[ Total Views: 307015 | Total Replies: 964 | Thread Id: 66140 ] |
Pages: 1 .. 18 19 20 21 22 .. 33 |
reub
VWRX is gone...
posted on July 25th, 2009 at 04:15 PM |
WOWSERS!
Looks sensational Ian. We're all hanging to see how it goes!
Reub
trickysimon
A.k.a.: Simon Azzopardi
Threads: 43
posted on July 25th, 2009 at 05:37 PM |
Thats awesome mate
ricola
Threads: 9
posted on July 25th, 2009 at 06:42 PM |
That engine looks incredible, love the carbon/polished contrast!
cnfabo
Threads: 140
posted on July 25th, 2009 at 07:28 PM |
i think ive gone bananas,,....
nothing short of WOW....
Flintstones
Threads: 69
posted on July 25th, 2009 at 08:24 PM |
Sensational
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
posted on July 27th, 2009 at 10:07 PM |
Looks nice! I don't know about the orange valve covers though.
reub
VWRX is gone...
posted on July 27th, 2009 at 10:35 PM |
Quote: | Originally
posted by Baja Wes
Just as well they weren't red or you would have said straight out how horrible they were...
Reub
2443TT
A.k.a.: Ian
Threads: 68
posted on July 27th, 2009 at 10:41 PM |
Quote: | Originally
posted by reub-revhead
Quote: | Originally
posted by Baja Wes
I agree... Orange is the colour out of the box. I'll be painting them flat black along with the tinware once its back from the sand blasters.
colonel mustard
Threads: 51
posted on July 27th, 2009 at 11:03 PM |
I like the orange... its out there... Looking good mate.
mactaylor
Mood: even my dog is german
posted on July 28th, 2009 at 06:11 AM |
looken great ian what brand is your dry sump pump?
EVERLAST CONCRETE TANKS
1800 552 123
2443TT
A.k.a.: Ian
Threads: 68
posted on July 28th, 2009 at 09:01 PM |
Quote: | Originally
posted by mactaylor
Its an RPM 4 stage. 1st stage is 1.250", and the scavenge stages are all 1.75" stages.
The engine is now back in the car today. Im working on the header again now and have re-mouted one of the turbo's so far. I'll have some pics up in
a few days when its finished.
Ian
Golde60
Threads: 73
posted on July 29th, 2009 at 01:14 AM |
crazy
awsome and inspirational
Boostn
Threads: 28
posted on July 30th, 2009 at 02:00 PM |
Looking good Ian,
what ecu are you going to use?
what is your predicted KW
VOLLKOMMEN ART
nick@vollkommenart.com
Speed and Style
2443TT
A.k.a.: Ian
Threads: 68
posted on July 30th, 2009 at 03:22 PM |
Quote: | Originally
posted by Boostn
Looking good Ian,
I'll be using a Wolf version 5 ecu and MSD DIS2 or 4 ignition with 2 or 4 coils (havent quite decided just yet).
Power level predictions? Well the pair of trust T517z's are rated flow 700hp to the flywheel on a RB26, and examples of them tuned in GTR's they
make around 400awkw maxed out. I hope to see 450-500rwhp on a max power tune, but time will tell.
Still working on the header today. The engine sure looks good bolted into the back of the car again now.
Flintstones
Threads: 69
posted on July 30th, 2009 at 09:14 PM |
Pics please
dangerous
Mood: 591
posted on July 31st, 2009 at 06:09 AM |
"The engine sure looks good bolted into the back of the car again now."
YEAH!!!!
You cant say that and have no pictures!!!
Quote: | Originally
posted by westi
That's mad Alan.
2443TT
A.k.a.: Ian
Threads: 68
posted on July 31st, 2009 at 06:08 PM |
Well here's the header 1/2 finished with the altered turbo positioning. This time I made a bracket to hold the turbo flange where I wanted it first,
then ran the plumbing to it. Such a smarter way of keeping things leval than trying to hold something in position when welding it all together using
curved pipes. Ive used mild steel for the header and Turbo X black ceramic coat it and the turbo's turbine housings rather than mess around with
stainless.
I'll be able to easily put a thin stainless sheet metal heat shied around the turbo housings too. There is plenty of room, not that the pics show
that. Enough to easily run 3" dumps from the turbo's with plenty of tyre clearance, but it will most likely end up being 2.5" as thats the size all
the valving is for the sequential setup im using.
Manifolds are just temporarily fitted. Ive got to work out how I want to do the intake manifolds next. Im contemplating using a plenum chamber above
each manifold and a single 3" pipe from each side to a center mounted throttle body, or running 2 x 2.5" pipes to a merge and then 2.5" from each
merge to a center mounted throttle. The 2.5" setup would maintain better air flow at low RPM which should mean better torque in theory but I dont
think that will be a problem with this engine. The 3" idea is a lot easier to manufacture.
I'll be finishing off the rear pipe work on the weekend, and then I want to pressure test it to check I havent left any pinholes in my welding.
Ian
Flintstones
Threads: 69
posted on July 31st, 2009 at 11:17 PM |
With the aluminum trailing arms, you've got so much more room for the turbo's and exhaust (when you do make it)
It's definately looking good!!
2443TT
A.k.a.: Ian
Threads: 68
posted on August 10th, 2009 at 07:06 PM |
Hi guys,
Well I got nothing at all done over the weekend, instead decided to have the day off to blow my nose and drink buckets of mucas but all good now.
