[ Total Views: 65931 | Total Replies: 633 | Thread Id: 78092 ] |
Pages: 1 2 3 4 5 6 .. 22 |
STIDUB
Over it.
Threads: 57
posted on November 24th, 2009 at 09:02 PM |
re-invention of the wheel?
in other news, everyone knows micks engine yes?
im picking one up tomorrow, shame its in the opposite direction to the gearbox, lots of driving to be done tomorrow
Hello baked beans on toast for the rest of this pay
Volkswagen Drivers Club of Queensland - member
dangerous
Mood: 591
posted on November 24th, 2009 at 10:03 PM |
Had to clearance inside the case to fit the beetle forks and shift rails:
All the shift rails and slots neeed to be extended to suit the wider 091 gears:
Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
posted on November 24th, 2009 at 10:10 PM |
Clearanced the fork for 1st and second(steel not brass):
Made an aluminium clutch bush to replace the plastic one:
Here is the Albins mainshaft with 2.82 first gear and 1.857 second.
Usingmetal caged needle bearings for better support.
Quote: | Originally
posted by westi
That's mad Alan.
STIDUB
Over it.
Threads: 57
posted on November 24th, 2009 at 10:11 PM |
ahhh, clearancing awesome timing though dave, greatly appreciated thats
for sure,
Oh, & that slave mount is stock standard with the bellhousing kit (you get what you pay for it seems )
sent the remaining $$ just now dave, hope the arvo is good, gotta pick up the engine in the morning, 8hrs worth of driving to be done tomorrow
dangerous
Mood: 591
posted on November 24th, 2009 at 10:14 PM |
The spline on the end of the shaft requires the coupling to be counterbored:
Albins steel hub(with oil holes) to replace the weak cast original:
Needle bearing for 4th:
Third gear is 1.143, Fourth is 0.77:
Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
posted on November 24th, 2009 at 10:23 PM |
Pinion shaft got a nice new taper bearing,
and metal caged needles for first gear:
Cromoly pinion bearing nut from Albins:
1st 2nd hub got oil holes:
Assembled gear stacks:
Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
posted on November 24th, 2009 at 10:26 PM |
Spiffy intermediate housing with all the beetle stuff fitted:
Check out this input shaft:
Front end:
Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
posted on November 24th, 2009 at 10:27 PM |
Quote: | Originally
posted by westi
That's mad Alan.
STIDUB
Over it.
Threads: 57
posted on November 24th, 2009 at 10:28 PM |
these posts are like dial up internet waiting for porn vids to load many years ago... dave, your a tease!
like a kid in a candy store right now not bad for a birthday pressie
eh? (unfortunately it was a happy birthday to myself) the girl helped though
i need sleep, will give you a call tomorrow after ive grabbed the engine bits & peices
colonel mustard
Threads: 51
posted on November 25th, 2009 at 03:31 PM |
Looks freakin amazing! Butler.... Your a pro and a champ
trickysimon
A.k.a.: Simon Azzopardi
Threads: 43
posted on November 25th, 2009 at 03:39 PM |
Welcome to the Butler Box Boys
STIDUB
Over it.
Threads: 57
posted on November 25th, 2009 at 10:21 PM |
had to buy the fresh gearbox a friend
that came with some followers
Using all standard/aftermarket subaru clutch, flywheel, pressure plate, starter, seals, etc etc etc
& the main event.... (& i still didnt get to have one of those famous muffins!)
GEARBOX!!!!!!!!!!!!!
driving all over SEQ in a day was worthwhile i think
get to play with it all tomorrow
looking forward to getting the mounts sorted, itching for fire up day now
still need the wiring, plumbing & fuel system sorted out yet but concentrating on bolting it all together for now
put it this way though, next pay is already spent
matberry
posted on November 25th, 2009 at 10:29 PM |
Awesome
STIDUB
Over it.
Threads: 57
posted on November 25th, 2009 at 10:56 PM |
why thankya mat
Sides
A.k.a.: Dave Sidery
posted on November 26th, 2009 at 07:14 AM |
You bought a pallet load of plastic wrap with mystery mechanical stuff inside, which was followed by some sort of cooler looking thingy and a laptop
box ???
btw - meant to ask earlier about the shackle on the box... is that somehow involved in the mounting setup, or just to try and make it a bit easier to
handle and shift around ???
My toys
STIDUB
Over it.
