[ Total Views: 141867 | Total Replies: 127 | Thread Id: 59063 ] |
Pages: 1 2 3 4 5 |
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on May 15th, 2010 at 06:19 AM |
Quote: | Originally
posted by Craig Torrens
Congrats Keith.......you should have told me, I would have run mine tonight as well !
I thought you were scared of going in a straight line Craig!! Not too many corners on a drag strip LOL
So do this mean you'll be at warwick to give Keith a run??
Congrats on getting the car running Keith. Been reading this thread from day dot and nice to see the hard work paying off!!
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on May 15th, 2010 at 10:02 AM |
Quote: | Originally
posted by LIFE IN THE LOW LANE
not scared....just bored with it.
BUT, knowing my little 1916 wil get me into the 12's in a street car has given me some excitement.
I'm sure Keith and I will enjoy blowing away modern cars at WSID on a regular basis.........certainly easier than driving for 10hours to run the
1/8th
Keith you started out using a new alley case in the first pics and then it seems you ended up using a mag case.....any reason why ?
LOWBUG
Threads: 33
Mood: OUT OF CONTROL
posted on May 15th, 2010 at 04:52 PM |
1/8th
Craig, are you getting 12's out of your 1916. Wow that impresive, what sort of power is it making at the wheels?
Jak Rizzo
Threads: 67
Mood: Pastizzi eating
posted on May 21st, 2010 at 06:51 AM |
Hi Keith, hope u don't mind me posting this.
Car looks fantastic, pics don't do it justice. Glad to see it running.
regards
Jak
Error |
LOWBUG
Threads: 33
posted on May 26th, 2010 at 08:45 PM |
Hey Kieth, when ya going out for skid next?
Keith Haeusler
Threads: 40
posted on May 26th, 2010 at 09:48 PM |
Lowbug,
Will head out next wednesday if weather permits. If not the one after.
Regards, Keith.
71-BEETLE-SEDAN
AKA Josh
Threads: 108
posted on May 27th, 2010 at 08:33 PM |
kieth, make sure you post here when your gunna take it to the drags
colin
Threads: 82
posted on June 16th, 2010 at 07:53 AM |
Good luck tonite Larry, give it heaps!
Cheers Col
dangerous
Mood: 591
posted on December 23rd, 2010 at 08:14 AM |
Quote: | Originally
posted by Keith Haeusler
Hi,
Here are a few shots of the thrust on the centre main saddle. I saw a photo of a case done like this in the US so thought i`d give it a go.
I had the saddle machined to accept the thrust bearings then had 2 steel rings machined up and white metalled. Split the rings and drilled and tapped
saddle. Then surface ground the backs of the bearings until i had the correct endfloat.
The screws sit about 1mm below the bearing surface.
What do you guys think? Should i cut some small grooves into the face of the bearing for oilling?
Regards, Keith
And thanks CT for the computer lesson!
Here is how I tackled the "quality thrust bearing issue" for use with the flanged cranks.
This case was purchased through scat as having "type 4 mains tunnel",
but it is just your regular bubble top alum case,
that they sent out to Rimco for a line bore to type 4.
First step was to counterbore a recess
to match the Toyota thrust washer at the FW side:
And then one in the inside too.
The thickness if the web must be controlled to have the correct end float result!
Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
posted on December 23rd, 2010 at 08:21 AM |
The flange's diameter will block most of the oil return hole, so a new one must be drilled.
I added two extras because this set-up also has a small hole drilled to let fresh oil onto the thrust face.
Normally the thrust is oiled by the system after it has passed through the journal diameter.
Key ways are cut front and rear to stop the thrust washer from rotating:
Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
posted on December 23rd, 2010 at 08:22 AM |
Quote: | Originally
posted by 71-BEETLE-SEDAN
What were the outcomes at WSID and Warwick Keith?
I saw you broke something at Warwick on the video,
but it looks like you fixed it?
CV flange or something?
