[ Total Views: 294864 | Total Replies: 1178 | Thread Id: 80275 ] |
Pages: 1 .. 13 14 15 16 17 .. 40 |
Smiley
A.k.a.: Daniel Stephens
Threads: 110
Mood: Synchro'd
posted on June 24th, 2011 at 07:37 PM |
Quote: | Originally
posted by bajachris88
and now that you got the bolts in there already, you atleast know the thread should be nice, clear and clean for reinstallation compared to how it was
initially maybe ???
The issue was more that the holes didn't line up because the framehead I bought wasn't built to the greatest tolerance.
When I put the body on I had to start them first and then move the body around to get everything else to start.
Smiley
bajachris88
A.k.a.: Chris Leete
Threads: 534
posted on June 24th, 2011 at 07:44 PM |
maybe worry bout beam braces when you have an offroad beam and lift kit prepped to go, then smash it out?
are they necessary if you run a stock beam and don't intend on having massive front end knocks on boulders?
(ô_!_/ô) (ô_!_/ô)
69' baja: kombi box, thing spindles, irs, disc front, type 3 rear drums, 2 inch lift kit, 31x10 rears.
matberry
posted on June 24th, 2011 at 10:00 PM |
Mate, stock beetles in 1950 were fitting them because the frame heads cracked. That was when they were new. I fit them to every car that has anything
improved over stock. The ones pictured above that only attach to the lower tube are very close to useless. They really need to support both tubes with
a diagonal brace rearward, or tie to the shock upright between the tubes, and rearward to the 2 M10 bodymount bolts.
Smiley
Threads: 110
Mood: Synchro'd
posted on June 24th, 2011 at 10:02 PM |
As I have proven they are necessary if you have adjusters welded to your beam.
The stock beam flexes back and forward even on a stock road going Beetle. Once you cut it in half and weld in adjusters you introduce a weak spot
which happens to be at the center of the beam which is flexing back a forward. Adding the braces helps to significantly reduce the ends of the beam
moving back and forward.
I should have added them when I built the car and now I'm paying the price.
Smiley
matberry
posted on June 24th, 2011 at 10:05 PM |
Back and forward is some of it Smiley, but worse is the rotational/torsional loads, that is why the braces need to tie to both tubes.
Smiley
Threads: 110
Mood: Synchro'd
posted on June 24th, 2011 at 10:12 PM |
Quote: | Originally
posted by matberry
These are the mounts that hold my front bar on.
If I run a tube from here (lined up with the bottom torsion tube) back to my floorpan, then run a tube or plate from the top of this mount back down
to the bottom tube will this be enough for my mild Baja for the time being?
Smiley
matberry
posted on June 24th, 2011 at 10:14 PM |
It sure will mate.
matberry
posted on June 24th, 2011 at 10:16 PM |
It sure will mate.
The diagonal could be tube, solid of even flat bar, on edge set diagonally.
68AutoBug
posted on June 24th, 2011 at 10:23 PM |
OH! those kinda braces...
I went with the idea your dreading with off the shelf beam braces from cip1. There were two kinds, lower braces (bolt in the body bolts) and upper
braces that bolt into the front firewall.
I didn't like the idea of bolting in there, because the image of a front end acident and the steel bar driving into my leg was a bit of a turn
off.
These braces are solid as though. and now that you got the bolts in there already, you atleast know the thread should be nice, clear and clean for
reinstallation compared to how it was initially maybe ???
Hi Chris
You will need extended grease nipples to grease Your torsion bar bearings , as they look too close to the brackets...
those brackets look a good idea....
bajachris88
A.k.a.: Chris Leete
Threads: 534
posted on June 24th, 2011 at 10:24 PM |
hmm! i have an old beam brace like what u describe Matt that used to be on my 67 baja, but didn't fit the balljoint beam because of clearance issues
with all the nick nacks about.
i have 1 intact in the backyard, will take photo soonish.
1 i cut up to mod to fit the balljoint but never finished. its been hacked up bad.
heres a pic of what it looked like. didn't ahve diagonal brace, it was a steel angled rod, connecting to the beam tubes clamp and tube backing up to
the m10 bolts
Error |
(ô_!_/ô) (ô_!_/ô)
matberry
posted on June 24th, 2011 at 10:27 PM |
That's one locally made, prolly by Custom Off Road Components, they have been making them fo 35-40 years, reckon there's a few sets out there.
bajachris88
A.k.a.: Chris Leete
Threads: 534
actually, it musta worked well, cos out of everything that was on that POS car, the beam was one of the very fuew straight un-farked components i got
out of it
btw, thanks Matt for the heads up. i'd aught to get some tube angled to the top bars then. I was more inclined on the road bumps and torsion bar
response puting teh beam back at the ends and producing a moment about the frame head than radial of top twisting over bottom (well visa versa)
(ô_!_/ô) (ô_!_/ô)
matberry
posted on June 24th, 2011 at 10:31 PM |
They are 100% necessary IMO, but you don't have to take my word for it, just ask Smiley....hey, it's his thread.
baghall
Ben Hal Outlaw Bushranger
Threads: 131
Mood: Kids think I'm obsessed!
posted on June 25th, 2011 at 09:48 AM |
Well I have been thinking about beam support as mentioned here but haven't done it yet. Better get onto it, but am glad I haven't yet welded in beam
adjusters. Hope you get it back together quick smiley!
