[ Total Views: 26480 | Total Replies: 320 | Thread Id: 82673 ] |
Pages: 1 .. 9 10 11 |
Paulc1964au
posted on August 25th, 2013 at 05:05 PM |
thanks guys i appreciate your advice
Paulc1964au
posted on August 31st, 2013 at 01:46 PM |
Installed an inline suppression filter to the power supply and didnt make any difference i am thinking the distributor has such a strong spark that
nothing is going to stop the issue
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on August 31st, 2013 at 02:05 PM |
You have induction noise, no need for a radio
1303Steve
Threads: 556
posted on August 31st, 2013 at 03:23 PM |
Try disconnecting the charging system, that maybe where the noise is coming from. If that fixes it you may need a suppressor on the charging
circuit
ian.mezz
Threads: 280
posted on August 31st, 2013 at 04:33 PM |
we have big radios in our dubs with electronic diisy and no probs
Paulc1964au
posted on August 31st, 2013 at 04:37 PM |
thanks guys the car is going back to Boris next Saturday for an oil change will look at it then.
BTW Craig took it for a spin and your right i just love the sound of the car
Paulc1964au
posted on August 31st, 2013 at 04:38 PM |
Quote: | Originally
posted by 1303Steve
circuit
If i disconnect one lead that should be fine to test?
Bizarre
Threads: 730
posted on August 31st, 2013 at 04:48 PM |
^^^ No - he is talking disconnecting the alternator
Paulc1964au
posted on August 31st, 2013 at 04:51 PM |
Quote: | Originally
posted by Bizarre
I disconnected the spade terminal wire of the alternator but didnt make a difference
68AutoBug
posted on August 31st, 2013 at 05:46 PM |
Does the noise go up and down with engine revs??
make sure everything is earthed well..
separate perfect earth connections on everything..
means scratching the paint off under each connection..
also, could try attaching an earth lead to the distributor or engine..
check the earth strap at the nose of the gearbox to chassis..
Your spark plug leads - are they resistance type or wire type?
I'm guessing You have a low resistance spark plug lead system
beetles normally have a resistor in the distributor rotor plus in those bits that sit on the spark plugs.. but I'm guessing its an earthing issue...
which is being picked up by Your amplifier etc,,
Paulc1964au
posted on August 31st, 2013 at 06:07 PM |
Quote: | Originally
posted by 68AutoBug
kinda strange its like the amp is being clipped
I have Taylor Spiro Pro 8mm Plug Wire Set - Blue leads
Will have to check all earths so is the earth strap at the front of the gearbox?
68AutoBug
posted on August 31st, 2013 at 06:35 PM |
Hi Paul
You should be able to see it hanging from the chassis to the nose of the gearbox near the front gearbox mount..
I made one out of a new long earth strap I had, I soldered each end and drilled holes
it needs to be shiny on the strap and the chassis metal so it earths out to the chassis metal, not thru the bolt..
Use a new zinc plated bolt and flat washer..
Many of these straps are missing these days and the flow of electricity has to go thru the gearbox gear shifter etc to earth out..
I've seen headlights go dim when changing gears... lol
earthing problems arise due to a car being painted etc.. as its natural not to want to go scratching the paint off.. lol
best of luck
Paulc1964au
posted on August 31st, 2013 at 07:15 PM |
Thanks Lee i will check the earth tomorrow
Bizarre
Threads: 730
posted on August 31st, 2013 at 07:25 PM |
doubt if it is earthing if everything else is working fine
first thing to go would be the battery not charging or not starting properly
I know you are using Taylor Spiro Pro 8mm Plug Wire Set - Blue leads
But are they noise suppression leads??
Paulc1964au
posted on August 31st, 2013 at 07:49 PM |
Taylor Spiro-Pro 8mm Custom Fit Spark Plug Wires
Features
Spiro-Pro's two-layer 100% silicone inner core & outer jacket keep the wires flexible for the life of your vehicle, maintaining its vibrant color
with heat protection to 600º F
Spiro-Pro wire consists of a highly conductive spiral wound core with a stainless steel wire covered with conductive fluorocarbon material
350 ohms per foot resistance provides more fire power to the spark plugs than OE resistor core wires and has up to 10 times less resistance than
standard resistor core wires
Spiro-Pro eliminates radio frequency interference (RFI) and is recommended when using multi-spark discharge electronic ignition systems and other
electronic components
68AutoBug
posted on August 31st, 2013 at 08:28 PM |
Looks like they are OK then Paul...
I like those leads but too expensive for Me.. lol
and I wasn't sure whether they were the suppression type or ones used on race/drag cars which don't need to be suppressed etc...
Paulc1964au
posted on September 8th, 2013 at 06:08 PM |
Probably the best pic of my bug so far, thanks Rick for taking it
rabidbeetle
Mood: in the groove
posted on September 13th, 2013 at 05:33 PM |
Looks amazing Paul,notice that vintage didn't fit a breather box setup for additional breathing to releive crankcase pressure
Paulc1964au
posted on September 13th, 2013 at 09:02 PM |
Quote: | Originally
posted by rabidbeetle
Isn't the hose between the carby and case sufficient?
rose
doin it for d girls
Threads: 308
Theme: UltimaBB Pro Red
Mood: always happy
posted on September 13th, 2013 at 09:09 PM |
Quote: | Originally
posted by Paulc1964au
new motors don't have a lot of pressure to get rid of.
[img][/img]
Paulc1964au
posted on March 12th, 2014 at 06:11 PM |
It's been a while since I posted an update, yesterday Rosie went to Vintage VW for a service as well as a few bits and pieces, as usual Boris, Mike
and the gang did a fantastic job, couldn't be happier.
Next upgrade will be replacement of the rear deck lid with one with 4 vents then I can remove the stand-off