Last week I had some flanges laser cut so when I knocked off work today after lunch I was able to get started on the intake manifolds. These are the
comp eliminator manifolds I used on the last engine. There is a balance pipe welded through both ports (for when it had quad throttles on it), which
I will still use as it keeps the vacuum hoses nicely hidden. This is how I mounted the fuel rails too, It proved very effective and is a lot neater
than how CB would have you do it.
Here is one side of the intake manifold before its tig welded. Ive given the flanges and pipe the once over with the polisher too of course. Welds to
the flanges will be internal and then the flanges will be milled dead flat again.
And here's what it looks like from the top. Its so time consuming making nice merges, especially when they have to look good. Where's Westi when you
need him...
Ian
Stanley
Threads: 270
posted on August 10th, 2009 at 07:18 PM |
lookin' the goods Ian.
Keep the pics coming
Boostn
Threads: 28
posted on August 10th, 2009 at 07:47 PM |
Nice, Rochester 1000cc shower head injectors. They are great to tune down low.
The injector mount is much nicer than the std CB way !!
Can't wait to see the dyno sheets for this.
VOLLKOMMEN ART
Speed and Style
2443TT
A.k.a.: Ian
Threads: 68
posted on August 23rd, 2009 at 07:14 PM |
They are rochesters but these are 650cc's from memory. Enough to get started and run in with but i'll be having to upgrade when I go after a max
power figure. Ive got a base map from my 2443 that ran these injectors so it will mean no startup issues in theory...
So its been a little while since the last update. Ive been outsourcing having the tig welding done on the intake manifolds. The guys doing the work
are very good but also busy so my project has been put to the bottom of their list as far as priority's go, which is a bit of a pain in the ass.
The first intake manifold end I had welded introduces me to how much stainless steel pulls when its welded. The flanges on the first intake end were
about 5mm closer together once the merge was welded on the above pictures, so I had to do a lot of swearing to get it back onto the 4 mounting studs,
bolt it on and then have some wedges welded in between the flanges to stop the whole lot twisting up and distorting.
I got it right on the 2nd intake and had these wedges welded to the flanges first before they were unbolted from the manifolds and the pipes then
internally welded to the flanges.
With the ends done I set about doing the plumbing in between. This is more or less what it will look like, with the throttle body in the center
through the firewall. The welding is being done on this tomorrow (hopefully). Im having this done in stages so I can re-check the pipe alignment and
adjust for the material distortion that comes with the welding.
The entire intake will be flanged/bolt together, except for the left side behind the pump where there will be a clamped expansion joint.
As for this weeks activities ive been focusing on the exhaust system starting with dump pipes and the start of the exhaust. Ive used 2 x 2.5" pipes
on the turbo flanges, cut them and joined them the full length so they fit nicely on the flange. Ive welded them internally and blended them to the
pipe on the inside. The other end of the dump pipes then expands to 3" where it then runs parallel to the rocker cover as you can see.
3" might be seen as being a little excessive, but that is the standard size that would be being used if these turbo's were on an RB26DETT in a GTR,
which is what they are designed for. The only diference is that I wont be merging them back together, there will be a 3" muffler on each pipe and an
exhaust pipe behind each tyre. Im glad the wheels are so wide on the rear end, it makes for plenty of room for the mufflers.
Thats all for now.
Ian
Smiley
A.k.a.: Daniel Stephens
Threads: 110
Mood: Synchro'd
posted on August 23rd, 2009 at 08:38 PM |
Nice work. It's looking sweet Ian.
Smiley
DavoBuggy 1641
Threads: 12
Theme: UltimaBB Pro Orange
posted on August 24th, 2009 at 04:27 PM |
This thing is insane! nice work dude!
Cheers Dave!
VWFREAK
A.k.a.: Peter / Bones
VWFREAK
Threads: 264
Mood: FREAKY
posted on August 24th, 2009 at 07:55 PM |
This build takes VW Porn to a new level, bloody awesome Ian.
reub
VWRX is gone...
posted on August 24th, 2009 at 08:01 PM |
SCHAWING
Reub
2443TT
A.k.a.: Ian
Threads: 68
posted on August 25th, 2009 at 05:15 PM |
Howdee all,
Another update... Manifold nearing completion. The 2nd last lot of tig welding is now done, and ive got just the two last pieces and a throttle
flange to have welded onto it now. With any luck it will be ready tomorrow afternoon.
Ian
2443TT
A.k.a.: Ian
Threads: 68
posted on August 26th, 2009 at 08:29 PM |
Welding finished at last.
Finishing the exhaust this weekend and then its time to break open the wallet and order some intercoolers and hoses for oil and fuel. Im beginning to
see light at the end of the tunnel now.
colonel mustard
Threads: 51
posted on August 26th, 2009 at 08:36 PM |
Its looking great. Out of interest, whats the deal with the red bandage :S looks great. Sorry, If iv missed it before, but one injector per
Cylinder.... what size for this setup! amazing progress there looking
great
2443TT
A.k.a.: Ian
Threads: 68
posted on August 26th, 2009 at 08:47 PM |
The "red bandage" is a piece of 2.5" silicon hose. I'll is the expansion joint between both sides of the engine. Injectors will have to be around
1000cc to make the big power figure im after, but the 650cc injectors are still for well over 300hp which will be the street tune of the car.
