[ Total Views: 25197 | Total Replies: 244 | Thread Id: 91120 ] |
Pages: 1 2 3 4 5 .. 9 |
sander288
"Bolt-on Master"
Threads: 183
posted on January 10th, 2012 at 04:23 PM |
Update
Argh!
Got spark happening; and then systematically checked all the ignition system from switch to plugs - all working
So still no start; and the winner is fuel....
disconnected the fuel hose that goes to the tee piece and it was dry; looked under the car and the fuel isn't moving past the filter that is next to
the gearbox,
Ironic seeing that everyone said look out for too much pressure!!
Will get a new pump tomorrow and hopefully the thing will go, next time I get a new motor i'll take the whole car up and get it turn key!
Shaun
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on January 10th, 2012 at 04:52 PM |
Fun, isn't it.
But when it fires up, and runs sweetly, it will be worth all the pain.
Don't bring the engine stand back just yet, Shaun.
Sides
A.k.a.: Dave Sidery
posted on January 10th, 2012 at 05:22 PM |
Oh c'mon Shaun... just get it DONE already will ya !!!
btw - you've checked it's not just a blocked filter, or a bug crawled into the disconnected fuel hose or somethin... yeah ???
Like the others have said - nothing more satisfying than when you've got it going yourself...
My toys
ian.mezz
Threads: 280
posted on January 10th, 2012 at 06:34 PM |
did uou put the fuel pump lines on back to front.?
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on January 10th, 2012 at 06:50 PM |
yeah i thought that too Ian
pump rod length too
sander288
"Bolt-on Master"
Threads: 183
posted on January 10th, 2012 at 07:42 PM |
doubled checked all the fuel connections and the fuel is making it to the pump have cranked it over and nothing is coming out of the pump.
The rod length is fine too; I checked the rod movement and also length when I installed the pump,
The lines are installed correctly too; into the top one and out the bottom one, sounds silly but I took photos of it before I took everything off too
make sure it went together in the working order!
Thanks for all the replies everyone; appreciate the help
Doug Sweetman
Nil Bastardo Carborundum
Threads: 58
Mood: sweeeeet
posted on January 11th, 2012 at 12:22 AM |
I once had the pivot pin work loose and fall out of a fuel pump on my l bug.... It moved enough that the mechanism inside the pump fell off it and th
pump thus had zero stroke length and no fuel flow ( Brazilian rubbish). That was a biatch to troubleshoot....
Do he mechanical pumps ever have problems priming ? Coul you start it on aerostart or similar to get it to run long enough to pump / prime ? Likely
just failed diaphragm in the pump tho I guess
sander288
"Bolt-on Master"
Threads: 183
posted on January 11th, 2012 at 01:05 PM |
IT LIVES!!!
The motor is now running; Wolfgang the Tiguan came to the rescue with some jumper leads, a new fuel pump and a cut thumb (final blood scarifice...?)
the motor has roared into life.
Very excited now; will need to work out a day to take the car somewhere to properly work the motor out as the car isn't street registered and i'm on
a main road.
The only things i'll need to do for now is set the timing and get the thing to idle nicely (although it is a bit lumpier than before ) (Edit: and work out a catch tank for the breather...)
Shaun
hellbugged
A.k.a.: Daimo Pell
posted on January 11th, 2012 at 04:54 PM |
cool stuff, always exciting
Aussie Dubbin
Threads: 90
posted on January 11th, 2012 at 05:08 PM |
Congrats. Yay! Engine starting is great. Good luck first drive
Doug Sweetman
Threads: 58
Mood: sweeeeet
posted on January 11th, 2012 at 05:33 PM |
Fantastic !!! Good to hear
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on January 11th, 2012 at 10:00 PM |
Quote: | Originally
posted by sander288
I have the same Ivan Tighe cam (37/68) in my 36hp motor and once the carbs are balanced it idles like a stock motor (not lumpy!).
