[ Total Views: 152569 | Total Replies: 200 | Thread Id: 57814 ] |
Pages: 1 2 3 4 .. 7 |
76bug
Threads: 20
posted on January 9th, 2007 at 12:22 PM |
the induction is a quad throttle body arragement using zx12r T/B's sitting on modified idf manifolds
cant wait to get it running:P
56astro
Threads: 74
posted on January 14th, 2007 at 01:27 PM |
Did some more work on the conversion today.
Fitted the HP fuel pump. I kept the rubber collar, added some extra foam, and supported the bracket bolts with some garden hose.
Here are the HP pump and pulse dampener, and new bracket.
Here it is in its new home.
I also mocked up a possible intake system. The volume of the plenum is OK, but the runner volume may be a tad out.
I will take the "model" to the fabricator's workshop (where the engine is ATM) to check for fitment.
35MPG on 101.3kPa
56astro
Threads: 74
posted on January 14th, 2007 at 01:35 PM |
Updates here as well:
http://home.people.net.au/~astro/EFIconv.html
35MPG on 101.3kPa
pete wood
posted on January 23rd, 2007 at 05:58 PM |
nice website, btw, which intake manifolds did you end up using, couldn't quite make it out.
56astro
Threads: 74
posted on January 23rd, 2007 at 08:28 PM |
This one, on the left.
[ Edited on 23-1-2007 by 56astro ]
35MPG on 101.3kPa
pete wood
posted on January 24th, 2007 at 11:57 AM |
cool. how difficult is it to get a pair of them?
MickH
A.k.a.: Michael Hutchinson
Hairy Gutted Sloth
Threads: 29
posted on January 24th, 2007 at 01:43 PM |
Looking good!! I ran a LINK ECU on my 1916.Was dead easy to tune with the hand held and installment was a breeze.The final dyno adjustment was
minimal.The guy in Townsville that sells them also sells many other brands,but uses the LINk on his Fink race car...sitting out in the dust and rain
and it hasn't failed....so they must be OK. How lomg until this one is up and running????
tssnq.com.au
56astro
Threads: 74
posted on January 24th, 2007 at 04:14 PM |
Pete,
Not difficult at all. There are 2 suppliers from Mexico. One is far cheaper than the other. Under $1000 so no duty or GST. UPS is the big killer.
Mick,
I also like the link. There appears to be a lot of 2nd hand EMS units on ebay, so I'm assuming they are being installed, not performing all that
well, and then being replaced.
Link seem to have a really good reputation for being robust.
35MPG on 101.3kPa
tassupervee
A.k.a.: Knob Jockey
That really hurts doesnt it!
Threads: 25
Mood: Moody!
posted on January 24th, 2007 at 07:17 PM |
There is a lot of unfair press about EMS ecu's.
Ive found that very few tuners are comfortable with the EMS tuning sequence which is entirely different to, say a Microtech where you just choose from
one of the load parameters ( say "x" psi boost or 15"Hg Vac.) and tweak the settings whilst strapping the engine at 3 to 4000 rpm.
Then finer trimming is done with the wide open throttle and cruise trimmers
The EMS utillises 3 main load areas, -50, zero and +50 KPA that are further divided at 500 rpm "load points"
The ECU interpolates between the 3 load areas and predicts a fuel curve between them for a particular RPM range.
Ignition is adjusted in the same manner.
So, in order to tune, each of the three parameters is adjusted over the entire rpm range (500rpm increments) and then any bumps and dips in the
mixture range is trimmed using fuel "curve modifier" trimmers which are kinda like main microtech tuning points. Allows an alteration to mixtures
at a particular manifold pressure/vac but over the entire RPM range
It does take some time to get your head around and if used to the "other" tuning interface, it can be very confusing but is actually surprisingly
easy to use after some practise.
L8tr
E
Im not a complete idiot, quite a few parts are missing....
56astro
Threads: 74
posted on January 24th, 2007 at 08:36 PM |
Thanks for the info E
35MPG on 101.3kPa
Judsons4eva
Threads: 24
posted on January 31st, 2007 at 08:04 PM |
Guys
I have a Gotech MFI
http://www.gotech.co.za
Imported from South Africa. Good support, a forum, standard maps for various VW's. supports O2 sensors and MAP or TPS, comes with harness and senors
are available at reasonable cost
AND it works
Ken
550 Porsche Spyder
56 Oval mit Judson
96 Porsche 993 C2
tassupervee
A.k.a.: Knob Jockey
Threads: 25
Mood: Moody!
posted on January 31st, 2007 at 08:27 PM |
Ive heard some nice reports about GoTech ECU's and are evidently very well priced.
L8tr
E
Judsons4eva
Threads: 24
posted on January 31st, 2007 at 10:15 PM |
yes less than $500
550 Porsche Spyder
56 Oval mit Judson
96 Porsche 993 C2
56astro
Threads: 74
posted on February 1st, 2007 at 05:43 AM |
There isn't much info on their site about the ignition set-up. That's where I seem to be having the most problems. Even with Haltech E6X I would
have been required to run 2 dual ch ignition modules.
Some of the other lesser known units cope with twin ignition far easier.
35MPG on 101.3kPa
76bug
Threads: 20
posted on February 1st, 2007 at 08:20 AM |
the michrotech x4ignition modual is $150 this is i have for my car, if u give them a call they will be able to tell wether it can handle firing the
twin plugs. thats if u wanted to use a microtech
Judsons4eva
Threads: 24
posted on February 1st, 2007 at 08:32 AM |
On Gotech you can run either with their on-board ign module or an external module. You can also run multiple coils but that complicates the trigger
wheel set up. Download the manual on the site it give you the detail. http://www.gotech.co.za
550 Porsche Spyder
56 Oval mit Judson
96 Porsche 993 C2
56astro
Threads: 74
posted on February 1st, 2007 at 09:32 AM |
I tried to open 2 of the .pdf files (install manual and twin spark install) and both had problems.
