[ Total Views: 23655 | Total Replies: 177 | Thread Id: 88662 ] |
Pages: 1 .. 4 5 6 |
hypo-vw
A.k.a.: Wayne Penrose
Threads: 82
Mood: hypo cruis'n
posted on August 1st, 2013 at 07:13 PM |
the new accelerator pedal has been modified & installed
Error |
Team
FASTEST SPEED @ WARWICK 2011
FASTEST ET & SPEED WSID 2012
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on August 1st, 2013 at 07:14 PM |
thats enough playing on the computer tonight !! I am going to install the fuel tank & the water tank (for the intercooler) tonight
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on August 5th, 2013 at 07:21 PM |
well I did stay back at WPVW late on thursday night to get the tanks mounted in the front of the new circuit car
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on August 5th, 2013 at 07:26 PM |
with the fuel tank & water tank installed , I now have to fabricate support brackets from the mounting plate to the chassis . I will then start to
mount the fuel pumps & surge tank etc
Error |
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on August 10th, 2013 at 01:33 AM |
I install an additional brake fluid reservoir which will feed the brake fluid to the 2 master cylinders . This will enable me to keep a check on the
fluid level without having to disassemble any of the car to get to the master cylinders on the pedal assembly .
I then fabricate a mounting plate for the fuel surge tank , EFI fuel pump & Carter lift pump
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on August 10th, 2013 at 01:39 AM |
the internal rear panels had to be cut to enable correct fitment , I add an aluminum support plate where they were cut
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on August 10th, 2013 at 01:44 AM |
new front & rear cross-drilled discs are purchased in Chevy/Porsche pattern . All new wheel bearings are installed . Rear wheel spacers in 12mm
are also purchased
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on August 10th, 2013 at 02:17 AM |
all of the brake discs are installed . New titanium wheel studs are installed also
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on August 10th, 2013 at 02:19 AM |
all of the rear panels are secured down
Error |
Error |
Team
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
posted on August 10th, 2013 at 08:54 AM |
Looking very neat Wayne
cnfabo
Threads: 140
posted on August 10th, 2013 at 11:59 AM |
Motivation right here, thanks Wayne I'm heading to the cave ..
What calipers are you going to use..
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on August 10th, 2013 at 02:43 PM |
Quote: | Originally
posted by cnfabo
the front calipers are alloy Brembo from an early 911 Porsche & the rear calipers are going to be standard superbug twin-pin
I split the front alloy Brembo calipers to remove the bakelite spacer blocks so that I can use them on the solid discs , as these calipers were
traditionally used on ventilated discs . It is a very good thing that I did pull them apart as the person who assembled them had pinched one of the
seals & they would have certainly leaked
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on August 10th, 2013 at 02:46 PM |
the alloy Bremo calipers are installed and fit perfectly with the solid front brake discs . These calipers bolt directly to the type-3 stub-axle
assemblies without any adaptor plates
Error |
Error |
Error |
Error |
Team
humpty
Threads: 139
Mood: Totally boosted!
posted on August 10th, 2013 at 06:58 PM |
Awesome to see the Dak to the future Dub come together finally... Looking forward to seeing how it goes in the roundy, roundy stuff.
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on August 12th, 2013 at 08:53 AM |
Quote: | Originally
posted by humpty
yeh I know Simon , I have been a bit slack with this one as I have been very busy helping Ben , Chris & Cindy with their cars and also the new
engine build for the oval (not to mention a long pointy thing that arrived from US) ..... I should have had this car on the track long before now ,
but it wont be too far away . I am nearly ready to strip the entire car for powdercoating / detailing , then back together it goes for the final build
Team
vassy66T1
A.k.a.: Marcus Vass
posted on August 13th, 2013 at 07:54 AM |
I don't think you have been slack Wayne!!!
Good output coming from your workshop.
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on August 13th, 2013 at 09:45 AM |
Quote: | Originally
posted by vassy66T1
Thanks Marcus , we are now preparing Ben Ford' supercharged drag bug for Warwick while I am working on DTTF ..... Bens bug made 332hp@ 4500rpm at
the wheels and wont breath after that . We are remaking his supercharger manifolds for better flow ..... but I want to stay working on DTTF until it
makes noise and is finally on the track !!
Last night Dean & I sorted out what fuel fittings & hose we need up front , I then installed the clutch slave cylinder , then installed the
new turbo ready for exhaust connection
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on August 19th, 2013 at 11:07 PM |
I have done more work on DTTF . The hydraulic clutch slave cylinder has been installed ..... the new T-70 turbo is installed with the exhaust flange
ring & clamp
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on August 19th, 2013 at 11:20 PM |
I purchase 2x 4" mandrel bends and a 4" to 3" reducer for the exhaust pipe from turbo to muffler . Here the new 4" mandrels are pictured beside a
2.5" alloy 90degree mandrel to show their massive size . A new flange plate is bolted to the muffler
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on August 19th, 2013 at 11:33 PM |
the fabrication of the exhaust continues with the attachment of the reducer pipe to the exhaust flange
Error |
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on August 19th, 2013 at 11:43 PM |
the exhaust is connected from the turbo to the muffler , next I will have to fabricate the wastegate plumbing
Error |
Error |
Error |
Error |
Team
lou0060
Threads: 30
posted on August 20th, 2013 at 07:18 PM |
great stuff Wayne. can't wait till Nationals next May as this is when you seem to unviel new cars.
By the way, my old man built RH a trailer for this car back in 1998-9 so have a keen interest to see this finished and going.
1971 karmann ghia Cabrio - Cruising
1963 beetle Sunroof - gathering dust
1968 race beetle - twin turbo Subaru - stress relief
1960 beetle - old school low & slow
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on August 20th, 2013 at 09:37 PM |
Wow, look at the angle on the axles and CV joints
lunar_c
Threads: 16
Mood: Excellent
posted on May 29th, 2014 at 01:07 PM |
Thank you so much for sharing just how much work goes into preparing a car like this. It's an overwhelming task! Best of luck in getting it ready on
time. I look forward to some footage of it running.
6 Dubs in and counting..
1966 1300 Deluxe Beetle in polar white.
silver
Dangerous when poked
Threads: 162
Mood: In 2 Minds
posted on August 30th, 2015 at 09:02 PM |
"Future" is just an expression
Keeping it real !
OZ Towdster
A.k.a.: Andrew Westwood
Keen to finish some projects
Threads: 132
posted on August 31st, 2015 at 05:06 PM |
Why an earth would you remove a tandum adjustable brake master cylinder system for a single circut master cylinder
Flintstones
Threads: 69
posted on November 5th, 2015 at 08:26 PM |
Any further progress on DTTF?
ricola
Threads: 9
posted on November 11th, 2017 at 12:10 AM |
Was surprised to see this finished in the latest Performance VW magazine!
Pages: 1 .. 4 5 6 |
