[ Total Views: 112915 | Total Replies: 1112 | Thread Id: 85894 ] |
Pages: 1 .. 34 35 36 37 38 |
1303Steve
Threads: 556
posted on August 30th, 2019 at 03:05 PM |
NPC in Queensland looked over my clutch and flywheel, they gave them a grind and made my a new cushion puck clutch plate. Ive been wanting to fit a
1/2 cage for a while, I might get it done before the motor goes back in
Error |
hulbyw
Threads: 130
Mood: I'm OK, RU?
posted on August 30th, 2019 at 08:25 PM |
Prettiest clutch plate I have ever seen. Half cage sounds like a good idea given the huge power you have in this Beetle. Amazing car which is a credit
to you
1303Steve
Threads: 556
posted on August 31st, 2019 at 12:21 AM |
Thanks for that.
1303Steve
Threads: 556
posted on August 31st, 2019 at 12:45 AM |
I asked for advice from a water cooled VW tuner when I made my air intake in the right mudguard about what sort of enclosed air filter to use. So I
bought an Italian made BMC Oval Trumpet air filter, the VW tuner told me he was using these on 400 hp water cooled VWs.
You can see the BMC air filter in the top view of my engine
I sent an email to BMC asking what would be the upper limit of this air filter.
Their reply,
"It is difficult to answer. 307 kW is about 415 hp.
In the past we tested the OTAs on engines having the above power, but due to the huge quantity of air they needed, they were insufficient to power any
engine.
The best result we achieved is around 300 hp = 180 rwKw.
Please take note that also other factors must be considered, such as for instance the load loss consequent to the installation.
Just to sum up, it is not only a matter of empirical power.
We eventually recommend the filer with PN ACCDA100-220-01."
My tuner was worried that he couldn't account for the air flow into the inlet at high speed so I'm pretty sure I'm going to use a Blitz Carbon Core
but this time I will only have the air from my mudguard intake blowing on the filter inlet not physically connected as I did with the BMC unit
Error |
Error |
1303Steve
Threads: 556
posted on October 17th, 2019 at 02:22 PM |
As anybody knows who has added more contemporary parts to an old VW you know that you soon run out of places to fit things.
I'm running an in tank Walbro 460, I did suffer some fuel surge at the VW Nationals Supersprint so I'm now fitting a Taarks surge tank with another
Walbro 460 inside, the Walbro pump in the fuel tank will now feed the Taarks surge tank.
One Walbro 460 is good for about 560 kW, if I need more fuel supply I can simply fit another pump inside the surge tank. Im aiming for 400 kW at the
wheels so one 460 should be enough.
Error |
1303Steve
Threads: 556
posted on March 2nd, 2020 at 07:10 PM |
I went for a chrome-moly IHRA spec cage, being checked by their tech guy tomorrow night. The cage was done by Ministry of Fabrication, a new
fabrication shop that usually does cages and nudge bars for drift cars. the guys are ex AGI a well known roll cage supplier. They tied the cage into
my chassis at the rear.
Ministry of Fabrication as the name would suggest use a few lightning bolts as their trade mark.
Putting the motor back in soon then another tune, hopefully get closer to 400 rwkW this time
Error |
Error |
Error |
1303Steve
Threads: 556
posted on March 2nd, 2020 at 07:23 PM |
a few more photos
Error |
Error |
Error |
hulbyw
Threads: 130
Mood: I'm OK, RU?
posted on March 2nd, 2020 at 08:07 PM |
Lookin good!
Flintstones
Threads: 69
posted on March 2nd, 2020 at 09:23 PM |
Nice and stiff now!
Question: With the front roof bar, could you move it to above the visors, so that it's closer to where the front legs bend down?
1303Steve
Threads: 556
posted on March 3rd, 2020 at 07:37 PM |
Not sure if moving the cross piece would help anything.
Just had the car inspected by the IHRA guy, passed with flying colours, he was very impressed with how it was done, needs another inspection with the
car ready to race with all safety gear etc then it is able to go down to a 8.00. pass. I will be happy to get into the 10s.
When I thought about having a cage fitted I wanted to stiffen up the chassis. I had to make new top shock mounts so that I could lay the shocks over
to clear the axles as the motor and trans are 100 mm forward. Ministry of Fabrication tied the cage into the extended shock mounts.
Error |
Error |
1303Steve
Threads: 556
posted on March 4th, 2020 at 11:38 AM |
I was running some Toyo R888R on the street, 225 40 x 18 & 245 40 x 18, great tyre but a little stiff. Iv'e now fitted these tyres to some hollow
spoke twist wheels for track days.