68 Baja - It's a growing pain!
58 Baja ute - and the pain spreads!
85 T3 Kombi - still growing
89 T3 Kombi - parts car
Smiley
Threads: 110
Mood: Synchro'd
posted on June 25th, 2011 at 10:57 AM |
Quote: | Originally
posted by matberry
SECONDED!!!!
Matt, do you have any pictures of the setups that you have built? Do you run into issues with the tie rods clearing the top brace??
Smiley
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on June 25th, 2011 at 03:56 PM |
http://forums.aussieveedubbers.com/viewtopic.php?tid=57446
i have a few sets of these, interestingly the stoko beetle recently aquired has a set too.
Smiley
Threads: 110
Mood: Synchro'd
posted on June 25th, 2011 at 04:45 PM |
Very nice. I'm going to make something similar to this but it's going to be welded to the floorpan instead of bolting on.
Once I get around to doing my lift kit I'll cut them off and remake them to tie into the C-channel.
Smiley
matberry
posted on June 25th, 2011 at 09:21 PM |
Sorry Smiley, only digital pics are ones you have seen already
Smiley
Threads: 110
Mood: Synchro'd
posted on June 30th, 2011 at 06:20 PM |
Ok. I haven't really had much of a chance to work on the car this week.
On Tuesday afternoon I put the spare beam in. And assembled the front end with everything except the torsion bars installed. This way I can cycle the
suspension and make sure that none of the steering or suspension is going to hit my brace bars.
Smiley
Smiley
Threads: 110
Mood: Synchro'd
posted on June 30th, 2011 at 06:22 PM |
You can see in these next few pictures that even on the drivers side with the steering on full lock and the suspension at full droop that I'm going
to have plenty of room to run the bars.
Smiley
Smiley
Threads: 110
Mood: Synchro'd
posted on June 30th, 2011 at 06:25 PM |
I picked a bit of scrap tubing out of the bin at work that I'm going to use for the braces. Going to make use of the bends in the tube to keep the
bar as close the the body and out of the way of the tyre. I think I'll only have very minimal rubbing. This setup is also only temporary too, because
when I install a lift kit into the cars I'm going to redo all the bracing/front barwork etc.
Smiley
Smiley
Threads: 110
Mood: Synchro'd
posted on June 30th, 2011 at 06:37 PM |
You can see here that there will be no clearances issues in any way on the passengers side.
When I undid everything off the beam and disassembled it, it literally fell in two.
And you should have seen the amount of sand that was in the bottom torsion tube when it came apart! It must be getting in through the adjust.
Does anyone else have this problem?
What have you done to prevent it??
I hope to get the braces made up and tacked in tomorrow afternoon at a minimum. But I'm going to try and have the car all back together and drivable
again by Saturday lunchtime at the latest.
Thanks for looking
Smiley
Smiley
Threads: 110
Mood: Synchro'd
posted on July 5th, 2011 at 07:55 PM |
Got another half hour of time this afternoon to do a tiny bit on the car.
I made the RHS beam brace up. That is all. More soon hopefully.
Smiley
11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
posted on July 5th, 2011 at 08:08 PM |
The ones I have flatten out and use the two large body bolts to attach to the body. I'll take some pics later
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
Smiley
Threads: 110
Mood: Synchro'd
posted on July 14th, 2011 at 09:31 PM |
Got the tubes all welded in last Friday afternoon.
Just need to put the front hubs back on, wheels and bleed the brakes! She should be driving by the weekend.
Smiley
Smiley
Threads: 110
Mood: Synchro'd
posted on July 14th, 2011 at 09:38 PM |
And look what came in the post today!! I didn't know it was Christmas!!
Ceramic coated exhaust.
I'm excited!!
Smiley
matberry
posted on July 14th, 2011 at 09:40 PM |
You really need the added bar to make the brace work properly
Error |
matberry
posted on July 14th, 2011 at 09:44 PM |
Woo hoo new engine
Smiley
Threads: 110
Mood: Synchro'd
posted on July 14th, 2011 at 09:53 PM |
Quote: | Originally
posted by matberry
That is the intention. I need to get it to work around the tie rods too. I think I'll add some flat bar from the top down.
Similar to this.
Smiley
matberry
posted on July 14th, 2011 at 09:56 PM |