Threads: 57
posted on November 26th, 2009 at 01:08 PM |
sides, thats exactly it! i love empty boxes & used plastic wrap, just going to toss the other bits out
also, boy that sway bar was a toughy, so hard to work out how it goes on :P
for the record, the loom etc is in that box, now i know why later looms cost more to modify, they are so much bigger than earlier ones
shackle was just to move around, now being used as security while working on both it & the engine on the pallet, pics later tonight, dont have my
laptop here (stealing the sisters hehe)
that reminds me, gotta call rod about the rest of the driveline soonish
STIDUB
Over it.
Threads: 57
posted on November 26th, 2009 at 07:05 PM |
another day passes, a lil more progress....
JDM 02 STI engine
mounted to the kombi box with all its bits & peices
using a standard 240mm subaru flywheel/clutch etc
same story on the starter motor
think the turbo is going to be moved a few inches away from this at the least
& im going to need me a stainless donut to fix that
turbo part numbers etc somewhere down there
Really wish this could be started right now
axles will end up fairly straight & almost stock lenght
AND! proof that VW & subaru were made for this!
colonel mustard
Threads: 51
posted on November 26th, 2009 at 07:39 PM |
Looks like a fair bit of firewall cutting will happen :s looking superb man!!!
trickysimon
Threads: 43
posted on November 26th, 2009 at 08:08 PM |
Thats a funny looking beetle engine
STIDUB
Over it.
Threads: 57
posted on November 26th, 2009 at 08:39 PM |
amazing what a lil red paint & some water can do eh?
STIDUB
Over it.
Threads: 57
posted on November 27th, 2009 at 08:40 AM |
to have or not to have aircon.... that is the question....
the woman reckons it would be horrible without, im having a moment of weakness, should i leave the option to have it there or not....?
actually i think i shall since a/c defrosts windows & such alot quicker than without, failing that, can always leave it out later on.
excuse the thinking out loud
STIDUB
Over it.
Threads: 57
posted on November 27th, 2009 at 08:50 AM |
im predicting ill be another happy customer for am auto, they got back to me first think the morning after email, mite have the loom sorted very
shortly!
Sides
A.k.a.: Dave Sidery
posted on November 27th, 2009 at 09:33 AM |
Yes - keep the aircon !!!
Admittedly Jezebel is mainly a race car and has very few creature comforts, so no stereo, carpet, headlining, sound deadening etc.
After driving her to and from work for 3 days this week to give the new gearbox some k's, the only thing I miss from driving my normal modern V8 ute
is the aircon !!!
My toys
STIDUB
Over it.
Threads: 57
posted on November 27th, 2009 at 11:03 AM |
yeah, definately keeping the a/c now, just means i need to find MORE space somewhere to fit all the associated crap, goodbye what was left of the boot
space up front & any room at all around the box, having a demister that works will be nice, the alternative is a heater element in the glass from
a mob in the uk, stereo is a necessity for my generation sides
maccas carparks here i come, though im getting too old for that crowd
Oh, the cage is inevitable it seems, will have to ask the guy nicely if he would do mine, if i come to mt cotton on sunday ill try have a better look
at yours, or at the next meet drive it there! - provided its not ripped apart for the new toys to go in, jezebel is getting alot of love for christmas
this year.
matberry
posted on November 27th, 2009 at 12:41 PM |
Mate the air is a definate surely with that water pumper in the back. I've been involved with fitting up a climate control system fully aftermarket
into a wild baja and surprisingly easy once all the stuff has room, so need to plan early.
STIDUB
Over it.
Threads: 57
posted on November 27th, 2009 at 02:43 PM |
true true, i think fuel & coolant bits are more important currently though, but yes, will have to nut out how to fit it in, i guess the a/c evens
out the weight front to rear...
hell, why not keep the power steering too
Joel
posted on November 28th, 2009 at 07:34 PM |
Quote: | Originally
posted by STIDUB
BOO-URNs
dangerous
Mood: 591
posted on November 28th, 2009 at 07:49 PM |
Quote: | Originally
posted by Joel
BOO-URNs
love that episode!
Quote: | Originally
posted by westi
That's mad Alan.
Joel
posted on November 28th, 2009 at 07:52 PM |
hehe yea, i'll never grow out of the simpsons
http://www.youtube.com/watch?v=WRT70ceAMQ4
ian.mezz
Threads: 280
posted on November 28th, 2009 at 08:07 PM |
ahhh wack a battery pack on the starter and turn the sucker over to see if its all good.
