[ Total Views: 13307 | Total Replies: 98 | Thread Id: 78941 ] |
Pages: 1 2 3 4 |
electricmonk
A.k.a.: Jason
Threads: 56
Mood: Indego
posted on October 13th, 2009 at 07:34 PM |
Thanks PM sent. Nice to be riding the crest of the wave with you lot. Here's hoping for the best results possible. Good luck to everyone.
And they shall beat their swords into plowshares, for if you hit a man with a ploughshare, he'll know he's been hit
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on October 14th, 2009 at 11:23 AM |
Ok, all of them on their way.
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on October 16th, 2009 at 01:25 PM |
Here are some wiring diagrams on the net. There will be some differences. Some of these state that if the bulb is blown that the alt will not work,
this is correct for the original vw alt found in the type 1's but not for these alts as they are excited through the IG wire.
D+ wire at generator should go to the main power terminal on the alternator.
IG goes to the ignition.
L is connected to the DF wire in the engine bay.
Generator regulator is removed or disconnected.
D+ is bridged to B+
DF is bridged to wire 61(this goes to the dash light)
http://www.vw-resource.com/alternator.html#wiring
http://www.nls.net/mp/volks/schem/gen_alt.htm
Quote of the week
vwombat
A.k.a.: Martoon
Hey Ho - Lets GO!
Threads: 48
Mood: uebergeil
posted on October 17th, 2009 at 10:45 AM |
Thanks mate -
it arrived yesterday during my little girls birthday party. Nice that I got a present too!
I'm on this right now.
I'll post some pics and a report tonight!
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on October 17th, 2009 at 11:47 AM |
Cool, hope all goes well. Just remember to disconnect the battery first before you start to play.
Quote of the week
vwombat
A.k.a.: Martoon
Hey Ho - Lets GO!
Threads: 48
Mood: uebergeil
posted on October 17th, 2009 at 12:12 PM |
Quote: | Originally
posted by mackaymanx
PROBLEM!!! Because the RED D+ wire should be sent to both the battery and subsequently the starter solenoid with the standard wiring setup plus the
fuse box (by bridging at the voltage regulator), what exactly gets connected to the ignition terminal on the altinator? The light terminal gets the DF
GREEN wire, but does the ignition need a new 30 amp wire to the 2nd red (fusebox) connection at the regulator?
vwombat
A.k.a.: Martoon
Hey Ho - Lets GO!
Threads: 48
Mood: uebergeil
posted on October 17th, 2009 at 12:20 PM |
The wiring diagram would indicate the splice at the regulator would be enough for ignition... Hmmm... Empty ignition terminal or new wire... Hmmm...
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on October 17th, 2009 at 12:53 PM |
The IG wire goes to the positive side of the coil. So the alt excites when the ignition is turned on.
Quote of the week
vwombat
A.k.a.: Martoon
Hey Ho - Lets GO!
Threads: 48
Mood: uebergeil
posted on October 17th, 2009 at 02:10 PM |
Eureka - it's alive! It's ALIVE!!!
Running at a sweet 14.8 to 14.11V at low cold idle and high RPM's. Genny light comes on for ignition and goes straight out as she fires up.
Started up 5 times, all good and kept pumping out the voltage.
It looks like you might be onto something Dr FrankenManx! I'll keep you posted as I road test over the next couple of weeks.
Interestingly, I found some circuit diagrams for these alternators on both a Triumph motorcycle and a light aircraft site among others. Looks like
they get around!
Muchos Gracias Amigo!
vwombat
A.k.a.: Martoon
Hey Ho - Lets GO!
Threads: 48
Mood: uebergeil
posted on October 17th, 2009 at 02:17 PM |
I've been idling the engine now for 35 minutes. the alternator is up to 14.12V and not even thinking about getting warm.
telf
posted on October 20th, 2009 at 01:35 PM |
Hi vwombat i got mine late last week. I was gona fit it over the week end but ran out of time Since you've got yours going could you pm me your ph
no so i can confirm what wires go where.
Thanks Telf
vwombat
A.k.a.: Martoon
Hey Ho - Lets GO!
Threads: 48
Mood: uebergeil
posted on October 20th, 2009 at 06:45 PM |
Bring it up if you want. See PM.
