[ Total Views: 9009 | Total Replies: 70 | Thread Id: 77738 ] |
Pages: 1 2 3 |
bajachris88
A.k.a.: Chris Leete
Threads: 534
posted on August 31st, 2009 at 10:34 AM |
hows this going?
(ô_!_/ô) (ô_!_/ô)
69' baja: kombi box, thing spindles, irs, disc front, type 3 rear drums, 2 inch lift kit, 31x10 rears.
isky
Threads: 40
Mood: awesome....
posted on September 1st, 2009 at 12:05 PM |
mate ive been flat out with work for the past two weeks which is why i havent been on lately or put up any updates. We're going to put the old
master cylinder back in hopefully this week after having a good look and thinking its probably got life left in it...
Once ive done that and spent a little time on the rear wheels im going to take it for a spin!
grumble
Mood: happy all the time
posted on September 1st, 2009 at 09:52 PM |
Did you check the inside of the master cylinder for pitting in the bore,this is common and will cut the new cups out very quickly.We use either new or
resleeved cylinders. Cheers Les
isky
Threads: 40
Mood: awesome....
posted on September 1st, 2009 at 10:05 PM |
We found a place that would resleeve a cylinder for 140, but it was going to cost 207 for a newy so we decided to use the original seeing it didn't
seem to have any visible rust. If it doesn't work out when installed it won't be a big deal replacing it. I think I'll just get a new one from
'micks' I guess. Can you get a better idea of wear by taking the clip off? I just looked down the break line holes and it seemed pretty clean.
bajachris88
A.k.a.: Chris Leete
Threads: 534
posted on September 2nd, 2009 at 12:01 AM |
By takin the clip off you can look straight down inside, and even run the finger a bit.
once degreased and clean, it should be shiny. you will see if its pitted or not.
(ô_!_/ô) (ô_!_/ô)
isky
Threads: 40
Mood: awesome....
posted on October 18th, 2009 at 08:22 PM |
Rito! so ive had a month or so off for work commitments and am now raring to get back into it. Today the master cylinder went back in. Next week im
going to swap the rear drums and shoes with my red Ghia's newer ones. I also got a the rear wheel kits from Micks a while back which will come in
handy. Then ill bleed the lines and get the brakes up to scratch.
The U.S exchange rates are looking pretty sweet at the moment so ill be doing a bit more online shopping as well. Cip/ebay watch out!
So yeah question for everyone?? My drivers side door is sliding on and rubbing against the bottom sill. There seems to be about 1cm play in the
hinge if i lift the door up and down. Is this normal? and can i fix the door rubbing on the sill by adjusting the hinges? Seems pretty straight
forward but thought id ask
Cheers!
vwsteve
A.k.a.: steve
karmann crazy
Threads: 200
Mood: Busy!
posted on October 19th, 2009 at 07:46 AM |
the alloy hinges are prone for wearing out, you can drill them out a little and put larger pins and sleeves in them or just order another set
1 1963 356b porsche coupe
2 1960 karmann ghia cab
1 1965 karmann ghia cab
1 1966 karmann cab
1 1961 split ute
1 1967 split p/van
1 1952 standard bug
1 1963 ragtop
1 1960 ragtop
2 1954 ovals
1 1956 oval baja project
1 1957 oval flying flea
isky
Threads: 40
Mood: awesome....
posted on October 19th, 2009 at 09:11 PM |
thanks Rexy...so are they alloy?! I didn't realize alloy was around 50 years ago. That last statement probably shows how dumb i really are lol.
Ill try adjusting first, if that doesn't work ill try the set on my other red KG, if that doesnt work ill buy newies...
thanks
sputnick60
Threads: 2
posted on October 19th, 2009 at 10:41 PM |
I had my hinges redone at Vintage Vee dub. All four cost $480
you can send them away to the US and get House of Ghia to do the refit for about $70USD each Plus 2 way shipping.
Nicholas
isky
Threads: 40
Mood: awesome....
posted on October 19th, 2009 at 11:12 PM |
bloomen heck! had no idea a small hinge was so exy...cip1 sell them for 45 (us) but it cost another 45 to get it shipped. Im pretty confident ill
get by with adjusting, or using my others from my parts car...they seem solid enough I actually also need the door alignment wedges as well.
sputnick60
Threads: 2
posted on October 21st, 2009 at 11:28 AM |
On the ghia, if the hinges are at all loose they will soon fail. It will be better to cough up and get refurbished ones... the repro ones break. When
you get the alignment wedges .... try find the OEM ones..... the WCM ones fall apart after a year .
I was surprised at the expense of refurbishing the hinges here in OZ... But I had commissioned the work before asking for a quote.....I'll be more
careful next time.
BTW what sort of glider is that? I've been using a C2 for a while now & lovin' it. (I'm HGFA advanced rated)
isky
Threads: 40
Mood: awesome....
posted on October 21st, 2009 at 10:33 PM |
thanks for the advice sputnik...