Quote: | Originally
posted by westi
That's mad Alan.
Keith Haeusler
Threads: 40
posted on December 23rd, 2010 at 05:49 PM |
Hi Dave,
Best i could manage at Warwick before it broke was 8.09 at 86mph on 1.79 sixty foot. 6500rpm launch. Tried 7k, went bang. Was getting better with each
increased launch.
I haven`t been out to WSID since last time, either too wet or i get stuck at work. I hope to be there very soon.
Yes, broke the drive flange. It was a fabricated 091-930 flange. When i took it off i couldn`t believe it lasted that long considering how i made it.
Not very well designed.
Anyway, i have since fitted 2 new chinese chromoly ones and bolted them on. We shall see what happens.
Ordered my new progressive contoller from Santa last week. Getting closer now to giving it a go.
Nice flanged crank set up. I have now covered 600miles in mine and end float still measures the same as when assembled, so here`s hopeing.
Regards, Keith.
dragvw2180
Threads: 33
posted on December 24th, 2010 at 01:25 PM |
Hey Keith,
I was looking at your lines going into your manifolds for the NOS, is it just the picture or does your system inject fuel and NOS separetely?
I ran pro fogger nozzles years ago, they mixed it inside the nozzles is why I asked.
Your buildup has been impressive and you have a very nice car, something to be very proud of. Mike
richie webb
Threads: 1
posted on December 25th, 2010 at 02:43 AM |
Hi Keith,
just read this from the begining,very cool,glad you kept at it,these projects seem to take forever:-)
I thought you might be interested in my nitrous engine I built a few years ago now as a comparision,it was in my cabrio[over 1100kg with me in it]
which I drove everywhere back then so it had to be streetable,heres the engine combo
It was 2332 with mag case,8mm german head studs,scat 8 dowelled crank,VW flywheel 8 dowelled and lightened,no wedgemate,just a berg gland nut,scat
5/16 bol h beam rods,wisecos in mahle cylinders,FK47 on 108 lobe centers with CB comp eliminators heads[46/38 valves with port n polish]scat 1.4
rockers,10.2/1 compression,berg 1 3/4 header,st 1 kennedy clutch with a 4 puck disc.
Type 1 irs trans with 3.88r&p, 3.78,2.06,1.56,1.12 gearstack with a quaife lsd,944 cvs and "russian made shafts"
I had a WON nitrous system with only one pair of solenoids[mine were mounted up higher for access to the jets],WONnitrous controller and DTA efi.
The engine dynoed at 229 flywheel hp and I ran up to 120/130hp of nitrous on top.
Driving it to the track[about 80miles] fitting phoenix slicks and putting some higher octane fuel in,also stinger instead of muffler it went best10.88@126[mph could be slightly out]then putting the treads/muffler back on and driving it home,just for reference it went 13.27 best with treads and
no gas.
When you get that car sorted it is going to be alot of fun and surprise alot of people
Enjoy it
cheers richie,uk
colin
Threads: 82
posted on December 26th, 2010 at 03:48 PM |
Quote: | Originally
posted by richie webb
Hi Keith,
no gas.
Enjoy it
cheers richie,uk
What surprised me Richie was he actually both finished the car and drove it in pretty quick time LOL.
But seriously, Keith builds my little 1916 and does an awesome job.
I wouldn,t want anyone else doing my engine, he,s damn good.
What are you up to anyway Larry? is it latte time yet? LOL
Cheeers Col
Keith Haeusler
Threads: 40
posted on December 28th, 2010 at 04:38 AM |
Hi Mike,
Yes, the fuel and nitrous is injected into the manifold individually. And thanks for the comments on the car, i appreciate it.
Ritchie,
The car took way longer to finish than i had hoped, but got there in the end. My engine combo is very similar to the one you posted, albeit alittle
tamer.
If i get anywhere near your times i will be stoked. I will be sorting the nitrous this year so i`ll see where it takes me.
