[ Total Views: 105606 | Total Replies: 85 | Thread Id: 90207 ] |
Pages: 1 2 3 |
live2surf
Threads: 0
posted on July 7th, 2011 at 03:23 PM |
Awesome Brent, your bus is really coming together! Well done. |
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on July 7th, 2011 at 05:06 PM |
Trial fitted the SmallCar sump oil pickup and was not very impressed with the fit. With one side of the flange on the block there is quite a gap on
the other side. This is a critical part that must seal properly to prevent air sucking into the system. I'll trim it down to get it to seal but it
pisses me off that I have to.
Error |
Error |
Error |
Quote of the week
MickH
A.k.a.: Michael Hutchinson
Hairy Gutted Sloth
Threads: 29
posted on July 7th, 2011 at 05:49 PM |
now thats not very impressive..........
tssnq.com.au
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on July 7th, 2011 at 06:34 PM |
2nd sump should turn up tomorrow so I will compare the oil pickup for that with this one.
Quote of the week
Ben386
Threads: 26
Mood: Never had a bad day
posted on July 7th, 2011 at 10:40 PM |
Yeah Skot,in the T3 after you remove the tin ware you could do it in the vehicle.
You dont want to do this after you have just finished your conversion.
I have manged to stop the leaking head.
I will let you know how when I see you next.
With yours, do the heads mate,then no worries.
She stops well now!
Ben386
Threads: 26
posted on July 7th, 2011 at 10:46 PM |
Brent,check the clearance between the sump and pick-up too.There is reports about the early SC sumps not having suffient clearnce causing
starvation.
BenC
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on July 8th, 2011 at 08:21 PM |
Well my 2nd sump turned up today and the oil pickup fits, I had to take a file to it first but it fits. KEP automatic adapter I ordered came with the
sump, these are very well machined . Made up some tools to torque
the pulleys properly with, crank one worked well but the timing pulley one needs tweaking.
Error |
Error |
Error |
Quote of the week
MickH
Hairy Gutted Sloth
Threads: 29
posted on July 9th, 2011 at 11:08 AM |
Hey man......u know yer engine is upside down.....
tssnq.com.au
Scottkombi
Mood: Sick of Work
posted on July 11th, 2011 at 11:26 AM |
Just a matter of interest - why did you go for the adapter ratehr than the bellhousing replacement? Aparently the VW flywheel is heaps lighter and
hence using it means you engine torque will suffer.
88 Caravelle Syncro Camper
89 Caravelle GL microbus - 5 speed
69 Microbus
05 Mk5 Golf 1.9 TDi DSG
Ben386
Threads: 26
posted on July 11th, 2011 at 11:30 AM |
I think the vv is 9lbs,subaru 11lbs
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on July 11th, 2011 at 01:56 PM |
Quote: | Originally
posted by Scottkombi
I'll clear this up, the adapter plate (auto) is for for my notch. The caravelle will be getting the bellhousing. I just got everything in one order
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on July 21st, 2011 at 02:17 PM |
Coolant Manifold 1
SmallCar sent me a replacement oil pickup tube, it's better than the last one but the alignment is still not good, service was good thought.
Picked up my coolant manifolds today, I've gone two different ways to do a comparison. Here is the the first one with the manifold reversed, bosses
welded on for sensors, outlet sectioned and welded.
Error |
Error |
Error |
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on July 21st, 2011 at 02:19 PM |
one more
Error |
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on July 21st, 2011 at 02:29 PM |
Coolant Manifold 2
Here is the second option. The manifold is not reversed, outlet is removed and pluged, outlet is then rewelded onto the other end.
Error |
Error |
Error |
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on July 21st, 2011 at 02:30 PM |
one more
Error |
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on July 21st, 2011 at 02:35 PM |
Some side by side shots.
Error |
Error |
Error |
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on July 24th, 2011 at 07:21 PM |
Manifold installed with the coolant bleed off hooked up. Earlier T3 coolant temperature sensor installed in place of the subaru one, this will let the
temp gauge work properly in the dash, tapped this out to the correct M10x1.0 thread.
Edit - if yor wondering where I got the barbed elbows that are silver soldered into the coolant pipe you can salvage these from a subaru fuel filter.
Error |
Error |
Error |
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on July 24th, 2011 at 08:41 PM |
This is the spacer you have to install under the dipstick when use the smallcar sump. Have to admit I got caught with this and it was a pain getting
the dipstick tube in and aligned properly. Tube needs to be tweaked a little and would have been easier to do when I had the timing covers and pulley
off doing the cam seal. Spacer ended up being about 15.5 mm high.
Error |
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on July 24th, 2011 at 09:23 PM |
Bit of minor clearancing between the sump and water pump. This is needed for turbo pumps (which I am using) and the later subaru pumps. Engine mount
also needs some work.
Error |
Error |
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on July 25th, 2011 at 06:18 PM |
Shaved a bit off the mount bolt head, gets a bit tight around the pump.
Filed back this casting flash on the bellhousing as the header were touching. Will end up with a bit more space as the headers were trail fitted
without gaskets.
Error |
Error |
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on July 27th, 2011 at 03:38 PM |
Machined up some blanking plates for the coolant manifold. Then frankensteined this together, filled the manifold with water and pressure tested it to
30 psi (about twice working pressure). No leaks on this one.
Error |
Error |
Quote of the week
Ben386
Threads: 26
posted on July 27th, 2011 at 10:30 PM |
Good work.Those headers dont stay shiny like that for long,unfortuantly.
Just a thought,have you seen the Tom Sheils thermostat housing.This may give you more clearance.
Have you made a coolant by-pass yet,dont be tempted to make one from plastic tees.
BenC
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on August 4th, 2011 at 08:14 PM |
Yes I have seen the Tom Sheils thermostat housing, coolant bypass is built into the manifold.
Quote of the week
Ben386
Threads: 26
posted on August 4th, 2011 at 09:49 PM |
Are you going to run your heater?VW and Subaru coolant flows in opposite direction.
MickH
Hairy Gutted Sloth
Threads: 29
posted on August 4th, 2011 at 10:16 PM |
Quote: | Originally
posted by Ben386
But they both flow towards the front of the car
tssnq.com.au
Ben386
Threads: 26
posted on August 5th, 2011 at 03:20 PM |
You know what I mean Mick
Adsman
Threads: 21
posted on August 5th, 2011 at 09:43 PM |
looking good Brent
What my garage isn't messy........Well chaos is a form of order isn't it?
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on October 18th, 2011 at 03:51 PM |
Small update.
Machined up a wedge for between the throttle body and the intake manifold. This should give me a better angle and more space in the engine bay.
Scavenged and modified this from the original subaru motor intake manifold.
Also replaced the plastic fuel fitting in the engine bay.
Error |
Error |
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on October 27th, 2011 at 06:19 PM |
Ok, finally some real progress!
Lost quite a bit of time getting over a bad back but mobile again
now
Error |
Error |
Quote of the week
Ben386
Threads: 26
posted on October 27th, 2011 at 08:36 PM |
Looking good mate.
Glad I did mine on a hoist.
Clean up and paint the tin ware,makes it all look mickey mouse.
Pages: 1 2 3 |