I fly a Sting, but also have a S4 moyes. My Sting is my fave though, i love Airborne gliders. I want an C4! Ive been flying since about 2004 but
don't go as often as id like. Where do you fly?
sputnick60
Threads: 2
posted on October 29th, 2009 at 10:21 AM |
Quote: | Originally
posted by isky
Just a heads up on a potential issue you might have here....
I bought a bunch of these rear quarter rust replacement panels only to discover they are for 1967 and later...which is after the shape change and
shorter bumper. In brief... they don't fit for 1966 and earlier cars.
Nicholas
isky
Threads: 40
Mood: awesome....
posted on October 29th, 2009 at 11:02 AM |
Sputnik hi, Thanks mate that bit of info could have saved me some grief seeing im almost ready to purchase. I know a bloke around here who has been
doing a car the same age as mine so shall ask where he got his from...I'll also contact cip1 direct to see what the go is...
Thanks again buddy!
bajachris88
A.k.a.: Chris Leete
Threads: 534
posted on October 29th, 2009 at 12:08 PM |
Any progress on this one Anthony ?
Hows the holidays been mate? I checked out your website you
mentioned a week or two back, your work is awesome! (some of the gals aren't bad either :P) lol
With the way your good with your hands and creativity, i'm VERY keen to see how this one turns out. should be mad as!
I got an email from CIP1 stating they have a 15% off halloween sale or sumfin with like 4 days left... if ya going to buy from them, don't leave it
too late!
(ô_!_/ô) (ô_!_/ô)
isky
Threads: 40
Mood: awesome....
posted on October 29th, 2009 at 02:46 PM |
Chris Hi, Thanks mate. Lo,l being good at making corsets and being able to do a job like this is pretty extreme mate. But my corsets do have steel
in them... When are you coming over? Ill try and accidentally organize a
photo shoot with some of my girls for ya
I saw the 15% off thing at cip1. Im going to get a hand full of little nick nacks from them in the next couple of days like a door hing, door
alignment wedges, license plate seals etc. I was going to get a front lower fender section but was just told by Nicolas (sputnick60) to be careful
because their body metal is made for later model Ghias than mine...but looking again at their description it says 56-74 years so i dont know. I
better investigate it first. I might just get one and see.
Call me when your ready...but dont expect too much mate
sputnick60
Threads: 2
posted on October 30th, 2009 at 08:10 AM |
Quote: | Originally
posted by isky I saw the 15% off thing at cip1.
I should have been clearer... the part I had trouble with is #3 in the picture.
You should be OK with #1. If you have access to a good old school panel guy, making up a good replacement out of sheet metal for #2 & #3 should be
easy. I had Chris Rolfe from Innovative Body Works do mine and it came out rather well.
Check out his face book page for lots of photos of my ghia
[img]http://www.facebook.com/photo.php?pid=2594178&id=143130584919[/img]
This one is of the lower rear wing in question.
Nicholas
bajachris88
A.k.a.: Chris Leete
Threads: 534
posted on October 30th, 2009 at 10:10 AM |
haha, i will be ready soon! exams finish this coming thurs, then work will wnat me... but i will get a day off sometime, and will give ya notice.
(ô_!_/ô) (ô_!_/ô)
isky
Threads: 40
Mood: awesome....
posted on October 30th, 2009 at 01:24 PM |
Wow Nicolas! That's some pretty major surgery happening there! Cant wait to see the final result or even more progress pics.... Hmmm i just looked
at cip's site again. There seems to be two different shapes available for item 3. years 56-71 and 72-74....Perhaps you bought the 72-74 metal?
Anyways thanks for the hands up There's a bloke out my way who ill
contact shortly about doing some work for me. He's doing his own Ghia at the moment and it looks sweeeet! I just really want to take care of the
back wheel arches....ill do the pans myself down the track a bit
@Chris....lol, no worries mate!
sputnick60
Threads: 2
posted on October 30th, 2009 at 10:24 PM |
I missed that earlier one about the glider... I've been flying since 1983. Maxi, Mega2, Probe, Probe2, Foil, Kiss, Blitz, Blade, Shark, Climax,
Current glider = C2. Favorite all time glider was the Kiss and the C2. I mainly fly Stanwell but I used to fly Byron alot and spent time in Europe
too. Beechmont is a cool site. So to Mt Tambourine.
About the panel...... Yes, there is a difference on the CIP offering but it is because the "Fat Chick" bumpers required a square indent to
accommodate their shape that is different to the rounder early style bumpers. Are these details mind numbing but bear in mind these part suppliers don't give the correct dates for parts some times. I would say
the rear guard section has three versions. '54 to '66 then '67 to 70 then 71 to 74
If you want more on my car... look on the samba....http://www.thesamba.com/vw/forum/viewtopic.php?t=270985
Nicholas
isky
Threads: 40
Mood: awesome....
posted on November 17th, 2009 at 08:12 PM |
Hey Groovers! Little help?
