[ Total Views: 42493 | Total Replies: 108 | Thread Id: 63561 ] |
Pages: 1 2 3 4 |
vw54
posted on July 7th, 2007 at 08:12 AM |
Quote: |
I would run bigger injectors though.
Nick they work out at 550ccs per injector i thought it would be an over kill ??
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
posted on July 10th, 2007 at 07:14 PM |
Looking good Dave - thanks for sharing the pics!
vw54
posted on July 11th, 2007 at 01:53 PM |
I now have the fuel rails finished, thanks to Brad from Westside 9773-7244 for the welding, and thanks to Pirtek Mascot for the fittings
hopefully i will have the engine ready to fit in the next few weeks, then comes the fun part
Error |
vw54
posted on July 27th, 2007 at 08:11 AM |
been doing a little each arvo
Error |
vw54
posted on July 27th, 2007 at 08:13 AM |
low pressure fuel filter
Error |
vw54
posted on July 27th, 2007 at 08:14 AM |
made up some nice fitting clamps and got some stud rubber mounts for the fuel pump
Error |
vw54
posted on July 27th, 2007 at 08:16 AM |
fuel return into the filler neck of the tank
Error |
vw54
posted on July 27th, 2007 at 08:17 AM |
the return line and flexiable line fit in neatly behind the spare wheel
Error |
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on July 27th, 2007 at 09:33 AM |
Hey Dave, that is a nice idea for the return line. What size (inside diameter) pipe and hose are you using for the fuel system?
Also sorry if you have covered it already but is there going to be a swirl pot/surge tank anywhere? Finally can you give some info re. what type of
pump is that you are using (is it a low pressure pump for the return....or if it is a high pressure efi pump then why the low pressure filter?)
Sorry for all the questions!
Alan
vw54
posted on July 27th, 2007 at 11:14 AM |
Alan
The feed line from tank to pump is 1/2 or 13mm the main feed and return lines to n from engine are rubber 5/16 or 8mm
No i am not using a surge tank a few people have done it this way and providing your not cornering at 100klms per hour or racing it should be good
for street also must remember not to go below 1/4 tank
The pump is off a VL Commondore 3.0 Litre Fuel Injection so it will be able to feed a 2 Litre engine no probs its HP or the main or only fuel
pump
The filter is there to remove any junk from the tank and is a heavy duty plastic type that will handle the suction from the pump
I have another HP filter on the feed line prior to the fuel rails, which will be located under the rear firewall and is of metal construction
no probs with the questions
vintage
Threads: 43
posted on July 28th, 2007 at 02:26 PM |
Looking good
jenz58
Postal Menace
Threads: 230
Mood: Cruisy
posted on July 28th, 2007 at 08:21 PM |
Dave howdo you find the time hehe...got a good job hey.....what ride is it in?:thumb
Euro_67
Threads: 75
posted on July 28th, 2007 at 11:31 PM |
Dave, top job and looks very factory. How do you think the accelerator pedal feel will be. Even with the factoy EFI plenumb setup I couldnt quite get
the pedal feeling right, too much spring or not quite enough.
vw54
posted on August 6th, 2007 at 10:25 AM |
Wayne
yeah dont know how it will feel the origional spring on the Throttle body looks pretty stiff so may have to cut it a bit
vw54
posted on August 6th, 2007 at 10:29 AM |
Jen
yeah good job always allow a few hours in the day to do some small jobs for yourself LOL
I will be fitting to the Orange Smoothieeeee
http://forums.aussieveedubbers.com/viewtopic.php?tid=4762&page=1#pid248566
jenz58
Postal Menace
Threads: 230
Mood: Cruisy
posted on August 9th, 2007 at 11:12 PM |
...had to do a double take there:P
Took 4 minutes lol
So is the Orange Smoothie off the road for a bit while tweak a few things?
vw54
posted on August 10th, 2007 at 06:50 AM |
Yeah the smoothie is off the road i miss driving it got the other Orange car the 76
vw54
posted on August 14th, 2007 at 07:42 AM |
Fitted the ECU up last night
[ Edited on 13-8-2007 by vw54 ]
Error |
vw54
posted on August 14th, 2007 at 07:44 AM |
I have fitted it against the engine fire wall
Error |
vw54
made some spacers to stand the unit of the wall to allow heat escape
Error |
vw54
posted on August 14th, 2007 at 07:45 AM |
The nut inserts save heaps of time and allow easy instalation
Error |
vw54
posted on August 22nd, 2007 at 07:37 AM |
Finally got around to do some more work
Error |
vw54
posted on August 22nd, 2007 at 07:38 AM |
its cold in the garage
Error |
vw54
posted on August 22nd, 2007 at 07:39 AM |
made up the attach brackets
Error |
vw54
posted on August 22nd, 2007 at 07:40 AM |
should be installing the engine next week
Error |
vw54
making sure the fuel hoses dont foul or get caught up
Error |
StenGuns
Threads: 236
posted on August 22nd, 2007 at 08:08 AM |
Looking forward to seeing this Dave
vw54
posted on August 22nd, 2007 at 09:39 AM |
Me too I will drop round n take u for a run
lulu94
A.k.a.: Danielle
Threads: 50
Mood: What!! 2 more(hehe i draged ryan over to the dark side)
posted on September 2nd, 2007 at 01:42 AM |
looks good, the 3 litre VL injectors should keep uip with a 1916 well enough, not turbo is it??
gives me ideas for Danielles beetle - only the inlet could have a bit of a plenum in the middle and four individual runners all the way, similar to
the factory type.
hmmm I'm still logged on as Danielle.. oops.
1968 pearl white beetle:kiss
1600 engine
soon to be supercharged
1970 and 72 Squarebacks 70 soon to be rotor powered
vw54
posted on September 9th, 2007 at 06:50 PM |
No its not Turbo although it might be one day
Pages: 1 2 3 4 |