So now I'm going to run some Nitto Invos in 225 40 x 18 and 265 35 x 18.
I also had the wheels repainted by Barrel Bros while they were off the car, same colour
Error |
1303Steve
Threads: 556
posted on March 19th, 2020 at 06:58 AM |
I just had my rear mudguards tidied up after running on Gunnedah Airport, they got really chewed up by rocks on the airport road surface at over 200
kph, the panel beater spayed some stone guard on them.
When I ran my car at a supersprint last year the rear tyre picked up the mudguard intake and ripped it out, just had new one made with hopefully
enough tyre clearance
Error |
Error |
1303Steve
Threads: 556
posted on March 19th, 2020 at 07:05 AM |
I have to run a flywheel scatter shield as well. These are some photos that Wally from the Netherlands fitted to his G50 transmission
Error |
Error |
Error |
hulbyw
Threads: 130
Mood: I'm OK, RU?
posted on March 19th, 2020 at 02:37 PM |
That shield looks pretty tough. Love the new air intake. Smoothe as
1303Steve
Threads: 556
posted on March 25th, 2020 at 04:16 PM |
The photos I posted of the shield belongs to Wally from the Netherlands. I'm making one along similar lines.
I went to a local profile cutting place http://www.hawleysengineering.com.au/ and they are rolling up a piece steel for me now. I cant wait to get this thing back
on the road.
1303Steve
Threads: 556
posted on April 3rd, 2020 at 04:24 PM |
Started on the scatter shield today, rain and lack of welding gas stopped progress
Error |
1303Steve
Threads: 556
posted on April 5th, 2020 at 12:32 PM |
scatter shield painted now I can start putting the car back together
Error |
silver
Dangerous when poked
Threads: 162
Mood: In 2 Minds
posted on April 5th, 2020 at 03:00 PM |
looks good,
lets hope you don't need it
Keeping it real !
1303Steve
Threads: 556
posted on April 5th, 2020 at 05:01 PM |
I sure do hope I don't need it but its for the safety of track officials etc. If a failure took the front off the gearbox that's $10,000
1303Steve
Threads: 556
posted on April 25th, 2020 at 11:27 AM |
I fitted a nice radiator overflow where the air conditioning compressor would normally fit and something I've been meaning to do for a long time, a
rear tray to fit between the rear apron and motor. I'm not sure if this will upset airflow in the engine bay
Error |
1303Steve
Threads: 556
posted on May 6th, 2020 at 11:14 AM |
Its running again, booked in for tune session in a few weeks. I'm really happy with new clutch, not grabby at all unlike the organic Kennedy clutch
plate
1303Steve
Threads: 556
posted on June 4th, 2020 at 09:09 AM |
Just got the car back from the tuner, I was hoping for more but it looks like I may have reached the limit of the current setup. Its still scary
fast.
Now I waiting for the drag strip to open so that I can have the approval on my cage ticked off.
Error |
hulbyw
Threads: 130
Mood: I'm OK, RU?
posted on June 4th, 2020 at 11:17 AM |
Very impressive!
1303Steve
Threads: 556
posted on June 5th, 2020 at 05:44 PM |
thanks
nbturbo
Threads: 89
Theme: UltimaBB Powder
posted on June 6th, 2020 at 05:39 PM |
That much power should cause an explosion in your underpants - well done
1303Steve
Threads: 556
posted on June 7th, 2020 at 03:49 PM |
thanks its a ball to drive
1303Steve
Threads: 556
posted on August 3rd, 2020 at 04:58 PM |
With all the Covid closures the local drag strip has decided to resurface the strip so I still haven't had the final tech inspection on my cage
I've entered a roll racing event at the Sydney Motorsport Park this coming Friday 7th August but the weather predictions aren't too good for that
night.
I've fitted up my Mickey Thompson ET Streets for the event on some 18x9 Simmons OM wheels, they a 245/40x18. Took it it for a kebab run the other
night, they are hooking up nicely even though they have been sitting next to my garage unused for about 5 years
Error |
1303Steve
Threads: 556
posted on August 8th, 2020 at 09:38 AM |
Roll racing was called off with the rain, now I have to wait until 21st August to have a run
hulbyw
Threads: 130
Mood: I'm OK, RU?
posted on August 8th, 2020 at 11:24 AM |
Bugger. Car looks fantastic
1303Steve
Threads: 556
posted on August 9th, 2020 at 10:18 AM |
thanks