Well i FINALLY started on my back brakes today...the plan was to replace my drums/shoes/slave cylinders etc with my Red karmanns because the ones off
my red cars looked brand new. When i actually got my drums off my good brown car i was dumbfounded to see that they also looked in good nick. In fact
they were massive! The drum off the brown car actually fitted well over the standard red cars drum. My mate said "id keep those for sure!, they're
huge, you'll have great braking power!" He also said they may even be off a combi...
Now i know the previous owners of my car rallied it or were getting it ready to rally so that may explain why they are so different. So my question
is....What are they from?
Ok these were the numbers and script around the area in question 58 W&E.S 311.501.311A BI TVS 1618 (i think it was 1618)
and on the drum itself there was W&E 2 VW 55 311 501 615E
oh and they also had two small springs holding the shoes on instead of just one if that helps...
Some pics...
isky
Threads: 40
Mood: awesome....
posted on November 17th, 2009 at 09:22 PM |
Geez Nick you've done some flying! I haven't even heard of some of those gliders...Yep Beechmont and Tambo are pretty good. I live in Brizzy so i
get pretty sick of driving all that way...especially when i don't get off the hill. I flew Byron a few years back and had the best day ever!
Totally out flew every one on the day I also did 40 km's at
Tewantin / (Rainbow beach way) on my last flight. It was epic and i almost got hit by a 4WD when landing on the beach...
This is a blog i once had but haven't added to it for years if your interested...
http://www.anthonysingh.blogspot.com/
isky
Threads: 40
Mood: awesome....
posted on November 18th, 2009 at 03:31 PM |
hey guys don't worry about trying to identify my drums....apparently they're standard. I took the shoes into get re-bonded today and the old fella
behind the counter took one look at them and said 'from a Karman Ghia hey?'
I just couldn't understand how a 61 KG drums and guts could be so much bigger than a 1960 model...
isky
Threads: 40
Mood: awesome....
posted on June 12th, 2011 at 04:48 PM |
Finally things have started to happen. Over the past 6 months I've spent a pretty penny buying all the rust panels, floor pans and little bits and
pieces needed to complete my little beast. Last weekend my mate and I loaded it on the back of a car trailer and drove it up Toowoomba way so my new
best friend could start stitching them on It'll turn 50 this year and
has sat idle in a shed for easily 20 years... this should be a nice birthday present.
I feel so much better now that things have started
The following are pics of my mate Drew driving it on the trailer as well as some of the parts I've been collecting to complete the project.
isky
Threads: 40
Mood: awesome....
posted on June 21st, 2011 at 10:57 PM |
Starting to take shape! Found some major inner sill rust behind the front left hand door so will have to deal with that before proceeding. My body
man mate is a legend and keeping me informed and up to date the whole way. Both my doors are now opening and closing perfectly! Even better than his
car lol. Great to see some of the patch panels roughly in place also. Apart from discovering the rust my mate pulled out a metal plate in the rear
quarter lower rear section... I can't believe how dodgy some people are. As my body buddy says... "'Everyone is a panelbeater!' If you can't
fix it then don't!" Hopefully soon we'll cut the front guards off my parts car as well as a few other bits and pieces
ThoughtI'd up load some pics
bajachris88
A.k.a.: Chris Leete
Threads: 534
posted on June 22nd, 2011 at 08:30 AM |
you been waiting for this day for ages man
noice work! keep us updated every step of the way
(ô_!_/ô) (ô_!_/ô)
isky
Threads: 40
Mood: awesome....
posted on June 22nd, 2011 at 11:18 AM |
Thanks Chris! Yeah i know right, I'm so relieved. One thing I've found though is that it's one thing to read and watch other peoples blogs and
seeing all the undiscovered rust... but when it comes to your own pride and joy you get this sick feeling in your guts. Will do, I'm sure there'll
be loads more photos to come
isky
Threads: 40
Mood: awesome....
posted on July 12th, 2011 at 07:06 PM |
Massive day on Saturday. Unbolted body, removed doors, cut off roof and all 4 guards from my parts kg for stitching onto my better brown one.
It was actually pretty sad to see the red car get cut up like this. But in a way it's going to live on.
Parts car prepped and stripped for cutting.
/6721/img1460k.jpg[/IMG]
first guard off
front guard gold
all 4 guards off to get stitched on to it's new body
frog
Threads: 49
Mood: is what the cow did yesterday.
posted on July 12th, 2011 at 08:21 PM |
I pretty sure I looked at the brown ghia in the mid 90's near Minden and he was after 5k which was steep at the time for a modded ghia.
And here it is all this time later and good on you for keeping it alive.
"-Hannovermetalmadness-"(Infectious desease with no known cure).
isky
Threads: 40
Mood: awesome....
posted on July 12th, 2011 at 08:35 PM |
Serious?! I'd love to find out it's history. All I've heard was that it was used as a rally car (what ever that means). I bought it from a guy
who was advertising another Ghia. In the add he said "if you buy my Ghia for 20,000 ill throw another Ghia in for free". I just called him and
asked him about the give away. I certainly didn't pay 5 grand for it.
Thanks mate... hopefully there will be another 'back from the dead' Karmann on the roads soon
Pages: 1 2 3 |
