM |
no
70AutoStik
Threads: 18
posted on February 23rd, 2011 at 06:23 PM |
Can the moderators add this to the top of the front page of this site - you do not need to use an additive or lead in any stock VW!
Valve seat recession was an issue with cast iron heads - no exported or otherwise non-German VW ever used cast iron seats. Chrome stemmed exhaust
valves should exist in any engine still alive, and any dodgy jobs will need a rebuild anyway - cast iron seats fall out.
Stock engines built for Australia will work on the fuel they were designed for, which is now standard unleaded. If, you have raised compression,
witnessed pinging or other signs of detonation, you should consider higher octane fuels. If your engine is overheating, find the problem and fix it -
it is unlikely to be the fuel.
Lead should only be required for strip engines running titanium or some lightweight stainless valves, or aircraft, and is not legal in most of
Australia (some outback areas excepted, mostly in WA and NT.)
Calorific value and burn rate are not octane-specific, but are designed in to a degree by manufacturers. Economic factors tend to make these end up
fairly consistent, outside of the ethanol factor.
Any stock engine should run just OK with ethanol blends as they tend to be set uo rich, but they should be avoided in vehicles which are not regularly
used due to the abovementioned hydrophilic properties.
If your rubber fuel hose is 40 years old, replace it! Rust is a problem in some parts of Australia and not in others. If you are doing a resto, I'd
have a look at PPC or similar treatments. Stainless line is a good investment, too.
Imac
Threads: 0
posted on March 9th, 2011 at 11:36 AM |
http://en.wikipedia.org/wiki/Octane_rating
GO HERE READ AND LEARN
68AutoBug
posted on March 9th, 2011 at 05:17 PM |
UNLEADED FUEL - ETHANOL FUEL ...
[size=5]No..
fuel with lead has been banned for years now
so, You cannot buy it from any service stations...
VW engines do not need an additive in the fuel to lubricate the valve stems etc...
BUT.... Many people who own VWs DO use Valvesaver or A similar additive to the fuel... it cannot hurt the engine and may help to lubricate the valve
stems...
I have only just started to Use Valve saver in My fuel....
I ONLY Use fuel without Ethanol in My beetle as I lose about 40% of My engine Power by using it....
There are still some small independent BP stations selling Unleaded 91 without Ethanol....
with larger fuel stations I use 98 Unleaded.... which is higher octane and has cleaning additives in it...
I also have used 95 unleaded also..
because of crop failures... Unleaded fuel without Ethanol will be produced for another year.....
[/size]
Error |
Error |
h
posted on March 23rd, 2011 at 09:16 AM |
OMG i needed my sunnies on looking at the above
why are people so unkind..?
still been running BP 98 with flash lube for over umpteen years now and no probs here
bring back leaded fuel and this will all go away..
leaded paint on the weatherboards still goes on and on and on and when we were kids its tasted good too for an arvo snack as we couldn't afford food
AA003
A.k.a.: Phill
Threads: 39
posted on December 7th, 2011 at 12:47 PM |
What about Opal?
Opal Fuel
I read it on samba, so it must be correct.
Sometimes Volkswagen dealers sell spare parts. Amazing isn't it!
68AutoBug
posted on December 7th, 2011 at 01:32 PM |
I haven't heard about OPAL fuel
Is unleaded fuel with Ethanol now used in Western Australia??
I know ethanol was illegal years ago... in Western Australia..
when BOGAS fuel in NSW used ethanol in their petrol..
annosL
Threads: 43
Mood: need to win lotto
posted on December 7th, 2012 at 04:27 PM |
No ethanol used in fuel here, too far from the sugar cane! but that might change now the chinese own stage 2 of the Ord
68AutoBug
posted on December 8th, 2012 at 10:30 AM |
Found a woolworths caltex servo selling NON ethanol unleaded
fuel yesterday about 5 cents a litre more than ethanol fuel..
DubbyDo
A.k.a.: Dave
Threads: 45
Mood: need more compreshunn!
posted on December 8th, 2012 at 01:49 PM |
Quote: | Originally
posted by AA003
What about Opal?
Opal Fuel
We only have Opal and BP 95 premium here. The premium is $2.05 L at the mo and Opal (which is heavily subsidised by the gov) is about $1.90L. I only
ran the premium but at nearly $70 a tank I thought I would try the Opal. After 6 tanks and no valve saver it is still running sweet if anything it
seems a bit smoother
Pages: 1 2 |