35MPG on 101.3kPa
KruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
posted on February 1st, 2007 at 06:55 PM |
Steve, I beleive you need to get yourself an ECU from a Lada Niva; still the AC Delco as used on Holdens, but suitable for crank-fired coilpacks.
Kruizin Kol
VWCOOL
Threads: 235
Mood: happy to help
posted on February 1st, 2007 at 08:52 PM |
Quote: | Originally
posted by KruizinKombi
The 'upright tail light' Ladas used a Haltech
Won't the Delco ECU (FamilyII-powered Pulsar/Camira) crank-fire, like V6 Commodore?
[ Edited on 1-2-2007 by VWCOOL ]
Pay your debts, CxxT
Judsons4eva
Threads: 24
posted on February 1st, 2007 at 09:55 PM |
Re Downoading Gotech manuals - I had the same problem. Best to right click on adobe link and "save target as" You can open the downloaded file. If
you have trouble I'll email the to you.
Ken
550 Porsche Spyder
56 Oval mit Judson
96 Porsche 993 C2
56astro
Threads: 74
posted on February 2nd, 2007 at 07:11 AM |
Quote: | Originally
posted by VWCOOL
Twin Ignition
Even an 8 cylinder wasted spark set-up won't be a simple swap to a 4 cyl twin ignition system. So when you factor in the $1100 Kalmaker software, the
aftermarket units are even more attractive.
Unless I'm missing something (along with the Tech gurus @ Haltech!)
35MPG on 101.3kPa
VWCOOL
Threads: 235
Mood: happy to help
posted on February 2nd, 2007 at 09:05 AM |
ah yes I forgot you were twin plugged
56astro
Threads: 74
posted on February 14th, 2007 at 03:10 PM |
Got a package from Mexico yesterday.
I got the left and right fuel rails as well as the end castings.
New stand as well.
Note the rebate for the twin runners.
29mm ID.
30mm ID. You might just be able to make out the injectors.
Left runner sitting in position.
Right runner sitting in position.
For some reason the [img] code isn't working
[ Edited on 14-2-2007 by 56astro ]
35MPG on 101.3kPa
56astro
Threads: 74
posted on February 14th, 2007 at 03:42 PM |
Any way,
updates here as well:
35MPG on 101.3kPa
ratty 63
A.k.a.: Rossco
Threads: 74
Mood: Just cured my shed envy!
posted on February 15th, 2007 at 10:19 AM |
hmmmm, nice end castings!
Quote: | Originally
posted by VWCOOL
FYI: The Delco ECU only controls the timing of the spark, not the way in which it is distributed. There is a control board on the bottom of the coil
pack mounting plate that ensures that the correct coil fires when it is required to do so, therefore you can use an ECU out of any Delco fitted
vehicle to run any number of cylinders - you just have to fit the correct dissy or coil pack... This is why I have set up my engine with a Camira
Dissy to begin with, and once everything is up and running I will change it over to a 4 cyl coil pack and use the space wher e the dissy was to mount
the A/C compressor....
R
56astro
Threads: 74
posted on February 15th, 2007 at 01:23 PM |
Quote: | Originally
posted by ratty 63
....... and use the space wher e the dissy was to mount the A/C compressor....
R
COOL
:thumb
35MPG on 101.3kPa
VWCOOL
Threads: 235
Mood: happy to help
posted on February 15th, 2007 at 03:56 PM |
hey Astro, check for body/injector clearance before you try install the engine. The body on my EFI Beetle is different to my other cars - it is
'swaged' along the sides of the engine bay for extra room
56astro
Threads: 74
posted on February 15th, 2007 at 04:15 PM |
Thanks for the tip GT.
On the mock up the fuel rail doesn't extend past the edge of the tinware by much at all. The edge of the tinware is a couple of inches or so inside
the engine bay.
Hopefully I can avoid some body work.
35MPG on 101.3kPa
koolkarmakombi
enkarmarising
Threads: 158
Mood: do you see the bats?
posted on February 15th, 2007 at 04:29 PM |
So if I find an upright tail light lada niva I can get a haltech ecu from it to use as well?
I always wondered with those ladas, essentially a fiat 1500 with added efi to meet local regs. Since the efi is added locally it could be well
adaptable to our cause.
Did you get my u2u COOL ?
kkk
Quote: | Originally
posted by VWCOOL
This disclaimer does not reflect the thoughts or opinions of either myself, my company, my friends, or my dog: don't quote me on that; don't
quote me on anything; this disclaimer is subject to change without notice; text is slightly enlarged to show detail; resemblance to actual persons,
living or dead, is unintentional and coincidental; dry clean only; do not bend, fold, or mutilate; anchovies or jalapenos added to this disclaimer
upon request; your mileage may vary; no substitutions are allowed; for a limited time only while supplies last; offer void where prohibited; this
disclaimer is provided "as is" without any warranties expressed or implied
VWCOOL
Threads: 235
Mood: happy to help
posted on February 15th, 2007 at 05:06 PM |
As far as I know, yes. But I don't know if it was a specially-built box or what... just that it was a Haltech box. It was alooong time ago!
Don't think I got the U2U...?
EDIT: maybe it was a GM/Delco box installed by Haltech...? The plot thickens!!
Quote: | Originally
posted by koolkarmakombi
kkk
Quote: | Originally
posted by VWCOOL
[ Edited on 15-2-2007 by VWCOOL ]
