[ Total Views: 11815 | Total Replies: 35 | Thread Id: 78303 ] |
Pages: 1 2 |
bajachris88
A.k.a.: Chris Leete
Threads: 534
posted on September 22nd, 2009 at 01:24 AM |
Out of curiosity, i know it doesn't affect me and my setup, but for swing axle, (i would imagine its absolutely same principle as this) but... how do
you go about the wheel bearings being higher than the gearbox itself?
seeing that they are lubed with the transmission oil rather than the separate gease and seal setup like on an IRS?
Is there a sealed bearing conversion or sumfin? I have always wondered thats all... but anywho!
btw though Joel, another good write up mate!
(ô_!_/ô) (ô_!_/ô)
69' baja: kombi box, thing spindles, irs, disc front, type 3 rear drums, 2 inch lift kit, 31x10 rears.
Joel
posted on September 22nd, 2009 at 08:30 PM |
most of these people running slammed swingers with 300degrees neg camber will tell you that they oil runs up the tubes every time they go round a
corner
im sceptical but i have heard people talking on thesamba about using sealed bearings
colonel mustard
Threads: 51
posted on November 14th, 2009 at 10:38 PM |
ah. soon!
57 oval
Oval type 4 Fuel Injected
Threads: 48
Mood: Oval
posted on November 15th, 2009 at 11:11 AM |
Excellent write up and the timming is spot on. I just sat my body back on yesterday after doing a full body rebuild and a IRS conversion to the
floorpan, only problem I have is I never had a standard height to start working with and when I put the torsion bars in I have set them way to high. I
will need to take them out and start again.
Joel
posted on November 15th, 2009 at 11:21 AM |
wait till you have the engine back in and all the car back together
you will be amazed how much it will settle
mine with a 1 spline drop and no engine sat higher than that
trickysimon
A.k.a.: Simon Azzopardi
Threads: 43
posted on November 15th, 2009 at 01:12 PM |
I might need to raise mine. Hit the sidewinder shifting into second
Pages: 1 2 |