Thanks also for the comments on the car, and to you and Mike for taking the time to read the post.
Regards, Keith
stoker
Mood: so nice @happy
posted on December 28th, 2010 at 07:29 AM |
keith, putting a post up at 4:38 am , whats the deal, you shouldnt have a prostate problem at your age
dangerous
Mood: 591
posted on December 28th, 2010 at 09:18 AM |
Quote: | Originally
posted by stoker
Probably already at work!
That is actually 5.38am in NSW no?
That's morning tea time isn't it?!
In QLD it is always morning tea time,
especially when the muffins are on the go!
Quote: | Originally
posted by westi
That's mad Alan.
Keith Haeusler
Threads: 40
posted on December 28th, 2010 at 05:04 PM |
Dave S,
No, i haven`t any problems - so far, you twisted individual.
As Dave B pointed out it was 5.30 and i was at work. Got to love the waste industry.
And i could have gone some muffins early this morning, only thing open at 5 was a chinese bakery and the 2 curry pies i ate may be upsetting the
prostate.
Cheers, Keith
Dak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
Mood: faster ,faster ,Done
posted on March 1st, 2013 at 06:53 PM |
Keith , any news , have be on dyno yet or back to the track ?
Good to look at some of the old threads .
http://www.youtube.com/watch?v=vp4lX9r67_Y
Keith Haeusler
Threads: 40
posted on March 4th, 2013 at 01:25 PM |
Hi Pete,
Car still here. I haven`t had it to track since Feb last year, work etc seems to get in the way.
But, I have made a few changes to the engine. Dave B ran some intake and exhaust numbers for me to further `optimize`these ares. Anyway I went to a
shorter manifold to lower the overall intake length and swapped out exhaust ( Thanks Rod P ) to something very close to the number.
It`s a tight fit against the shroud but gave me alot more room outside to locate the nitrous/fuel solenoids. I can even get the plugs out without
manifold removal. A static test has been run with the nitrous to set pressures etc, just waiting for dyno.
Here is how it stands now. Excuse the layer of dust on engine.
Cheers.
Error |
Error |
Error |
westi
what the
Threads: 28
Mood: not blue, pink
posted on March 4th, 2013 at 05:02 PM |
time to drag her back out mate.
did you get a better seat.or some neck straps yet.last time i watched you, it looked like you head was about to come off when you take off.
down sharon.
drgouk
Threads: 21
posted on September 14th, 2013 at 06:05 AM |
Hi Keith,
What gearbox mounts are you using with the bus box? How is the tin fit? I take it the box is not centred?
Thanks David
Keith Haeusler
Threads: 40
posted on September 14th, 2013 at 07:03 AM |
Hi David,
I used a Berg solid mount kit. From memory it centred the trans and offset the engine so i cut and shut it to centre the engine and offset the
trans.
I will take a shot of it for you this weekend. The tinware fit is like stock. I had to mod the shift rod to suit ( although my car was a semi auto so
rod was already modified to suit beetle box, so a standard rod may fit ).
Keith
colin
Threads: 82
posted on September 14th, 2013 at 07:48 AM |
Not long now Larry
Cheers Col
drgouk
Threads: 21
posted on September 15th, 2013 at 05:37 AM |
Thanks Keith, Some pics would be great.
Keith Haeusler
Threads: 40
posted on September 16th, 2013 at 02:08 PM |
Pics
Hi David,
Hope these help.
Cheers.
Error |
Error |
Error |
Keith Haeusler
Threads: 40
posted on September 16th, 2013 at 02:10 PM |
Pics
some more
Error |
Error |
Error |
Keith Haeusler
Threads: 40
posted on September 16th, 2013 at 02:11 PM |
Pics 3
Last one. If you need more let me know.
Error |
dangerous
Mood: 591
posted on October 12th, 2013 at 08:47 AM |
How did you go at Warwick Keith?
Quote: | Originally
posted by westi
That's mad Alan.
Pages: 1 2 3 4 5 |