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on January 12th, 2012 at 07:26 AM |
Well done Shaun. Can you put some old oil, dirt etc. on the NEW
fuel pump?.....it looks a bit flash.
Bet you're pleased to have the engine going......it's a bit like hitting yourself on the head with a hammer, so that you can feel good when you
stop!
Cheers, Greg
sander288
"Bolt-on Master"
Threads: 183
posted on January 12th, 2012 at 06:13 PM |
Yep well stoked with the motor thanks Greg; i'll bring that engine stand down to you if your free this weeked?
Hi Craig; i'll have to work on getting the carbs balanced if thats the case, early days yet...
All the panels are back on now see picture below; really happy with the decklid how it's sitting and also the muffler which doesn't stick out to
far, video to follow which i'm uploading now.
Shaun
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on January 12th, 2012 at 07:11 PM |
No hurry for the engine stand, Shaun.
I'll be driving the Cooper Porsche a Wakefield Park [85th anniversary or the Australian Grand Prix], but if you need to get the stand out of your
way, you can leave it in front of the shed.
Craig Torrens
Threads: 347
posted on February 28th, 2012 at 06:16 PM |
So how was the drags ?
sander288
"Bolt-on Master"
Threads: 183
posted on May 7th, 2012 at 07:39 PM |
Hey All,
Update on the car, swapped out the 4 - 1 header as it appeared to be more bent more then thought after an altercation with a hire trailer and short
ramps.
Replaced with a stainless steel GT 2-tip muffler from Classic Vee Dub
The car had a couple of runs up huntley flat out; but I never got enough tune time before the event, the drags were good; and I believe my time is in
the latest VWMA (haven't got the latest issue yet though)
See below a video of a run I took the bug on today
http://www.youtube.com/watch?v=K7XADvqUKe8
Its running pretty well, but I need to dial in the timing on the Bosch 019 - anyone have a advance function timing light I can borrow?
The other change i'll make is reduce the balance tube size between the Kads to match the fuel line size (1/4"); as at the moment it's 1/2" like
what Porsche used to run on it's Solex PBIC's and I think it's contributing to a mediocre throttle response.
Lastly I moved to Sunny QLD, so enjoy the vid with the great sunshine we've had!
Shaun
Lachlan VL
Threads: 32
Mood: lets hit the streets oh wait no licence
posted on May 7th, 2012 at 10:23 PM |
sounds good love it
sander288
"Bolt-on Master"
Threads: 183
posted on May 8th, 2012 at 07:48 PM |
1/4 Mile was 18.91 at nearly 70mph
Lachlan VL
Threads: 32
posted on May 8th, 2012 at 08:21 PM |
quick for a 1300cc
matberry
posted on May 8th, 2012 at 08:27 PM |
Quote: | Originally
posted by sander288
| Very respectable, well done. Engine sounds great. Got some compression there by the sounds.
sander288
"Bolt-on Master"
Threads: 183
posted on May 8th, 2012 at 08:43 PM |
Quote: | Originally
posted by matberry
Quote: | Originally
posted by sander288
Can't remember what it is exactly but Stan said he took ALOT off the heads.
I think it's about 9.3:1 or so...
hus22l
Threads: 36
posted on May 17th, 2012 at 08:44 PM |
Great work sander!
The engine sounds great. You must be happy with end result.
Were u much over budget?
Hus
sander288
"Bolt-on Master"
Threads: 183
posted on May 17th, 2012 at 09:55 PM |
Budget was a bit over but I bought some parts which I didn't really need like a new dizzy as I had a 009 that worked ok but yeah
Am happy with result, but I need to get it out on an open track and really see what shes like as drags and hillclimb are just too short!
whatnow
A.k.a.: Henry
posted on May 18th, 2012 at 10:03 AM |
nice work. can i pick your brains at some stage re suspension set up.
pity it isn't a '64. in 64 the FIA homologated the okrasa TSV 1300/34 kit. plenty of potential there.
have you considered changing the front brakes to twin leading shoe? i have started having a poke around and it looks quite do-able.
sander288
"Bolt-on Master"
Threads: 183
posted on May 18th, 2012 at 05:44 PM |
Fairly happy with the brakes, am in the process of gathering parts to overhaul the stock set-up.