Went for a long, fast, hot day run and it's still going like a bought one!
vwombat
A.k.a.: Martoon
Hey Ho - Lets GO!
Threads: 48
Mood: uebergeil
posted on October 22nd, 2009 at 06:57 AM |
Sheesh! Somebody deleted my PHOTOS from the camera.
I'll have to go and make some new ones now, and so much for my before and afters!!!
Blood - I want BLOOD!
telf
posted on October 22nd, 2009 at 09:18 AM |
Thanks for your help on the phone last night.
Ill try and get some pics of the before.
and put them up!
electricmonk
A.k.a.: Jason
Threads: 56
Mood: Indego
posted on October 22nd, 2009 at 10:59 AM |
Mine arrived late yesterday. Hope to be fitting it today.
electricmonk
A.k.a.: Jason
Threads: 56
Mood: Indego
posted on October 23rd, 2009 at 01:26 PM |
Oh god look at all that smoke!!!!
LOL Just kidding. Installed today and 14.5 Volts. Have not driven it on the road yet but may be able to try it tonight.
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on October 23rd, 2009 at 01:58 PM |
ha bloody ha
Good to see they have been a reasonably easy fit. Now we see if they stand up to everyday use.
vwombat you have the alt (003) with the upward facing terminal? make sure you use the the boot on the main terminal (just as a safety measure)
More here http://www.thesamba.com/vw/forum/viewtopic.php?t=377832&start=0&postd...
Quote of the week
vwombat
A.k.a.: Martoon
Hey Ho - Lets GO!
Threads: 48
Mood: uebergeil
posted on October 23rd, 2009 at 04:14 PM |
It's on and cruising! You are an official Entrepreneur!
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on October 23rd, 2009 at 05:23 PM |
Yeah sure, Watch out Donald Trump!
Just wanted to check on that alt as I assembled it with the terminal upward as it has a shorter terminal.
Quote of the week
electricmonk
A.k.a.: Jason
Threads: 56
Mood: Indego
posted on October 23rd, 2009 at 08:08 PM |
Mate I think these would sell quite well. The install took all of twenty minutes. You could be on a winner
Took the car for a spin tonight and all went well (apart from the blasted timing on the 009. After a good drive still 14.5 volts.
telf
posted on October 24th, 2009 at 10:24 AM |
Finally got it in the car. It was pretty straight forward. It took me a bit more than 20 mins, but i was messin about doing some other small stuff
whilst i had the alt off the car. Whilst idling it was on about 13.25. Cant wait to put it in to daily use.
Ill keep you up to date!
Thanks Telf
Sorry but forgot to take some picks
electricmonk
A.k.a.: Jason
Threads: 56
Mood: Indego
posted on October 30th, 2009 at 09:44 AM |
Still going strong, got a couple of drives in before rego expired. Crappy 009 gave me hell but Alternator works a charm. Might be a week or so before
she is on the road again
telf
posted on December 8th, 2009 at 10:10 AM |
Still Going strong!!!
electricmonk
A.k.a.: Jason
Threads: 56
Mood: Indego
posted on December 12th, 2009 at 04:38 AM |
Same here.
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on December 12th, 2009 at 07:22 AM |
How about some pics guys.
Quote of the week
electricmonk
A.k.a.: Jason
Threads: 56
Mood: Indego
posted on December 13th, 2009 at 03:25 PM |
ummm...But I haven't done my hair. Seriously though I should be able to take a couple this week
brightsparq
Threads: 1
Mood: catching a ball in a cup
posted on December 19th, 2009 at 10:08 PM |
Cool idea just wondering what the output amperage is ? |
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on December 19th, 2009 at 11:23 PM |
They should be about 45 amps (from early swift/barina). I can get a 100 amp alt to convert but they are very expensive.
Quote of the week
brightsparq
Threads: 1
posted on December 20th, 2009 at 10:24 PM |
Anybody with one fitted got a dc clampmeter/ amp gauge? 45 amps is pretty reasonable output. Are these fitted to anything else apart from swift/
barina? |
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on December 21st, 2009 at 07:22 AM |
I got 5 junk ones from my local auto electeician and when I went through the part numbers I got Yanmar, Suzuki and Diahatsu(feroza applause charade).
Early '90s for the suzukis and I think the same for the diahausu stuff also.
Quote of the week
Pages: 1 2 3 4 |
