[ Total Views: 8007 | Total Replies: 30 | Thread Id: 90803 ]
Author: Subject:  IRS camber and toe adjusters... just found this
posted on June 8th, 2012 at 08:51 AM
Originally posted by kombi_matt
Another very simple approach is to use some washers to space between the spring plate and the bit where it bolts to the hub. Ive seen this idea on a few slammed bay windows to correct the heinous toe out/ excessive neg camber, though it might be little different with the 3 bolt design of the beetle spring plate
Not a nice way to rectify toe/camber on a bay, fix the problem, not the symptom.
Oh, and that principle won't work on a bug, the bay suspension has a seperate bearing carrier-diagonal arm.
[ Queries: 40 ] [ PHP: 11.7% - SQL: 88.3% ]