The car is identical to a 64 in most respects so it's not a hard thing to get it log-booked under the TSV 1300 guise.
How long you been in Armidale? I went to Uni there a few years back and was in my bug then, daily driven, see it in the snow near the airport.
http://www.youtube.com/watch?v=4dd1x4sghXM
what would you like to know regarding the suspension?; I've not done anything new I've treated the car as a BIG 1200 formula vee
Shaun
whatnow
A.k.a.: Henry
posted on May 19th, 2012 at 10:25 AM |
hi, i've been in armidale for years, i lived around the corner from you but never pulled my finger out and dropped in.
all sorts of general set up questions, what works best for you?. rear camber setting, did you set the front height even, a little lower or a little
higher? camber compensator or rear sway bar, front bar size, etc.
from what stan said, i thought you might have trouble being allowed to run pre 1300 major components on your 67.
sander288
"Bolt-on Master"
Threads: 183
posted on May 19th, 2012 at 11:27 AM |
Once you look into historic racing you soon find out ALOT of people are bending the rules and are logbooked as such.
This car is probably heading down a more tarmac rally route than all out historic track machine so getting a historic COD probably won't be
applicable. If need be I only need to have the crank changed to a 64mm one and I'll have a 1200 and it would be sweet.
The Aussie 67s are basically identical to the 62 and a half beetle in most things except the 1300 engine.
My suspension at the moment is,
Front
Slotted 4" VW wheels
Formula Vee Dunlops or Michelin XZX ( 165R15 - street)
Bilstein shocks
3/4" bugpack sway-bar
Stock height for now - but I have some CSP adjusters that need to be installed which I'll use to lower the front end an inch or so.
Rear
5.5 Slotted 356 style rims
Formula vee dunlops or Michelin XZX (165R15)
Lowered 3 inner splines and 3 outer splines or there abouts
it has about 1.5 deg neg camber at the back
Compensating spring - made by Greg Mackie
That's it. My next developments will be to achieve some more pre-loading onto the compensating spring and I'm looking at swapping over to longer
axles from a later swing axle bug (68 onwards) and also some custom valved shocks. The other thing I'm saving for is some Flat 4 BRM's as they are
light and also have a wider offset which should give me a bit more track front and back. Lastly If I can find one I'd like to put an adjustable sway
bar on the front too.
The tyres are also going to be changed over to some Michelin XAS FF in a 155R15 size, these Michelins have the same rubber compound as a Pilot Sport
Cup tyre which is the OE tyre for Porsche GT3 RS and GT2 RS
The car needs to go to a specialist though to get all it's toe-in and out dialed in as I have mates who race historic formula vee and they swear by
it (remember they have the same suspension basics)
Shaun
whatnow
A.k.a.: Henry
posted on May 19th, 2012 at 02:21 PM |
i'm assuming you have seen this:
http://www.longstonetyres.co.uk/page/Special_Offer
free shipping
these ones look interesting... a little about of my budget though.
http://www.longstonetyres.co.uk/page/15-60-15-michelin-tb15.html
i will be running fairly high on factory slotted rims probably with XZX's.
sander288
"Bolt-on Master"
Threads: 183
posted on May 30th, 2012 at 12:51 PM |
Latest Update,
Been playing with the compensating spring on the back. I've made some longer attachments using High Tensile 1/2 UNF threaded rod, some zinc plated
washers and nyloc nuts
The way it is now the bar is taking most of the weight of the back and is also giving the back a little more negative camber.
The other thing I did was bolt down the battery instead of the cable tie & old strap combination I had at Eastern Creek (to the disgust of ANDRA!
- but they passed me and cursed VW's again)
please excuse the iPhone photos
